02-06-2012, 11:08 | #16 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Inside Samsung Pocket Age: 40
Member: 489331 Status: Offline Thanks Meter: 1,141 | Phone found! Series 60 Device detected! read info... - Ok Processing Server SX4 Auth Checking SDD key... Check SD : Key is Ok Operating mode is OK, no need change... Connecting to server... Connect to server Ok, checking SX4 Server : Online, ver:1.04 , Infinity Team (c) 2011 SX4, processing Step #1 SX4, processing Step #2 SX4, processing Step #3 SX4 Result : Ok Upload PM checked Uploading RF/Battery tune to phone... Using : RM-774.pm Operating mode is OK, no need change... Field 1 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 4 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 13 write - Ok Record 15 write - Ok Record 16 write - Ok Record 17 write - Ok Record 18 write - Ok Record 19 write - Ok Record 22 write - Ok Record 26 write - Ok Record 27 write - Ok Record 28 write - Ok Record 29 write - Ok Record 30 write - Ok Record 31 write - Ok Record 32 write - Ok Record 33 write - Ok Record 35 write - Ok Record 36 write - Ok Record 38 write - Ok Record 39 write - Ok Record 40 write - Ok Record 41 write - Ok Record 43 write - Ok Record 44 write - Ok Record 45 write - Ok Field 309 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 7 write - Ok Record 17 write - Ok Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED - > Try different PM files or "Restore CCC/HWC" option Done! Elapsed: 00:00:01 Upload done Will Write CCC/HWC keys now... Using : RM-774.rpl CCC Data found! HWC Data found! Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 60490000FFFF7C40EBDAAD66AFAA6A77F3D7B646 ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 11.48.0 Processing RAWLOADER... FLIC : 006000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 11.48.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : FEB3BB7481D3E5D0EAC907335A4402A071493D53 ADL: Preparing for write certificates... Erase CCC... Ok Writing CCC... Ok Erase HWC... Ok Writing HWC... Ok ADL: Writing Flash certs done! ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot All done, disconneting... Done! Elapsed: 00:00:05 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 701 Software ver : V 79u_11w31.4 16-08-11 RM-774 (c) Nokia IMEI : 358272041329031 Ape Ver : 111.010.1009 APE Var : 111.010.1009111.010.1009.08.01111.010.1009.C00.01 APE ADSP: 256 DSP Ver : 104_11w30 APE Test: 0.037 PPM : CNT : Product SN : 0 Product code : Base Prd.code: Module code : Long Prod.SN : 0 Hardware info======= HWID : Retu : 40 Tahvo : 00 Batery: 3753 mV Camera: CMT BT: APE BT: HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. APE HW: 256 LCDVer: RF ic : Lock info =========== IMEI : 358272041329031 IMEI spNet : 3A 85 72 02 14 23 09 03 IMEI svNet : 33 85 72 02 14 23 09 03 F3 Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok SimLock status : Ok Security status : Ok PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Elapsed: 00:00:10 |
The Following User Says Thank You to raulka2003 For This Useful Post: |
02-10-2012, 15:34 | #24 (permalink) |
No Life Poster Join Date: Dec 2002 Location: TURKEY Age: 44
Member: 18442 Status: Offline Sonork: 111110 Thanks Meter: 622 | ı make fully earse with best tool after write rpl but not read phone securty test fail always Phone not found... CertWrite failed : phone was not bootup Connection/SW/HW problem, try bootup manually If phone bootup Ok - write only flex keys Phone disconected! Connect phone on selected interface... User ACCEPTED FULL ERASE Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 7A390000FFFF7C40E84BE69C542E459608512280 ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 11.48.0 Processing RAWLOADER... FLIC : 006000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 11.48.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : FEB3BB7481D3E5D0EAC907335A4402A071493D53 Reading NPC certificate... IMEI : xxxxx Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! |
02-10-2012, 15:34 | #25 (permalink) |
Member: 18442 Status: Offline Sonork: 111110 Thanks Meter: 622 | NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : D:\YEDEK PROGRAMLAR\BOXLAR\infinity\EXE\İnfinity BB5 Best Tool\1.37.1\Backup\Cert\358272040xxxxx7_CRT_2nd.rp l ADL: Preparing for erase... Full Erase started... Asic : CMT , Sub : NAND Erase Area 0x00000000-0x3FFFFFFF Erasing Ok , [0F] Erase done , time : 00:00:03 ADL: Erase done ADL: Close_Session Content: 000205000000000000FFFF00000000 ADL: Reboot Phone disconected! Connect phone on selected interface... Core version : 1.36 Rev : 1.3 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-774_111.030.0609_79u_prd.core.fpsx PPM : RM-774_111.030.0609_01.01_Euro_1_79u_prd.rofs2.fpsx PPM2 : RM-774_111.030.0609_C00.01_79u_prd.rofs3.fpsx CNT : RM-774_111.030.0609_U01.01_79u.uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 7A390000FFFF7C40E84BE69C542E459608512280 ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 11.48.0 Processing RAWLOADER... FLIC : 006000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 11.48.