06-08-2011, 13:08 | #1 (permalink) |
Junior Member Join Date: Jun 2011
Member: 1593315 Status: Offline Thanks Meter: 0 | 6300 CNT not flashing properly Files Set for Flashing : MCU : rm217__07.21.mcusw PPM : rm217__07.21.ppm_c CNT : rm217__07.21.image_c_uk Flashing phone now... Check files done... -> SWversion check skipped : Manual mode selected Backup CRT308 data... CRT308 Backup Created... Batery valtage : 3749 mV -> Batery voltage less, than 3,8V (3749mV). Continue at user risk Getting product info... RAP_BOOT: 0901010002010000 RAP_PUBLIC: 0C50010E74607A56E590ABD8EDAE3E70759F47CD CMT_ROOTKEY: BAF3A9C3DBFA8454937DB77F2B8852B1 RAP_PAPUBKEY: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9 Checking CNT sector PN<>FL PN CNT sector : 128 kb Converted content already exist, skip convert and using 128k Loader len: 248320, CHK: 3714 ADL -> Sending loader... Update Server code succesfully sent to phone! TIME : Boot time : 00:00:04 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm217__07.21.mcusw Found 9 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00020000 - 0x0007FFFF, NOR, CMT Result: 0000 Erasing area 0x00080000 - 0x000DFFFF, NOR, CMT Result: 0000 Erasing area 0x00100000 - 0x001FFFFF, NOR, CMT Result: 0000 Erasing area 0x00200000 - 0x0031FFFF, NOR, CMT Result: 0000 Erasing area 0x00320000 - 0x0105FFFF, NOR, CMT Result: 0000 Erasing area 0x01060000 - 0x01067FFF, NOR, CMT Result: 0000 Erasing area 0x01068000 - 0x0107FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:58 Write : Processing rm217__07.21.mcusw Total 944 [944/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] CMT : Writing Hash CERT [PMM_CONF] CMT : Writing Hash CERT [SBIF_CONF] TIME : Write time : 00:01:36 MCU Write done ===Flashing [PPM]=== Erase : Processing rm217__07.21.ppm_c Found 1 areas to erase Erasing area 0x01080000 - 0x015FFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:17 Write : Processing rm217__07.21.ppm_c Total 289 [289/0/0] blocks to write, writing... TIME : Write time : 00:00:28 PPM Write done ===Flashing [CNT]=== Erase : Processing rm217__07.21.image_c_uk_128 Found 1 areas to erase Erasing area 0x01600000 - 0x01FDFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:44 Write : Processing rm217__07.21.image_c_uk_128 Total 308 [308/0/0] blocks to write, writing... TIME : Write time : 00:00:30 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:04:37 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6300 Software Info: V 07.21 05-11-08 RM-217 (c) Nokia. IMEI: 354181028723468 PPM version : V 07.21 05-11-08 RM-217 (c) Nokia. C Product code: 0554371 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:05:25 I think that this line is where it is going wrong. "Converted content already exist, skip convert and using 128k" i think that because of this it tries to flash a different file that i told it to, but this file doesnt exist on my harddrive. ===Flashing [CNT]=== Erase : Processing rm217__07.21.image_c_uk_128 anyone know how to stop it doing this or a workaround? i tried to copy the original file and rename it so it has the extra _128 on the file name but it still wont load the content onto the phone. |
06-08-2011, 13:45 | #3 (permalink) |
Member: 1593315 Status: Offline Thanks Meter: 0 | the CNT file flashes properly on the log but when i load up the phone all content is missing. i put in CNT : rm217__07.21.image_c_uk as file to flash but it converts it to CNT : rm217__07.21.image_c_uk_128 which is the file that leaves no content on the phone afterwards. |
06-08-2011, 17:02 | #5 (permalink) |
Member: 1593315 Status: Offline Thanks Meter: 0 | Files Set for Flashing : CNT : rm217__07.21.image_c_uk Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected -> Custom flashing in dead mode active! -> Phone will boot in normal mode after flash! Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006010C192101001101 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 21100113B38C7A56D18DB5E20C945F790FB72C0C CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : ASIC CMT select Ok ===Flashing [CNT]=== Erase : Processing rm217__07.21.image_c_uk Found 1 areas to erase Erasing area 0x01600000 - 0x01FDFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:49 Write : Processing rm217__07.21.image_c_uk Total 308 [308/0/0] blocks to write, writing... TIME : Write time : 00:00:34 CNT Write done ADL : End flashing |
06-08-2011, 17:35 | #7 (permalink) |
Member: 1593315 Status: Offline Thanks Meter: 0 | Same result, no content. tried multiple file versions and flashing entire phone again as well. Is it possible that this is a hardware fault on the dongle rather than the software? |
06-08-2011, 17:54 | #8 (permalink) |
No Life Poster Join Date: Jan 2010 Location: ANKLESHWAR,GUJARAT,INDIA Age: 41
Member: 1212231 Status: Offline Sonork: 100.1611130 Thanks Meter: 164 | BR>> if u want solvad u r problem so flesh with other tool i mean mxkey so same plz send mx key info .......... |
06-08-2011, 17:56 | #9 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | sahilfency, mon(key) go away. tbcsc, looks like it hw problem. CNT have 128 and 64 pages. You tried both - if no content - looks like exist troubles. Try flash via fbus, if possible. |
The Following User Says Thank You to Dzirt For This Useful Post: |
06-08-2011, 18:57 | #11 (permalink) |
Member: 1593315 Status: Offline Thanks Meter: 0 | Flash via FBUS solved some, had to go back to different software to fix the rest. Shame really, my FBUS clip can be unreliable sometimes, would have preferred to keep using USB and BEST dongle for the whole process. |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
