Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 02-06-2012, 11:08   #16 (permalink)
raulka2003's Avatar
Member: 489331
Thanks Meter: 1,141
Connect phone on selected interface...
Phone found!
Series 60 Device detected!
read info... - Ok
Processing Server SX4 Auth
Checking SDD key...
Check SD : Key is Ok
Operating mode is OK, no need change...
Connecting to server...
Connect to server Ok, checking
SX4 Server : Online, ver:1.04 , Infinity Team (c) 2011
SX4, processing Step #1
SX4, processing Step #2
SX4, processing Step #3
SX4 Result : Ok
Upload PM checked
Uploading RF/Battery tune to phone...
Using : RM-774.pm
Field 1
Record 0 write - Ok
Record 1 write - Ok
Record 2 write - Ok
Record 4 write - Ok
Record 6 write - Ok
Record 7 write - Ok
Record 8 write - Ok
Record 13 write - Ok
Record 15 write - Ok
Record 16 write - Ok
Record 17 write - Ok
Record 18 write - Ok
Record 19 write - Ok
Record 22 write - Ok
Record 26 write - Ok
Record 27 write - Ok
Record 28 write - Ok
Record 29 write - Ok
Record 30 write - Ok
Record 31 write - Ok
Record 32 write - Ok
Record 33 write - Ok
Record 35 write - Ok
Record 36 write - Ok
Record 38 write - Ok
Record 39 write - Ok
Record 40 write - Ok
Record 41 write - Ok
Record 43 write - Ok
Record 44 write - Ok
Record 45 write - Ok
Field 309
Record 0 write - Ok
Record 1 write - Ok
Record 2 write - Ok
Record 3 write - Ok
Record 4 write - Ok
Record 7 write - Ok
Check ST_SECURITY now...
Security status : ST_SECURITY => DAMAGED
- > Try different PM files or "Restore CCC/HWC" option
Done!
Elapsed: 00:00:01
Upload done
Will Write CCC/HWC keys now...
Using : RM-774.rpl
CCC Data found!
HWC Data found!
Connection opened successfully
Waiting for communication response...
[BB5 FLASH]: Bootrom Ok!
ASIC ID: 000000030000022600010007400C192103032108
CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB
EM0 ID: 00001040
EM1 ID: 00001030
PUBLIC ID: 60490000FFFF7C40EBDAAD66AFAA6A77F3D7B646
ASIC MODE ID: 00
ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706
ROM ID: 2CAC45E23BC33C8B
Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 11.48.0
Processing RAWLOADER...
FLIC : 006000EC
Req : XSR 1.6
Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 11.48.0
Processing PASUBTOC ...
Processing ALG ...
Boot Done!
TIME : Boot time : 00:00:03
Reopening the connection...
Waiting for response: 30
ADL: Check mode
Select ASIC [C900]
PAPUBkeys : FEB3BB7481D3E5D0EAC907335A4402A071493D53
ADL: Preparing for write certificates...
Erase CCC... Ok
Writing CCC... Ok
Erase HWC... Ok
Writing HWC... Ok
ADL: Writing Flash certs done!
ADL: Close_Session
Content: 000300000000010000000100000000
ADL: Reboot
All done, disconneting...
Done!
Elapsed: 00:00:05
Phone found!
read info... - Ok
Reading Phone Info....
Connected phone - Nokia 701
Software ver : V 79u_11w31.4 16-08-11 RM-774 (c) Nokia
IMEI : 358272041329031
Ape Ver : 111.010.1009
APE Var : 111.010.1009111.010.1009.08.01111.010.1009.C00.01
APE ADSP: 256
DSP Ver : 104_11w30
APE Test: 0.037
PPM :
CNT :
Product SN : 0
Product code :
Base Prd.code:
Module code :
Long Prod.SN : 0
Hardware info=======
HWID :
Retu : 40
Tahvo : 00
Batery: 3753 mV
Camera:
CMT BT:
APE BT: HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13.
