06-23-2011, 08:05 | #1 (permalink) |
Freak Poster Join Date: Sep 2005 Location: India Age: 50
Member: 181287 Status: Offline Thanks Meter: 58 | Code Received Only 4 Digit from Infinity Job Started 2011-06-21 16:42:05 -100 sys_code_sl3 IMEI : 352021042096966 Code Received From Infinity : 0002 Job COMPLETED Pls Help Me Lost 100 Credit Last edited by Mohsin-*; 06-23-2011 at 11:46. Reason: Edit Detail |
06-23-2011, 10:19 | #2 (permalink) |
Product Supporter Join Date: Mar 2005 Location: in CPU
Member: 128745 Status: Offline Thanks Meter: 16,936 | This means you uploaded BAD JOB FILE TO SERVER Server processed your file several times and it failed We do not refund credit for bad files uploaded to server |
06-23-2011, 18:37 | #3 (permalink) |
Member: 181287 Status: Offline Thanks Meter: 58 | Infinity Best Read Data Incorrectly This is not our fault because infinty best read this file automatically so if file is bad there is no my fault. it is calculated infinity itself. there is bug in ur software. pls refund my credit |
The Following User Says Thank You to mobidoctor For This Useful Post: |
06-26-2011, 05:52 | #5 (permalink) |
Member: 181287 Status: Offline Thanks Meter: 58 | Here is Log Readed By Infinity Connecting to server... Server version: 0.2.700 Request Submited Credit left: 131 Create Log file for local calculation... File c:\InfinityBox\BEST\Local_calc\352021042096966.bcl created - Ok File c:\InfinityBox\BEST\Local_calc\ighashgpu_352021042 096966.bat created - Ok File c:\InfinityBox\BEST\Local_calc\oclHashcat_35202104 2096966.bat created - Ok Done! Check client version... Compatible: 1.20.0. or higer... Connecting to server... Server have 922 free slot(s) Upload Job procedure started... Phone Imei: 352021042096966 Checking locks... Checking locks... Conf key : 8000000000000000 Provider key : 5050200000000000 Provider : Singtel Optus-Cable + Wireless Optus;Australia Counters : Key 0 [3] , Fbus 0 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close ============================= LOCKS : Closed ============================= PA_SL3 phone detected... Key file exists, no need to read... Connecting to server... Server version: 0.2.700 Request Submited Credit left: 31 Done! BCL File Readed By Infinity Best [Log] imei=352021042096966 hash=EFA01CBDC025BAEB397CBC8E92DBD621884F5BD7ED506 B31953BA2CBB3FBDF3BBB0BADEE77D56230D996509A3F2ADEF AA765ED686FEA776E1A3DFDC580D05D7F23D7D16FBF4CAFD2B 8B0C817653B7C096A5428CA0CB5244E4F2C2CCE530F332B08E 752D2945705DC4F6BB9BF8EDD75CA6493FBC4D267199CF9D20 F198CDA1B3C73381D38E3F2AF684D187BB1EC3F8AEF10A8572 85424F76C098B556421E4A728 BCL File Readed By ATF [log] imei=352021042096966 hash=AB36334306413152B7850DBC2F8AD93B9D563250CF9D0 43D12CC0132A41CACBCFA23982542F25AE840D4D1B2FF95ED5 453F2C6B91793565C1B85208FCCDFEE9BBDB1430AF63E185C8 5C4B7F03993C84EEA1D81D7ACD2A82B2AEFD97D0D38E7C798B 38B2BC83DF5D7E5ECAEDF4BB42690F60889E48257D60791963 ECF1EF1CEC5256C9787DB29A364E9BFEB5601823635B176231 BB1B193A11342A23FF851C7C6 ticket=E119A4432F13B5C8E52AC89F365B74F4874CC61B |
06-26-2011, 07:41 | #7 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Dear Mr. mobidoctor. Please, do not post logs that we can see at our server. It will be much better if you will post here detailed information about phone (that is absent in server data). Thank you very much for your kind future explanations. |
06-26-2011, 12:26 | #8 (permalink) |
Member: 181287 Status: Offline Thanks Meter: 58 | Here is Full Info log about Phone card found: S/N 0356:0118 registered to: DrMobile Connect phone on selected interface... UFS S/N 44461 boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 7230 Software ver : V 06.90 26-02-10 RM-604 (c) Nokia IMEI : 352021042096966 Ape Ver : APE Var : APE ADSP: DSP Ver : ICPR91_10w04_1 APE Test: PPM : V 06.90 26-02-10 RM-598 (c) Nokia T CNT : Content: optus AU SL V 06.90 26-02-10 RM-604 (c) Nokia Product SN : HFD998292 Product code : 059B1L2 Base Prd.code: 0585700 Module code : 0204267 Long Prod.SN : 0 Hardware info======= HWID : 1000 Retu : 40 Tahvo : 00 Batery: 4660 mV Camera: CMT BT: 1673-46034 APE BT: APE HW: LCDVer: SEIKO RF ic : |Vapaus_5.1 | Mikki_1.1 Lock info =========== IMEI : 352021042096966 IMEI spNet : IMEI svNet : Conf key : 8000000000000000 Provider key : 5050200000000000 Provider : Singtel Optus-Cable + Wireless Optus;Australia Counters : Key 0 [3] , Fbus 0 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close ============================= LOCKS : Closed ============================= User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! |
06-26-2011, 12:33 | #9 (permalink) |
Member: 181287 Status: Offline Thanks Meter: 58 | this is the upload log Check client version... Compatible: 1.20.0. or higer... Upload Job procedure started... Phone Imei: 352021042096966 Checking locks... Checking locks... Conf key : 8000000000000000 Provider key : 5050200000000000 Provider : Singtel Optus-Cable + Wireless Optus;Australia Counters : Key 0 [3] , Fbus 0 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close ============================= LOCKS : Closed ============================= PA_SL3 phone detected... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600000001020C192102044100 CMT EM0 ID : 00001040 CMT EM1 ID : 00001030 CMT PUB ID : 31B00104EE0300494E828A4006C96753B870CA75 CMT MODE ID : 00 CMT R_HASH : 7B045400E1752022F9EB80B0DEA9C65D CMT ROM ID : 67E82268F29CEA60 CMT : Sending 2nd loader... Use : RAP3Gv4_2nd.fg rap= 31B00104EE0300494E828A4006C96753B870CA75 hash= 7B045400E1752022F9EB80B0DEA9C65D key= 692F81A57E17E968E60E9C03369A53A3B6CFCC44 Init Service mode... Wait... Key file updated... Connecting to server... Server version: 0.2.700 Request Submited Credit left: 31 Create Log file for local calculation... File c:\InfinityBox\BEST\Local_calc\352021042096966.bcl created - Ok File c:\InfinityBox\BEST\Local_calc\ighashgpu_352021042 096966.bat created - Ok File c:\InfinityBox\BEST\Local_calc\oclHashcat_35202104 2096966.bat created - Ok Done! |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
PIN1/PIN2 CODE | Jon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-26-2012 04:40 |
Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-27-2012 11:00 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
