10-29-2013, 14:43 | #2 (permalink) |
Freak Poster Join Date: Sep 2005 Location: SPB Age: 45
Member: 182653 Status: Offline Thanks Meter: 115 | Why some people again and again create more stupid topics about flashing N9 and not wanting to read the forum? http://forum.gsmhosting.com/vbb/f641...ia-n9-1732412/ |
10-29-2013, 16:31 | #3 (permalink) | |
No Life Poster Join Date: Aug 2012 Location: under pross
Member: 1798174 Status: Online Sonork: 100.114149 Thanks Meter: 1,048 | Quote:
10-29-2013, 21:29 | #6 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | If you check section via search - this question asked seems, every day , so, that is reason why reaction such. If you want get result fast - try use search - I sure on 90% - you will find answer to your question. If not - you can make thread an get answer. |
The Following User Says Thank You to Dzirt For This Useful Post: |
10-29-2013, 21:37 | #7 (permalink) | |
mr Dzirt you can help me how to cancel user code in n9 phone!! phone flashed but still asked for user code with my respect | |
The Following User Says Thank You to Pastime_GSM For This Useful Post: |
10-29-2013, 21:56 | #8 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | http://forum.gsmhosting.com/vbb/f641...-n950-1403946/ Case 2 or Case 3 |
10-30-2013, 09:15 | #9 (permalink) | |
what to do!! br | |
10-30-2013, 10:31 | #14 (permalink) |
Member: 1798174 Status: Online Sonork: 100.114149 Thanks Meter: 1,048 | all operations done with seccess thx goes to you mr Dzirt ------------------------------- ---Processing MCU image--- Processing File : DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_001-OEM1-958_ARM.bin MKII : Sending config for [cert-sw] -> Ver T : RM-696 -> Ver H : 1507 , 1508 , 1509 , 1510 , 1601 , 1602 , 1603 , 1604 , 1605 , 1701 , 1702 , 1703 , 1704 , 1705 , 1801 , 1802 , 1803 , 1804 , 1805 MKII : Init pipe 00 MKII : Flashing... MKII : Finalizing... cert-sw Flash done MKII : Sending config for [kernel] -> Ver I : 2.6.32-20121301+0m8 MKII : Init pipe 01 MKII : Flashing... MKII : Finalizing... kernel Flash done MKII : Sending config for [rootfs] -> Ver I : DFL61_HARMATTAN_40.2012.21-3_PR_001 MKII : Init pipe 02 MKII : Flashing... MKII : Finalizing... rootfs Flash done MKII : Sending config for [cmt-2nd] -> Ver T : RM-696 MKII : Init pipe 03 MKII : Flashing... MKII : Finalizing... cmt-2nd Flash done MKII : Sending config for [cmt-algo] -> Ver T : RM-696 MKII : Init pipe 04 MKII : Flashing... MKII : Finalizing... cmt-algo Flash done MKII : Sending config for [cmt-mcusw] -> Ver I : 9.2.2011.51 -> Ver T : RM-696 MKII : Init pipe 05 MKII : Flashing... MKII : Finalizing... cmt-mcusw Flash done MKII : Sending config for [xloader] -> Ver I : 2.3.6+0m7 -> Ver T : RM-696 -> Ver H : 1507 , 1508 , 1509 , 1510 , 1601 , 1602 , 1603 , 1604 , 1605 , 1701 , 1702 , 1703 , 1704 , 1705 , 1801 , 1802 , 1803 , 1804 , 1805 MKII : Init pipe 06 MKII : Flashing... MKII : Finalizing... xloader Flash done MKII : Sending config for [secondary] -> Ver I : 2.3.6+0m7 -> Ver T : RM-696 -> Ver H : 1507 , 1508 , 1509 , 1510 , 1601 , 1602 , 1603 , 1604 , 1605 , 1701 , 1702 , 1703 , 1704 , 1705 , 1801 , 1802 , 1803 , 1804 , 1805 MKII : Init pipe 07 MKII : Flashing... MKII : Finalizing... secondary Flash done Switch : OSSO UART+USB Version : DFL61_HARMATTAN_40.2012.21-3_PR_001 Update SW release Ok ---Processing eMMC image--- Processing File : DFL61_HARMATTAN_40.2012.13-7.NOMAPS_EMMC_NOMAPS.bin MKII : Sending config for [mmc] -> Ver I : DFL61_HARMATTAN_40.2012.13-7.NOMAPS MKII : Init pipe 08 MKII : Flashing... MKII : Finalizing... mmc Flash done Done! |
