06-23-2011, 08:56 | #5 (permalink) |
No Life Poster Join Date: Jul 2007 Location: UK Age: 45
Member: 553000 Status: Offline Thanks Meter: 2,302 | I hv also C1-01 plz suggest me how to unlock ? I hv also C1-01 plz suggest me how to unlock ? here is the info by USB cable : Code: Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - C1-01 Software ver : V 03.35 02-12-10 RM-607 (c) Nokia IMEI : 355962048588414 Ape Ver : APE Var : APE ADSP: DSP Ver : APE Test: PPM : V 03.35 02-12-10 RM-607 (c) Nokia C CNT : Content: O2 GB sl V 03.35 02-12-10 RM-607 (c) Nokia Product SN : HUD185294 Product code : 059D9N8 Base Prd.code: 0585582 Module code : 0204427 Long Prod.SN : 0 Hardware info======= HWID : 1000 Retu : Tahvo : Batery: 4079 mV Camera: CMT BT: 19b5-22012 APE BT: APE HW: LCDVer: TPO RF ic : Lock info =========== IMEI : 355962048588414 IMEI spNet : 3A 55 69 02 84 85 48 01 IMEI svNet : 33 55 69 02 84 85 48 01 F7 Sl Conf : 234-10-00000000000 Sl Prof : 800000000003000-B Sl Aux : 000B0000 Hw Sig : 6EA0ED454F6FAAF9 Provider : 02 - Cellnet;United Kingdom Lock info: Block 1 L1:Close; CRT308 Backup Created User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Kmaxmax |
The Following 3 Users Say Thank You to kmaxmax For This Useful Post: |
06-23-2011, 10:06 | #7 (permalink) |
No Life Poster Join Date: Apr 2008 Location: INSIDE OCLHASHCAT
Member: 751235 Status: Offline Sonork: 100.1662008 Thanks Meter: 526 | i have one with security code, how do i remove cos if i manage to put phone in local mode and connect to software with usb the software frez... i have try on 3pc but same problem |
06-23-2011, 11:34 | #9 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | wzupfones, looks like something wrong with it. Try flash only MCU, should work after without problem. kmaxmax, can't say anything exactly now.. BR |
The Following User Says Thank You to Dzirt For This Useful Post: |
06-25-2011, 10:07 | #14 (permalink) |
Member: 751235 Status: Offline Sonork: 100.1662008 Thanks Meter: 526 | all is done thankx registered to: wzupfones Connect phone on selected interface... Core version : 1.20 , Rev : 4.0 Selected FlashSettings : Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm607__04.30.mcusw PPM : rm607__04.30.ppm_c CNT : rm607__04.30_002.image_c_ctv_uk_9f2x2 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" - just reinsert battery -> If flashing freeze - reinsert cable and try again --- Press phone's power button or insert charger! --- -> Phone not found.. -> Boot fail... Flashing failed... Core version : 1.20 , Rev : 4.0 Selected FlashSettings : Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm607__04.30.mcusw PPM : rm607__04.30.ppm_c CNT : rm607__04.30_002.image_c_ctv_uk_9f2x2 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" - just reinsert battery -> If flashing freeze - reinsert cable and try again --- Press phone's power button or insert charger! --- Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : XGOLD 213 2nd boot Ok, 01 2nd ready, AA Sending Algo Algo sent Ok BL : Quantum_Bootloader_10.37_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! ===Flashing [MCU]=== File : rm607__04.30.mcusw Image : rm607__04.30.mcusw_ebl_psi.fls Cert block found, sending.... Cert sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40040000 , Len : 0x00040000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40080000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40080000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 4/5 Erase , Start : 0x400A0000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:04 Write , Start : 0x400A0000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 5/5 Erase , Start : 0x40400000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:01:56 Write , Start : 0x40400000 , Len : 0x01780000 Flashing , wait ... Region flash done, time : 00:00:47 ===Flashing [PPM]=== File : rm607__04.30.ppm_c Image : package_c.ppm_ebl_psi.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41C00000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:17 Write , Start : 0x41C00000 , Len : 0x003B7638 Flashing , wait ... Region flash done, time : 00:00:04 ===Flashing [CNT]=== File : rm607__04.30_002.image_c_ctv_uk_9f2x2 Image : package_c_ctv_uk.image.fls Cert block found, sending.... Cert sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42200000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:03:50 Write , Start : 0x42200000 , Len : 0x00B60000 Flashing , wait ... Region flash done, time : 00:00:20 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:07 No write data, skip Flashing done! Total flash time : 00:07:33 Reboot phone now... Reading Phone Info.... Connected phone - C1-01 Software Info: V 04.30 25-01-11 RM-607 (c) Nokia IMEI: 353799043782317 PPM version : V 04.30 25-01-11 RM-607 (c) Nokia C Product code: 0596384 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 39 certs Data exist, skip certificate repair... AfterFlash operations done... Reconnect, wait... Done! Connect phone on selected interface... Elapsed: 00:08:10 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following User Says Thank You to THE GREAT ONE For This Useful Post: |
