03-31-2014, 23:33 | #1 (permalink) |
Junior Member Join Date: Dec 2004 Location: Serbia Age: 35
Member: 102194 Status: Offline Thanks Meter: 0 | ZTE Blade III (P772) successfully read, but not write (problem) partition successfully. Code: Selected Resurrector: [ZTE V880 V1.0.4787.19185] Connecting to the dead ************ ... OK Detected dead ************ ID: 0x106220E1 - CORRECT! Set I / O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x250100000000000000000000E9000000 Resurrection sequence started. Establish communication with the phone ... OK Initializing internal hardware configuration ... OK Uploading resurrector data into memory ... OK Starting communication with resurrector ... OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (SJS00M, 0x0000E9000000 Bytes = 3.64 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (SJS00M, 0x000000100000 Bytes = 1.00 MB) Reading FLASH1 address space from 0x000000000000 to 0x0000E8FFFFFF Writing is not working on partitions from emmc chip. Read normal, but try to fill back, it turns out that reading to read, but not written ... Please help! |
