06-17-2011, 12:07 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In a point from Universe! Age: 40
Member: 235325 Status: Offline Sonork: 100.1593552 Thanks Meter: 523 | C6-01 save info?!? I've got an c6-01 dead(vibrates only) and I need to save the phonebook from it. I tried but I get error Code: Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia C6-01 Software ver : V 92PS1_10w36.4 06-10-10 RM-718 (c) Nokia IMEI : 353759040608014 Ape Ver : 012.006 APE Var : 012.006.00.01012.006.01.01012.006.00.01 APE ADSP: 256 DSP Ver : TB92PS1_10w36 APE Test: 0.040 PPM : CNT : Product SN : CYD439997 Product code : 059C1D4 Base Prd.code: 059C012 Module code : Long Prod.SN : 0 Hardware info======= HWID : 0500 Retu : 40 Tahvo : 00 Batery: 4704 mV Camera: CMT BT: APE BT: HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. APE HW: 256 LCDVer: RF ic : |Alli_4.3.4 Lock info =========== IMEI : 353759040608014 IMEI spNet : IMEI svNet : Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= User code : Crypted UserDataExLevel : Low [Gallery] Done! BackUp UserData : [PhoneBook] Generation mode : [S60] Operating mode is OK, no need change... SmartPhone algo initialise... Setup data... StartUp FileSystem... Fsrun OK... Detect Symbian OS Generation... Detected: [Symbian OS 9.3/9.4] Phone! Warning! Many [9.3] and [9.4] phones not supported now :( Running : APE_TEST_SERVER,w23_10,(c)NMP Not found :( PhoneBook not found at all :( Error during read... Can be the save operation improved for this kind of newest phones? Thanks! |
06-17-2011, 19:17 | #3 (permalink) |
Member: 235325 Status: Offline Sonork: 100.1593552 Thanks Meter: 523 | It might be possible to be one of unsupported phones or bug from the program? Code: Warning! Many [9.3] and [9.4] phones not supported now :( Tomorrow I'll try with some other new phones(c7,c6-00,e72...) Regards! |
06-18-2011, 06:01 | #4 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | N70 supported. C7, C6, N8, E72 - not. We working on solutions. In 9.3/9.4 symbian Best will show - exist phonebook or not. In this log i can't see phonebook. |
06-20-2011, 15:49 | #5 (permalink) | |
Member: 235325 Status: Offline Sonork: 100.1593552 Thanks Meter: 523 | Quote:
can You check in the next future versions to improve detection of phonebook because there are some bugs in this. You said that for some phones (c6,c7 ...) the software detects if there is phonebook in the phone but it might get errors on saving. As You can see this is the same phone from the first post(I solved it hw) and I also checked it if is detecting the presence of phonebook but it's the same job like first time Here is the video made with the phone wich has contacts but the software don't detect it. I'm sure that will be solved this inconveniences and the comunications will be improved. Regards! | |
06-20-2011, 16:18 | #6 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | It depends on Symbian version and many other facts. Actually on 9.4/9.4 - we can detect phonebook present. (read also possible, but not work as well , we try end it soon ) About S^3 can't say anything - not have such phones yet for tests. |
The Following User Says Thank You to Dzirt For This Useful Post: |
I need info doc to make scripts for send.exe ThanksĦĦ | Bolo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 04-09-2000 11:49 |
Need solution for 3210 v5.01 | tati | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-20-2000 21:55 |
Please info unlock 6150v517 | cIVIc | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 12-27-1999 21:11 |
Please info unlock 6150 v5.17 | cIVIc | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-01-1999 03:13 |
Need info for unliocking 2 lock (with pic microprocesors) | Tomas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-26-1999 01:00 |
