03-12-2011, 09:46 | #31 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2011 Location: Codes Database Age: 48
Member: 1512061 Status: Offline Sonork: 100.1587135 Thanks Meter: 135 | log here Checking BUS... Switch jaf to FlashMode... FlashMode set Ok Booting phone... BOOT 1ST : C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 14B001147C7D6C5638A6559A28EEA8183917122A CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok MCU configuration CMT Flash ID : 220800EC < SAMSUNG [SEC] => K8F5615ETM\K5G5629ATD FLASHID : 220800EC , CMT , NOR FLCNT : 00000000000000000000000000000000000000 CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok FLASHID : 0000FFFF , CMT , MMC , EXT TransmissionReq : 16 bit, Single TransmissionReq : Accepted, 16 bit, Single Sending ALGO.... Use : RAP3Gv3_algo.fg CMT Algo sent! TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual Boot done! TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual Erase : Processing rm217__07.21.mcusw Init Erase Mode Ok Found 9 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00020000 - 0x0007FFFF CMT , NOR , Area : 0x00080000 - 0x000DFFFF CMT , NOR , Area : 0x00100000 - 0x001FFFFF CMT , NOR , Area : 0x00200000 - 0x0031FFFF CMT , NOR , Area : 0x00320000 - 0x0105FFFF CMT , NOR , Area : 0x01060000 - 0x01067FFF CMT , NOR , Area : 0x01068000 - 0x0107FFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:43 PrReq : NOR, 00 TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual Write : Processing rm217__07.21.mcusw Init Write Mode Ok CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [PMM_CONF] CMT: Writing Hash CERT [SBIF_CONF] Total writen 943 blocks TIME : Write time : 00:01:44 PrReq : NOR, 00 TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual Erase : Processing rm217__07.21.ppm_mea4 Init Erase Mode Ok Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01080000 - 0x015FFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:12 PrReq : NOR, 00 TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual Write : Processing rm217__07.21.ppm_mea4 Init Write Mode Ok Total writen 243 blocks TIME : Write time : 00:00:27 PrReq : NOR, 00 ConvertImage: Processing rm217__07.21.image_mea4_128 ConvertImage: Page Size is 128K, no need convert TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual Erase : Processing rm217__07.21.image_mea4_128 Init Erase Mode Ok Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01600000 - 0x01FDFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:28 PrReq : NOR, 00 TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual Write : Processing rm217__07.21.image_mea4_128 Init Write Mode Ok Total writen 216 blocks TIME : Write time : 00:00:24 PrReq : NOR, 00 Switch jaf to FBUS... FbusMode set Ok Phone connected IMEI : 358052012631338 Simlock status : Simlock is Ok Security status : Security is Ok Flashing done |
The Following 4 Users Say Thank You to .:CodesServer:. For This Useful Post: |
03-12-2011, 09:51 | #32 (permalink) |
Guest
Posts: n/a
Member: | [email protected] need n 70 solution contact retiler |
03-12-2011, 09:55 | #34 (permalink) | ||
No Life Poster Join Date: Sep 2007 Location: Gsm_World
Member: 583353 Status: Offline Thanks Meter: 259 | 2730c RM-578 READ key successfully using ufs: Quote:
03-12-2011, 09:56 | #35 (permalink) |
Freak Poster Join Date: Dec 2009 Location: Roma (Italy)
Member: 1173993 Status: Offline Thanks Meter: 46 | Bro this is not right section, however N70 is SL0, so you can backup RPL, then you can erase phone, flash latest version, write full PM, write full RPL, authorize SX4 and write PM1-309. To repair contact retailer you need to test SECURITY_TEST; probably it's failed, so you need to authorize SX4 and flash PM1-309. Bye |
03-12-2011, 10:08 | #36 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Sorry, my PM is full Test is enough. Waiting for reports. If all be ok - we release Update in few hours. BR |