APE HW: 256
LCDVer:
RF ic :
Lock info ===========
IMEI spNet : 3A 85 72 02 14 23 09 03
IMEI svNet : 33 85 72 02 14 23 09 03 F3
Conf key : 0000000000000000
Provider key : 2440700000000000
Provider : AT&T;U.S.A. (3650)
Counters : Key 0 [3] , Fbus 0 [10]
Blocks : 7
LOCK STATUS :
BLK : 1
Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open
BLK : 2
BLK : 3
BLK : 4
BLK : 5
BLK : 6
BLK : 7
LOCKS : All Open
CRT308 Backup Created
SDD key status : Ok
SimLock status : Ok
Security status : Ok
PA_SL3 phone , SP_CODE_LEN : 15
User code : Crypted
UserDataExLevel : Low [Gallery] , FullFlash method
Done!
Resetting selected items...
Check phone mode...
Phone in Local mode
Seting Test mode... wait...
Test mode set
Settings Full Factory Defaults...
Set OK!
Elapsed: 00:00:10
The Following User Says Thank You to raulka2003 For This Useful Post:
Old 02-06-2012, 11:12   #17 (permalink)
raulka2003's Avatar
Member: 489331
Thanks Meter: 1,141
BIG Thanks to Dzirt Best Team
Old 02-06-2012, 17:00   #18 (permalink)
BesTCooL's Avatar
Member: 18442
Sonork: 111110
Thanks Meter: 622
ı have same problem only nokia and restart how solve ?
Old 02-06-2012, 22:38   #19 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Same problem? You can exactly say it is SAME model or NOT?
Old 02-06-2012, 23:54   #20 (permalink)
BesTCooL's Avatar
Member: 18442
Sonork: 111110
Thanks Meter: 622
same model customer uplaod firmware after phone stuck nokia and reset always
Old 02-07-2012, 00:22   #21 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
Thanks Meter: 18,268
Hello
Flash Phone With Latest Firmware and Post here LOGS if face problem
Old 02-10-2012, 15:04   #22 (permalink)
BesTCooL's Avatar
Member: 18442
Sonork: 111110
Thanks Meter: 622
Unable to read SP Data..
SECURITY_TEST : FAILED
> Try SX4 "PM AUTH"
> Then Write PM 1 and 309
PHONE_MODE : TEST
DCC ID : NOT USED
Old 02-10-2012, 15:30   #23 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Better ask in ATF section about it.
Old 02-10-2012, 15:34   #24 (permalink)
BesTCooL's Avatar
Member: 18442
Sonork: 111110
Thanks Meter: 622
ı make fully earse with best tool after write rpl but not read phone securty test fail always
Phone not found...
CertWrite failed : phone was not bootup
Connection/SW/HW problem, try bootup manually
If phone bootup Ok - write only flex keys
Phone disconected!
User ACCEPTED FULL ERASE
Dead Mode is Selected
Waiting for USB device...
--- Insert cable and charger or press phone's power button! ---
EM0 ID: 00001040
EM1 ID: 00001030
PUBLIC ID: 7A390000FFFF7C40E84BE69C542E459608512280
ASIC MODE ID: 00
FLIC : 006000EC
Req : XSR 1.6
Processing ALG ...
Boot Done!
TIME : Boot time : 00:00:02
Waiting for response: 29
ADL: Check mode
Select ASIC [C900]
Reading NPC certificate...
IMEI : xxxxx
Reading CCC certificate...
Reading HWC certificate...
Reading R&D certificate...
Reading VARIANT certificate...
Reading PARTNERC certificate...
Reading MDM_KEYS certificate...
Cert Read done!
Old 02-10-2012, 15:34   #25 (permalink)
BesTCooL's Avatar
Member: 18442
Sonork: 111110
Thanks Meter: 622
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : D:\YEDEK PROGRAMLAR\BOXLAR\infinity\EXE\İnfinity BB5 Best Tool\1.37.1\Backup\Cert\358272040xxxxx7_CRT_2nd.rp l
ADL: Preparing for erase...
Full Erase started...
Asic : CMT , Sub : NAND
Erase Area 0x00000000-0x3FFFFFFF
Erasing Ok , [0F]
Erase done , time : 00:00:03
ADL: Erase done
ADL: Close_Session
Content: 000205000000000000FFFF00000000
ADL: Reboot
Phone disconected!