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : blank (Erased or HW failure) ADL: phone is in flash mode ===Flashing [MCU]=== Erase : Processing RM-774_111.030.0609_79u_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing RM-774_111.030.0609_79u_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [SOS+DECOMP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS+IVE3A] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 510 blocks TIME : Write time : 00:00:16 MCU Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [PPM]=== Erase : Processing RM-774_111.030.0609_01.01_Euro_1_79u_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-774_111.030.0609_01.01_Euro_1_79u_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 248 blocks TIME : Write time : 00:00:08 PPM Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [PPM2]=== Erase : Processing RM-774_111.030.0609_C00.01_79u_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-774_111.030.0609_C00.01_79u_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] CMT: Writing Hash CERT [SOS+IVE3B] Total writen 4 blocks TIME : Write time : 00:00:00 PPM Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [CNT]=== Erase : Processing RM-774_111.030.0609_U01.01_79u.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:02 Write : Processing RM-774_111.030.0609_U01.01_79u.uda.fpsx Total writen 966 blocks TIME : Write time : 00:00:37 CNT Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Flashing done! Total flash time : 00:01:06 Reboot phone now... Afterflash not selected, skip Done! Elapsed: 00:01:14 Connect phone on selected interface... Read Uniq key data started... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB PUBLIC ID: 7A390000FFFF7C40E84BE69C542E459608512280 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 Fetching data, wait... - > Reinsert cable and battery, press powerOn button again - > For X7, E7 - just waiting, near 1 minute - > When BEST start Search Phone - Press PowerOn if needed Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 7A390000FFFF7C40E84BE69C542E459608512280 ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 11.48.0 Processing RAWLOADER... FLIC : 006000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 11.48.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : FEB3BB7481D3E5D0EAC907335A4402A071493D53 ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Wait, reconneting... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 7A390000FFFF7C40E84BE69C542E459608512280 ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 11.48.0 Processing RAWLOADER... FLIC : 006000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 11.48.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : FEB3BB7481D3E5D0EAC907335A4402A071493D53 ADL: phone is in flash mode Reading NPC certificate... IMEI : 000000000000000 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! Will read flash content now... Flash IC Size : 1024 MB Trying read spr block , wait ... Get phone data... Spr read failed on acess error ADL: Close_Session ADL: Reboot Done!!! Connect phone on selected interface... Phone not found... Error, phone reboot not done #2 (Phone was not BootUp) rap= 7A390000FFFF7C40E84BE69C542E459608512280 hash= 3AB5DB70B45D23F1ADEEBB5734160706 key= C9698437C1F378CF9D9B1303C47CF93B09B9C002 - > You can insert data in "special.log" manually - > Or repeat procedure again Read fail...! |
02-10-2012, 15:34 | #26 (permalink) |
Member: 18442 Status: Offline Sonork: 111110 Thanks Meter: 622 | Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 7A390000FFFF7C40E84BE69C542E459608512280 ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 11.48.0 Processing RAWLOADER... FLIC : 006000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 11.48.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : FEB3BB7481D3E5D0EAC907335A4402A071493D53 ADL: phone is in flash mode Reading NPC certificate... IMEI : 000000000000000 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! Will read flash content now... Flash IC Size : 1024 MB Trying read spr block , wait ... Get phone data... Get flash data... Spr read failed on acess error User ACCEPTED FULL ERASE Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 7A390000FFFF7C40E84BE69C542E459608512280 ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 11.48.0 Processing RAWLOADER... FLIC : 006000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 11.48.