The Following 2 Users Say Thank You to Dzirt For This Useful Post: |
03-12-2011, 10:42 | #38 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Bogatic , RS Age: 56
Member: 4395 Status: Offline Thanks Meter: 159 | UFS UFS S/N 74744 boot - Ok Connect phone on selected interface... Read and Check phone data... BB5 bus checking... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000030000022600010007600C192102011104 CMT EM0 ID : 00000C34 CMT EM1 ID : 00000C30 CMT PUB ID : 2A500118905C034432C7A619F988D123A9476F3B CMT MODE ID : 00 CMT R_HASH : 25B977A055BE9B5DEC0C38A2A279C695 CMT ROM ID : 3E273BF637BE26FA CMT : Sending 2nd loader... Use : RAPUv11_2nd.fg , Rev : 0.0 Ver : 1.37.1 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 004000EC , CMT , NAND CMT Flash ID : 004000EC < SAMSUNG [SEC] => KAT00F00RA [NAND] FLCNT : 00030000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAPUv11_algo_xsr16.fg , Rev : 0.0 Ver : 1.40.0 CMT Algo sent CMT PAPUB : BA40E42B6F3B8A6EFEE35B4A9D15924EB132C68900 Transmission mode : Dual (Ddr, TX2) Boot Done! Init Service mode... Wait... SimLock status : SimLock is Ok Security status : Security is Ok SDD Key status : SD Data is Ok PA_SimLock Version : PA_SL3 phone detected Done! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Upload Job procedure started... Phone Imei: 353181033997199 Checking locks... Checking locks... Conf key : 8000000000000002 Provider key : 2320300000000000 Provider : T-Mobile ;Austria Counters : Key 0 [3] , Fbus 0 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close ============================= LOCKS : Closed ============================= PA_SL3 phone detected... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000030000022600010007600C192102011104 CMT EM0 ID : 00000C34 CMT EM1 ID : 00000C30 CMT PUB ID : 2A500118905C034432C7A619F988D123A9476F3B CMT MODE ID : 00 CMT R_HASH : 25B977A055BE9B5DEC0C38A2A279C695 CMT ROM ID : 3E273BF637BE26FA CMT : Sending 2nd loader... Use : RAPUv11_2nd.fg rap= 2A500118905C034432C7A619F988D123A9476F3B hash= 25B977A055BE9B5DEC0C38A2A279C695 key= A5FA9F7A35B0E27E5726ACBC31881D3D512DD8B2 Init Service mode... Wait... Key file updated... Connecting to server... Server version: 0.196 Request Submited Credit left: 20 Create Log file for local calculation... File E:\UFS2\Best\Local_calc\353181033997199.bcl created - Ok Done! |
03-12-2011, 10:43 | #39 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: Roof of the world
Member: 209722 Status: Offline Thanks Meter: 818 | Quote:
Oh sorry no need now i got it already from a friend. best wishes. Last edited by CONCORDIA GSM; 03-12-2011 at 10:49. | |
03-12-2011, 10:48 | #41 (permalink) |
Member: 4395 Status: Offline Thanks Meter: 159 | JAF Opening Connection... Device Location: 00000012 Connect Ok! Initializing Connection... JAF BOX is not in boot mode... JAF S/N ODQS9NBV boot error... Connect phone on selected interface... Opening Connection... Device Location: 00000012 Connect Ok! Initializing Connection... JAF Firmware: 01.B1 JAF S/N ODQS9NBV boot - Ok Connect phone on selected interface... Ready for operations... Read and Check phone data... Checking BUS... Switch jaf to FlashMode... FlashMode set Ok Booting phone... Switch jaf to FlashMode... FlashMode set Ok Booting phone... Switch jaf to FlashMode... FlashMode set Ok Booting phone... Switch jaf to FlashMode... FlashMode set Ok Booting phone... Switch jaf to FlashMode... FlashMode set Ok Booting phone... Switch jaf to FlashMode... FlashMode set Ok Booting phone... BOOT 1ST : 00 Error finding required loader... Ready for operations... Ready for operations... |
03-12-2011, 11:11 | #45 (permalink) | |
Cboot_R1 file missing for c/infinity/best/flash/ufs/spacial/Cboot_R1 the system can not found file spacified. | |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
