07-03-2011, 12:55 | #1 (permalink) |
No Life Poster Join Date: Jun 2011
Member: 1590039 Status: Offline Thanks Meter: 20 | c1 dead after flash card found: S/N 20B8:0118 registered to: hamid20 Connect phone on selected interface... UFS S/N 101934 boot - Ok Connect phone on selected interface... Read and Check phone data... Infineon checking... Booting phone now.... Sync Ok , A2 CPU ID : XGOLD , A200341100 Boot Ok , 01AB Algo Ok , 01 SBL mode Ok SBL : Default_RAM_Bootloader EPP CFG [Bering]... FLASH ID : 00EC000000542200 FLASH ID : Samsung, K8S6415E Boot Done! Done! Connect phone on selected interface... Core version : 1.22 , Rev : 4.5 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm689_003.000 PPM : rm689_003.00ij CNT : rm6890_nai03.00ij Infineon flashing... Booting phone now.... Sync Ok , A2 CPU ID : XGOLD , A200341100 Boot Ok , 01AB Algo Ok , 01 SBL mode Ok SBL : Default_RAM_Bootloader EPP CFG [Bering]... FLASH ID : 00EC000000542200 FLASH ID : Samsung, K8S6415E Boot Done! ===Flashing [MCU]=== File : rm689_003.000 Image : hw_s01_rm689_r03.000.fls Cert block found, sending.... Cert sent Found 3 region(s) Processing Region 1/3 Erase , Start : 0x00800000 , Len : 0x00210000 Erasing, wait ... Erase done Write , Start : 0x00800000 , Len : 0x00210000 Flashing , wait ... Region flash done Processing Region 2/3 Erase , Start : 0x00C60000 , Len : 0x00250000 Erasing, wait ... Erase done Write , Start : 0x00C60000 , Len : 0x0020A880 Flashing , wait ... Region flash done Processing Region 3/3 Erase , Start : 0x00FFC000 , Len : 0x00004000 Erasing, wait ... Erase done Write , Start : 0x00FFC000 , Len : 0x00000040 Flashing , wait ... Region flash done Check : 446F ===Flashing [PPM]=== File : rm689_003.00ij Image : hw_s01_rm689_003.00ij.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00210000 , Len : 0x00250000 Erasing, wait ... Erase done Write , Start : 0x00210000 , Len : 0x001DF800 Flashing , wait ... Region flash done Check : 6BD4 ===Flashing [CNT]=== File : rm6890_nai03.00ij Image : hw_s01_rm6890_nai03.00ij.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00EB0000 , Len : 0x000D0000 Erasing, wait ... Erase done Write , Start : 0x00EB0000 , Len : 0x000510C0 Flashing , wait ... Region flash done Check : D7EA Flashing done, rebooting... -> Infineon info : Do FullFactory Sets after flashing Flashing Done! Init Service mode... Wait... Init service mode failed! Try powerup phone manually and connect User ACCEPTED FULL ERASE Setting FlashMode FlashMode set Ok No answer from phone... 1. Check cable/connection, try again 2. Maybe HW fault or bad cable Error booting phone... Check Cable/HW , Try Again Connecting to server... Server have 903 free slot(s) Approx. time of calculation for first free slot: 25 Hour Phone not connected... Core version : 1.22 , Rev : 4.5 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm689_003.000 PPM : rm689_003.00ij CNT : rm6890_nai03.00ij Infineon flashing... Booting phone now.... Sync Ok , A2 CPU ID : XGOLD , A200341100 Boot Ok , 01AB Algo Ok , 01 SBL mode Ok SBL : Default_RAM_Bootloader EPP CFG [Bering]... FLASH ID : 00EC000000542200 FLASH ID : Samsung, K8S6415E Boot Done! ===Flashing [MCU]=== File : rm689_003.000 Image : hw_s01_rm689_r03.000.fls Cert block found, sending.... Cert sent Found 3 region(s) Processing Region 1/3 Erase , Start : 0x00800000 , Len : 0x00210000 Erasing, wait ... Erase done Write , Start : 0x00800000 , Len : 0x00210000 Flashing , wait ... Region flash done Processing Region 2/3 Erase , Start : 0x00C60000 , Len : 0x00250000 Erasing, wait ... Erase done Write , Start : 0x00C60000 , Len : 0x0020A880 Flashing , wait ... Region flash done Processing Region 3/3 Erase , Start : 0x00FFC000 , Len : 0x00004000 Erasing, wait ... Erase done Write , Start : 0x00FFC000 , Len : 0x00000040 Flashing , wait ... Region flash done Check : 446F ===Flashing [PPM]=== File : rm689_003.00ij Image : hw_s01_rm689_003.00ij.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00210000 , Len : 0x00250000 Erasing, wait ... Erase done Write , Start : 0x00210000 , Len : 0x001DF800 Flashing , wait ... Region flash done Check : 6BD4 ===Flashing [CNT]=== File : rm6890_nai03.00ij Image : hw_s01_rm6890_nai03.00ij.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00EB0000 , Len : 0x000D0000 Erasing, wait ... Erase done Write , Start : 0x00EB0000 , Len : 0x000510C0 Flashing , wait ... Region flash done Check : D7EA Flashing done, rebooting... -> Infineon info : Do FullFactory Sets after flashing Flashing Done! Init Service mode... Wait... Init service mode failed! Try powerup phone manually and connect |