Core version : 1.36 Rev : 1.3
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : RM-774_111.030.0609_79u_prd.core.fpsx
PPM : RM-774_111.030.0609_01.01_Euro_1_79u_prd.rofs2.fpsx
PPM2 : RM-774_111.030.0609_C00.01_79u_prd.rofs3.fpsx
CNT : RM-774_111.030.0609_U01.01_79u.uda.fpsx
Flashing phone now...
Check files done...
-> SWversion check skipped : Dead mode selected
EM0 ID: 00001040
EM1 ID: 00001030
ASIC MODE ID: 00
FLIC : 006000EC
Req : XSR 1.6
Processing ALG ...
Boot Done!
ADL: Check mode
Select ASIC [C900]
PAPUBkeys : blank (Erased or HW failure)
ADL: phone is in flash mode
===Flashing [MCU]===
Erase : Processing RM-774_111.030.0609_79u_prd.core.fpsx
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
TIME : Erase time : 00:00:01
Write : Processing RM-774_111.030.0609_79u_prd.core.fpsx
CMT: Writing Hash CERT [ADA]
CMT: Writing Hash CERT [KEYS]
CMT: Writing Hash CERT [PRIMAPP]
CMT: Writing Hash CERT [RAP3NAND]
CMT: Writing Hash CERT [SOS+PMML]
CMT: Writing Hash CERT [SOS+DECOMP]
CMT: Writing Hash CERT [PASUBTOC]
CMT: Writing Hash CERT [PAPUBKEYS]
CMT: Writing Hash CERT [GENIO_INIT]
CMT: Writing Hash CERT [SOS+IVE3A]
CMT: Writing Hash CERT [SOS*UPDAPP]
CMT: Writing Hash CERT [SOS*DSP0]
CMT: Writing Hash CERT [LDSP]
CMT: Writing Hash CERT [SOS*ISASW]
CMT: Writing Hash CERT [SOS+CORE]
CMT: Writing Hash CERT [SOS+ROFS1]
Total writen 510 blocks
TIME : Write time : 00:00:16
MCU Write done
ADL: Request programm status
NAND status : 00000000 / 00000000 / 00000000
===Flashing [PPM]===
Erase : Processing RM-774_111.030.0609_01.01_Euro_1_79u_prd.rofs2.fpsx
Erasing....
Erasing Ok...
TIME : Erase time : 00:00:00
Write : Processing RM-774_111.030.0609_01.01_Euro_1_79u_prd.rofs2.fpsx
CMT: Writing Hash CERT [SOS+ROFS2]
Total writen 248 blocks
TIME : Write time : 00:00:08
PPM Write done
===Flashing [PPM2]===
Erase : Processing RM-774_111.030.0609_C00.01_79u_prd.rofs3.fpsx
Erasing....
Erasing Ok...
Write : Processing RM-774_111.030.0609_C00.01_79u_prd.rofs3.fpsx
CMT: Writing Hash CERT [SOS+ROFS3]
CMT: Writing Hash CERT [SOS+IVE3B]
Total writen 4 blocks
TIME : Write time : 00:00:00
PPM Write done
===Flashing [CNT]===
Erase : Processing RM-774_111.030.0609_U01.01_79u.uda.fpsx
Erasing....
Erasing Ok...
TIME : Erase time : 00:00:02
Write : Processing RM-774_111.030.0609_U01.01_79u.uda.fpsx
Total writen 966 blocks
TIME : Write time : 00:00:37
CNT Write done
ADL: Close_Session
Content: 000300000000000000000000000000
ADL: Reboot
Flashing done!
Total flash time : 00:01:06
Reboot phone now...
Afterflash not selected, skip
Done!
Elapsed: 00:01:14
Read Uniq key data started...
Fetching data, wait...
- > Reinsert cable and battery, press powerOn button again
- > For X7, E7 - just waiting, near 1 minute
- > When BEST start Search Phone - Press PowerOn if needed
EM0 ID: 00001040
EM1 ID: 00001030
ASIC MODE ID: 00
FLIC : 006000EC
Req : XSR 1.6
Processing ALG ...
Boot Done!
ADL: Check mode
Select ASIC [C900]
ADL: Close_Session
ADL: Reboot
Wait, reconneting...
