12-24-2011, 17:19 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Maemo/MeeGo Guide (N9/N900/N950...) Here some explain and How-to instruction about N900/N9/N950 devices. General : Don't downgrade phone version!!!!! Always flash LATEST available!!! Don't FLASH any non-official firmwares Flash ONLY SUITABLE Firmware for your phone!!!! Twice CHECK ALL before press FLASH and connect phone!!! N900 (Maemo): Reflash - Need Select Maemo in generation (selected by default) Need select MCU file Press Check Files Press Flash Connect phone holding U button. All is done, waiting till process finish. User Code - All is same as for flash. After RootFs flashing code request will not appear on phone. U also able read N900 User Code . http://forum.gsmhosting.com/vbb/f641...d-how-1406166/ N9, N950 (MeeGo) Case1 : We have 2 flashfiles (MCU, eMMC), Want UPGRADE It Will clear all Data, Reset Code and all app's inside. Need Select MeeGo in generation Need select MCU file Need Select eMMC file Press Check Files Press Flash If phone connected - just wait till finish. If not - connect powered OFF phone. ( Power OFF it and wait near 20 seconds, after connect ) All is done, waiting till process finish. Estimated time is - 5 minutes for process Case2 : We have 2 flashfiles (MCU, eMMC), Want FullFlash device (as from factory) It Will clear all Data, Reset Code and all app's inside. Need Select MeeGo in generation Need select MCU file Need Select eMMC file Press Check Files Tick WIPE in Flash Settings Press Flash If phone connected - just wait till finish. If not - connect powered OFF phone. ( Power OFF it and wait near 20 seconds, after connect ) All is done, waiting till process finish. Estimated time is - 8-12 minutes for process Case3 : We have 1 flashfiles (MCU), Want FullFlash device (as from factory) It Will clear all Data, Reset Code and all app's inside. Useful if we can't download 2,5gb of eMMC Need Select MeeGo in generation Need select MCU file Press Check Files Tick WIPE in Flash Settings Press Flash If phone connected - just wait till finish. If not - connect powered OFF phone. ( Power OFF it and wait near 20 seconds, after connect ) All is done, waiting till process finish. Estimated time is - 8-12 minutes for process After - Power On phone. Go to : Settings - scrool down - select Reset, Select Clear Device. Wait till phone finish. After phone shows big circle - wait until it turn off. Power On phone. All is done. This will help refurbish device without eMMC. Separate Wipe button ( again - RED BUTTON ) - need for others, special cases. For flashing - Wipe option in FLASH settings. .. how to Read N900 user codes http://forum.gsmhosting.com/vbb/f641...d-how-1406166/ Last edited by Mohsin-*; 03-21-2012 at 08:22. Reason: adding |
The Following 66 Users Say Thank You to Dzirt For This Useful Post: |
12-25-2011, 03:05 | #4 (permalink) |
Freak Poster Join Date: Feb 2011 Location: china
Member: 1513547 Status: Offline Sonork: 琥珀帅 Thanks Meter: 18 | sir .. if i have n9 user code .... .i don't want to flash file ... that i can only press wipe button for clear user code ? if it can ... i thinks it is great feature..... |
The Following User Says Thank You to wanshuai163 For This Useful Post: |
12-25-2011, 06:45 | #8 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | It will format Swap and eMMC. We will have brick, until we reflash it with bin and emmc. I Was plan add more features for it in future, if it will be possible. |
12-25-2011, 07:46 | #9 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | N9 (64gb version) flashing - BIN+eMMC with wipe. 9 minutes for all Code: Rebooting... Insert cable in to powered OFF phone! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RM-696 , HWRev : 1501 NOLO : 01/05/21 SWVer: DFL61_HARMATTAN_20.2011.40-4_PR_001 Device mode : Production mode Read info Ok Processing APE Boot... File : DFL61_HARMATTAN_20.2011.40-4_PR_LEGACY_001-OEM1-958_ARM..bin Processing : ape-algo APE Algorithm boot Ok Reopening the connection... RFS mode init Ok Device : RM-696 HW build : 1501 Bat.level : 91 SW release : (empty) Protocol : 108 UPDAPP ver : 1.6.3 Upd/Dev PT : 3 , 3 FL_images : cert-sw,xloader,secondary,rootfs,kernel,moslo,config,mmc,tar,cmt-2nd,cmt-algo,cmt-mcusw Last errors : bb5_rdc_cert_read failed Code Match Ok HW match Ok RFS : Performing FULL WIPE... Starting Wipe... Bat.level : 91 Battery voltage is enough, starting wipe... Formatting... Can take up to 15 minutes, wait until process complete Stage #1 : Swap format Ok RFS : No any errors Stage #2 : eMMC format Ok RFS : No any errors RFS Set : Host Protocol set to 108 RFS Set : CMT Verify On RFS Set : Perform RFS On RFS Set : eMMC preserve Off ---Processing MCU image--- Processing File : DFL61_HARMATTAN_20.2011.40-4_PR_LEGACY_001-OEM1-958_ARM..bin RFS : Sending config for [cert-sw] -> Ver T : RM-696 -> Ver H : 1501 , 1502 RFS : Init pipe 00 RFS : Flashing... RFS : Finalizing... cert-sw Flash done RFS : Sending config for [kernel] -> Ver I : 2.6.32-20113701.10+0m6 RFS : Init pipe 01 RFS : Flashing... RFS : Finalizing... kernel Flash done RFS : Sending config for [rootfs] -> Ver I : DFL61_HARMATTAN_20.2011.40-4_PR_001 RFS : Init pipe 02 RFS : Flashing... RFS : Finalizing... rootfs Flash done RFS : Sending config for [cmt-2nd] -> Ver T : RM-696 RFS : Init pipe 03 RFS : Flashing... RFS : Finalizing... cmt-2nd Flash done RFS : Sending config for [cmt-algo] -> Ver T : RM-696 RFS : Init pipe 04 RFS : Flashing... RFS : Finalizing... cmt-algo Flash done RFS : Sending config for [cmt-mcusw] -> Ver I : 9.2.2011.21 -> Ver T : RM-696 RFS : Init pipe 05 RFS : Flashing... RFS : Finalizing... cmt-mcusw Flash done RFS : Sending config for [xloader] -> Ver I : 2.1.5+0m6 -> Ver T : RM-696 -> Ver H : 1501 , 1502 RFS : Init pipe 06 RFS : Flashing... RFS : Finalizing... xloader Flash done RFS : Sending config for [secondary] -> Ver I : 2.1.5+0m6 -> Ver T : RM-696 -> Ver H : 1501 , 1502 RFS : Init pipe 07 RFS : Flashing... RFS : Finalizing... secondary Flash done ---Processing eMMC image--- Processing File : DFL61_HARMATTAN_20.2011.40-4.EURASIA_EMMC_EURASIA.bin RFS : Sending config for [mmc] -> Ver I : DFL61_HARMATTAN_20.2011.40-4.EURASIA RFS : Init pipe 08 RFS : Flashing... RFS : Finalizing... mmc Flash done Done! Elapsed: 00:09:47 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
The Following User Says Thank You to Dzirt For This Useful Post: |
12-25-2011, 07:51 | #10 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | @ Dzirt Request to change your Avatar in my point of view Official should be more visible ur avator should discriminate you that ur from the support team Peoples like me always search the official announcement , i feel difficulty due to ur avator |
The Following 2 Users Say Thank You to cel_phon For This Useful Post: |
12-25-2011, 07:57 | #11 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | cel_phon, sorry, but, from my point of view - I should do my work. Other - only as I wish. I not in support officially, so... |
12-25-2011, 08:50 | #15 (permalink) |
Freak Poster Join Date: Mar 2008 Location: I Don,t Know Age: 38
Member: 718939 Status: Offline Thanks Meter: 90 | hello Dzrit I have a Nokia N9 hang on Nokia logo, I download MCU file on infinty support area and trying to flash set , but always stop here. plz chack where is problem Insert cable in to powered OFF phone! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RM-696 , HWRev : 1603 NOLO : 01/31/20 SWVer: DFL61_HARMATTAN_10.2011.34-1_PR_006 Device mode : Production mode Read info Ok Processing APE Boot... File : DFL61_HARMATTAN_10.2011.34-1.365.1_PR_LEGACY_365_ARM_RM-696_PRD_signed.bin Processing : ape-algo APE Algorithm boot Ok Reopening the connection... RFS mode init Ok Device : RM-696 HW build : 1603 Bat.level : 24 SW release : (empty) Protocol : 108 UPDAPP ver : 1.5.26 Upd/Dev PT : 3 , 3 FL_images : cert-sw,xloader,secondary,rootfs,kernel,moslo,config,mm c,tar,cmt-2nd,cmt-algo,cmt-mcusw Last errors : bb5_rdc_cert_read failed Code Match Ok HW match Ok RFS : Performing SWAP WIPE... Starting Wipe... Bat.level : 24 Battery voltage is enough, starting wipe... Formatting... Can take up to 15 minutes, wait until process complete RFS : Swap format Ok RFS : No any errors RFS Set : Host Protocol set to 108 RFS Set : CMT Verify On RFS Set : Perform RFS On RFS Set : eMMC preserve On ---Processing MCU image--- Processing File : DFL61_HARMATTAN_10.2011.34-1.365.1_PR_LEGACY_365_ARM_RM-696_PRD_signed.bin RFS : Sending config for [cert-sw] -> Ver T : RM-696 -> Ver H : 1507 , 1508 , 1509 , 1510 , 1601 , 1602 , 1603 , 1604 , 1605 , 1701 , 1702 , 1703 , 1704 , 1705 , 1801 , 1802 , 1803 , 1804 , 1805 RFS : Init pipe 00 RFS : Flashing... RFS : Finalizing... cert-sw Flash done RFS : Sending config for [kernel] -> Ver I : 2.6.32-20112910+0m6 RFS : Init pipe 01 RFS : Flashing... RFS : Finalizing... kernel Flash done RFS : Sending config for [rootfs] -> Ver I : DFL61_HARMATTAN_10.2011.34-1.365.1_PR_365 RFS : Init pipe 02 RFS : Flashing... RFS : ERROR_PIPE_CHECK_REQ FAILED Receiving error list... Last errors : bb5_rdc_cert_read failed bb5_rdc_cert_read failed bb5_rdc_cert_read failed bb5_rdc_cert_read failed bb5_rdc_cert_read failed mmc: handle_buffer failed in lzo decompress (-1) [Pipe 2] Finishing in error state with status 1 Flashing failed More info in Last Error Log |
The Following User Says Thank You to HAMMZA_MOBILES For This Useful Post: |
Guide to Rolis Flasher! | davieb | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 01-29-2002 16:53 |
Unlocking & Repair Guide | guruguide | GSM Mobile Links | 1 | 12-13-2001 15:23 |
Free SMSc's and Flashing Guides | davieb | GSM Mobile Links | 0 | 12-05-2001 15:51 |
Idiots guide to unlocking Nokia 3210 V6.00 NSE - 8/9 (03-10-00) req. | belker | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-23-2001 11:26 |
I mean pc guide for nokia 8210 | linda | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-18-2000 20:49 |