07-03-2011, 13:05 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Sure, it will be dead! Next time press all possible buttons, without understanding Nokia program basics - like platform, how can be flashed and other things. On this log - flash 2.60 - phone will be alive again. Or try flash 3.30 - it should work too. |
07-11-2011, 13:57 | #3 (permalink) |
No Life Poster Join Date: Oct 2007 Location: VIZAG,A.P, INDIA
Member: 602547 Status: Offline Sonork: 100.1621466 Thanks Meter: 930 | bro dont use 3.00 use 2.5 or 2.6 version of falsh file to falsh nokia c1-00 because u use 3.00 the main falsh file mcu checksum verified error! Certificate mismatch. Used 2.6 set will be ok 10000000000000000000000000% |
07-11-2011, 14:04 | #4 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Now exist 3.31 and 3.30 versions, as I know - they are Ok to Flash. Code: Phone found! Series 40 Device detected! read info... - Ok Read and Check phone data... Infineon checking... SIMLOCK TEST : Ok RUN TEST : Ok Booting phone now.... Sync Ok , A2 CPU ID : XGOLD , A200341100 Boot Ok , 01AB Algo Ok , 01 SBL mode Ok SBL : Default_RAM_Bootloader EPP CFG [Bering]... FLASH ID : 00EC0000007A2200 FLASH ID : UNKNOW [Not In Base] Boot Done! Done! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core version : 1.23 , Rev : 4.8 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm689_003.310 PPM : rm689_003.31ij CNT : rm6890_nai03.31ij Infineon flashing... Booting phone now.... Sync Ok , A2 CPU ID : XGOLD , A200341100 Boot Ok , 01AB Algo Ok , 01 SBL mode Ok SBL : Default_RAM_Bootloader EPP CFG [Bering]... FLASH ID : 00EC0000007A2200 FLASH ID : UNKNOW [Not In Base] Boot Done! ===Flashing [MCU]=== File : rm689_003.310 Image : hw_s01_rm689_r03.310.fls Cert block found, sending.... Cert sent Found 3 region(s) Processing Region 1/3 Erase , Start : 0x00800000 , Len : 0x00210000 Erasing, wait ... Erase done Write , Start : 0x00800000 , Len : 0x00210000 Flashing , wait ... Region flash done Processing Region 2/3 Erase , Start : 0x00C60000 , Len : 0x00250000 Erasing, wait ... Erase done Write , Start : 0x00C60000 , Len : 0x0020ADC0 Flashing , wait ... Region flash done Processing Region 3/3 Erase , Start : 0x00FFC000 , Len : 0x00004000 Erasing, wait ... Erase done Write , Start : 0x00FFC000 , Len : 0x00000040 Flashing , wait ... Region flash done Check : A86A ===Flashing [PPM]=== File : rm689_003.31ij Image : hw_s01_rm689_003.31ij.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00210000 , Len : 0x00250000 Erasing, wait ... Erase done Write , Start : 0x00210000 , Len : 0x001DF880 Flashing , wait ... Region flash done Check : 303F ===Flashing [CNT]=== File : rm6890_nai03.31ij Image : hw_s01_rm6890_nai03.31ij.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00EB0000 , Len : 0x000D0000 Erasing, wait ... Erase done Write , Start : 0x00EB0000 , Len : 0x000510C0 Flashing , wait ... Region flash done Check : D7B9 Flashing done, rebooting... -> Infineon info : Do FullFactory Sets after flashing Flashing Done! Init Service mode... Wait... Afterflash settings... SW ver : V 03.31 16-05-11 RM-689 (c) Nokia IMEI : 3548740xxxxx543 PCode : 059B341 Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! All done! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... SW ver : V 03.31 16-05-11 RM-689 (c) Nokia IMEI : 3548740xxxxx543 PPM : V 03.31 16-05-11 RM-689 (c) Nokia IJ PCode : 059B341 BPCode : 059D336 HWID : 1001 LCDVer : INNO:BOHAIv93 NT39121 IMEI : 3548740xxxxx543 Sl Conf : 001-01-00000000000 Sl Prof : 000000000003000-2 Sl Aux : 000B0000 Hw Sig : 168412E4E4D89B9B Provider : Default Test Operator Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Done! Phone disconected! |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
5110 5.24 locked all 4 locks after unlocking... | MCG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-07-2000 22:24 |