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : FEB3BB7481D3E5D0EAC907335A4402A071493D53 Reading NPC certificate... IMEI : 000000000000000 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! ADL: Preparing for erase... Full Erase started... Asic : CMT , Sub : NAND Erase Area 0x00000000-0x3FFFFFFF Erasing Ok , [0F] Erase done , time : 00:00:03 ADL: Erase done ADL: Close_Session Content: 000205000000000000FFFF00000000 ADL: Reboot Phone disconected! Connect phone on selected interface... Core version : 1.36 Rev : 1.3 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-774_111.030.0609_79u_prd.core.fpsx PPM : RM-774_111.030.0609_01.01_Euro_1_79u_prd.rofs2.fpsx PPM2 : RM-774_111.030.0609_C00.01_79u_prd.rofs3.fpsx CNT : RM-774_111.030.0609_U01.01_79u.uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 7A390000FFFF7C40E84BE69C542E459608512280 ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 11.48.0 Processing RAWLOADER... FLIC : 006000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 11.48.0 Processing PASUBTOC ... Processing ALG ... Transmission type request fail [000000] -> Boot error... -> Boot fail... Flashing failed... Phone disconected! Connect phone on selected interface... Core version : 1.36 Rev : 1.3 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-774_111.030.0609_79u_prd.core.fpsx PPM : RM-774_111.030.0609_01.01_Euro_1_79u_prd.rofs2.fpsx PPM2 : RM-774_111.030.0609_C00.01_79u_prd.rofs3.fpsx CNT : RM-774_111.030.0609_U01.01_79u.uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 7A390000FFFF7C40E84BE69C542E459608512280 ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 11.48.0 Processing RAWLOADER... FLIC : 006000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 11.48.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : blank (Erased or HW failure) ADL: phone is in flash mode ===Flashing [MCU]=== Erase : Processing RM-774_111.030.0609_79u_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing RM-774_111.030.0609_79u_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [SOS+DECOMP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS+IVE3A] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 510 blocks TIME : Write time : 00:00:16 MCU Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [PPM]=== Erase : Processing RM-774_111.030.0609_01.01_Euro_1_79u_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-774_111.030.0609_01.01_Euro_1_79u_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 248 blocks TIME : Write time : 00:00:08 PPM Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [PPM2]=== Erase : Processing RM-774_111.030.0609_C00.01_79u_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-774_111.030.0609_C00.01_79u_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] CMT: Writing Hash CERT [SOS+IVE3B] Total writen 4 blocks TIME : Write time : 00:00:00 PPM Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [CNT]=== Erase : Processing RM-774_111.030.0609_U01.01_79u.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:02 Write : Processing RM-774_111.030.0609_U01.01_79u.uda.fpsx Total writen 966 blocks TIME : Write time : 00:00:36 CNT Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Flashing done! Total flash time : 00:01:06 Reboot phone now... Afterflash not selected, skip Done! Elapsed: 00:01:18 Connect phone on selected interface... Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) SimLock Data found! SimLock key found! SuperDongle Key found! CMLA key found! WMDRM key found! Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 7A390000FFFF7C40E84BE69C542E459608512280 ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 11.48.0 Processing RAWLOADER... FLIC : 006000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 11.48.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : FEB3BB7481D3E5D0EAC907335A4402A071493D53 ADL: Preparing for write certificates... Erase NPC... Ok Writing NPC... Ok Erase CCC... Ok Writing CCC... Ok Erase HWC... Ok Writing HWC... Ok ADL: Writing Flash certs done! ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Wait, reconneting... |
02-11-2012, 02:38 | #29 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Flash it : https://rapidshare.com/files/3474769...k2012_0037.rar Also i attached pm and rpl in archive. Flash as MCU eno. Get other 2 files , put them : pm to BEST/phdata/tune/ rpl to BEST/phdata/ccc_hwc/ Do Restore ccc/hwc Do local sx4 (sdd repair before) |
The Following User Says Thank You to Dzirt For This Useful Post: |
02-13-2012, 22:39 | #30 (permalink) | |
Member: 18442 Status: Offline Sonork: 111110 Thanks Meter: 622 | Quote:
MATE u wonderful without problem ALL OK very very thx ı very happy use and sell best tool 2x 701 OK ATF and MX key cant repair Last edited by BesTCooL; 02-13-2012 at 22:47. | |
