06-08-2011, 09:11 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: Georgia
Member: 772384 Status: Offline Thanks Meter: 40 | 6303c can not unlock Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 6303 classic Software ver : V 08.90 30-06-09 RM-443 (c) Nokia IMEI : 359333038983310 Ape Ver : APE Var : APE ADSP: DSP Ver : ICPR81_09w10_pre APE Test: PPM : V 08.90 30-06-09 RM-443 (c) Nokia C CNT : Content: c_de_steel O2 DE 30-06-09 RM-443 (c) Nokia Product SN : KPE886544 Product code : 0587468 Base Prd.code: 0575069 Module code : 0204282 Long Prod.SN : 0 Hardware info======= HWID : 2002 Retu : 16 Tahvo : 22 Batery: 4673 mV Camera: CMT BT: Error APE BT: Error APE HW: Error LCDVer: SEIKO RF ic : 0831 Lock info =========== IMEI : 359333038983310 IMEI spNet : IMEI svNet : Conf key : 8000000000000000 Provider key : 2620700000000000 Provider : O2 Deutschland (DCT3 Contract);Germany Counters : Key 0 [3] , Fbus 0 [10] Blocks : 2 LOCK STATUS : ============================= BLK : 1 Lock1:Close BLK : 2 Lock1:Close ============================= LOCKS : Closed ============================= User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! it is info here is the log unlocking Phone Imei: 359333038983310 Checking locks... Checking locks... Conf key : 8000000000000000 Provider key : 2620700000000000 Provider : O2 Deutschland (DCT3 Contract);Germany Counters : Key 0 [3] , Fbus 0 [10] Blocks : 2 LOCK STATUS : ============================= BLK : 1 Lock1:Close BLK : 2 Lock1:Close ============================= LOCKS : Closed ============================= PA_SL3 phone detected... Setting FlashMode FlashMode set Ok No answer from phone... 1. Check cable/connection, try again 2. Maybe HW fault or bad cable Error fetching data... Can't read Unique data! Upload Job fail...! |
06-08-2011, 12:24 | #2 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | Hello Quote:
6303c PA_SL3 phone U need Unlock on BF ser or on OWN LBF Br | |
06-08-2011, 14:15 | #4 (permalink) |
Member: 772384 Status: Offline Thanks Meter: 40 | here is log with jaf ? card found: S/N 1B06:0118 registered to: kerpua Connect phone on selected interface... Opening Connection... Device Location: 00000022 Connect Ok! Initializing Connection... JAF Firmware: 01.B4 Authentificate JAF BOX... TEA Authentication Completed... JAF S/N ODJAF000 boot - Ok Switch jaf to FBUS... FbusMode set Ok Connect phone on selected interface... Read and Check phone data... Read and Check phone data... Opening Connection... Device Location: 00000022 Connect Ok! Initializing Connection... JAF Firmware: 01.B4 Authentificate JAF BOX... TEA Authentication Completed... JAF S/N ODJAF000 boot - Ok Switch jaf to FBUS... FbusMode set Ok Connect phone on selected interface... Read and Check phone data... Read and Check phone data... Read and Check phone data... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 6303 classic Software ver : V 08.90 30-06-09 RM-443 (c) Nokia IMEI : 359333038983310 Ape Ver : APE Var : APE ADSP: DSP Ver : ICPR81_09w10_pre APE Test: PPM : V 08.90 30-06-09 RM-443 (c) Nokia C CNT : Content: c_de_steel O2 DE 30-06-09 RM-443 (c) Nokia Product SN : KPE886544 Product code : 0587468 Base Prd.code: 0575069 Module code : 0204282 Long Prod.SN : 0 Hardware info======= HWID : 2002 Retu : 16 Tahvo : 22 Batery: 4797 mV Camera: CMT BT: 410B-v170 APE BT: APE HW: LCDVer: SEIKO RF ic : 0831 Lock info =========== IMEI : 359333038983310 IMEI spNet : IMEI svNet : Conf key : 8000000000000000 Provider key : 2620700000000000 Provider : O2 Deutschland (DCT3 Contract);Germany Counters : Key 0 [3] , Fbus 0 [10] Blocks : 2 LOCK STATUS : ============================= BLK : 1 Lock1:Close BLK : 2 Lock1:Close ============================= LOCKS : Closed ============================= User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Check client version... Compatible: 1.20.0. or higer... Connecting to server... Server have 425 free slot(s) Upload Job procedure started... Phone Imei: 359333038983310 Checking locks... Checking locks... Conf key : 8000000000000000 Provider key : 2620700000000000 Provider : O2 Deutschland (DCT3 Contract);Germany Counters : Key 0 [3] , Fbus 0 [10] Blocks : 2 LOCK STATUS : ============================= BLK : 1 Lock1:Close BLK : 2 Lock1:Close ============================= LOCKS : Closed ============================= PA_SL3 phone detected... Checking BUS... Switch jaf to FlashMode... FlashMode set Ok Booting phone... Switch jaf to FlashMode... FlashMode set Ok Booting phone... Switch jaf to FlashMode... FlashMode set Ok Booting phone... Switch jaf to FlashMode... FlashMode set Ok Booting phone... Switch jaf to FlashMode... FlashMode set Ok Booting phone... Switch jaf to FlashMode... FlashMode set Ok Booting phone... BOOT 1ST : 00 |
06-08-2011, 14:50 | #5 (permalink) |
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | Hello If U Use JAF then ur JAF box is damage ,need Repair For SL3 u Must Need Use UFS BOX ,connect Use and try to check if If same error on ufs then 100% ur cable Fault Br |
06-09-2011, 14:53 | #8 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Lagos, Nigeria
Member: 152547 Status: Offline Sonork: 100.1586021 Thanks Meter: 143 | the same problem here Connecting to server... Server have 447 free slot(s) Upload Job procedure started... Phone Imei: 352682048507585 Checking locks... Checking locks... Conf key : 8000000000000000 Provider key : 2341000000000000 Provider : 02 - Cellnet;United Kingdom Counters : Key 0 [3] , Fbus 0 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close ============================= LOCKS : Closed ============================= PA_SL3 phone detected... Setting FlashMode FlashMode set Ok No answer from phone... 1. Check cable/connection, try again 2. Maybe HW fault or bad cable Error fetching data... Can't read Unique data! Upload Job fail...! Phone disconected! Connect phone on selected interface... |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