EM0 ID: 00001040
EM1 ID: 00001030
ASIC MODE ID: 00
FLIC : 006000EC
Req : XSR 1.6
Processing ALG ...
Boot Done!
TIME : Boot time : 00:00:01
ADL: Check mode
Select ASIC [C900]
IMEI : 000000000000000
Cert Read done!
Will read flash content now...
Flash IC Size : 1024 MB
Trying read spr block , wait ...
Get phone data...
Spr read failed on acess error
ADL: Close_Session
ADL: Reboot
Done!!!
Phone not found...
Error, phone reboot not done #2 (Phone was not BootUp)
rap= 7A390000FFFF7C40E84BE69C542E459608512280
hash= 3AB5DB70B45D23F1ADEEBB5734160706
key= C9698437C1F378CF9D9B1303C47CF93B09B9C002
- > You can insert data in "special.log" manually
- > Or repeat procedure again
Read fail...!
Old 02-10-2012, 15:34   #26 (permalink)
BesTCooL's Avatar
Member: 18442
Sonork: 111110
Thanks Meter: 622
EM0 ID: 00001040
EM1 ID: 00001030
ASIC MODE ID: 00
FLIC : 006000EC
Req : XSR 1.6
Processing ALG ...
Boot Done!
ADL: Check mode
Select ASIC [C900]
Cert Read done!
Get phone data...
Get flash data...
EM0 ID: 00001040
EM1 ID: 00001030
ASIC MODE ID: 00
FLIC : 006000EC
Req : XSR 1.6
Processing ALG ...
Boot Done!
ADL: Check mode
Select ASIC [C900]
Cert Read done!
Erasing Ok , [0F]
ADL: Erase done
ADL: Close_Session
ADL: Reboot
Phone disconected!
Check files done...
EM0 ID: 00001040
EM1 ID: 00001030
ASIC MODE ID: 00
FLIC : 006000EC
Req : XSR 1.6
Processing ALG ...
Transmission type request fail [000000]
-> Boot error...
-> Boot fail...
Flashing failed...
Phone disconected!
Check files done...
EM0 ID: 00001040
EM1 ID: 00001030
ASIC MODE ID: 00
FLIC : 006000EC
Req : XSR 1.6
Processing ALG ...
Boot Done!
ADL: Check mode
Select ASIC [C900]
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
MCU Write done
Erasing....
Erasing Ok...
PPM Write done
Erasing....
Erasing Ok...
PPM Write done
Erasing....
Erasing Ok...
TIME : Write time : 00:00:36
CNT Write done
ADL: Close_Session
ADL: Reboot
Flashing done!
Reboot phone now...
Done!
Elapsed: 00:01:18
Will Write RPL keys now...
Check RPL file...
NPC Data found! (CMT)
CCC Data found! (CMT)
HWC Data found! (CMT)
SimLock Data found!
SimLock key found!
SuperDongle Key found!
CMLA key found!
WMDRM key found!
EM0 ID: 00001040
EM1 ID: 00001030
ASIC MODE ID: 00
FLIC : 006000EC
Req : XSR 1.6
Processing ALG ...
Boot Done!
ADL: Check mode
Select ASIC [C900]
Erase NPC... Ok
Writing NPC... Ok
Erase CCC... Ok
Writing CCC... Ok
Erase HWC... Ok
Writing HWC... Ok
ADL: Close_Session
ADL: Reboot
Old 02-10-2012, 18:03   #27 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
and? What now? I see only phone killing.
Old 02-10-2012, 18:25   #28 (permalink)
BesTCooL's Avatar
Member: 18442
Sonork: 111110
Thanks Meter: 622
yes dead phone always security failed no local mode via atf fbus read wiathut problem but securty problem not solve
Old 02-11-2012, 02:38   #29 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Flash it :
https://rapidshare.com/files/3474769...k2012_0037.rar
Also i attached pm and rpl in archive.
Flash as MCU eno.
Get other 2 files , put them :
pm to BEST/phdata/tune/
rpl to BEST/phdata/ccc_hwc/
Do Restore ccc/hwc
Do local sx4 (sdd repair before)
The Following User Says Thank You to Dzirt For This Useful Post:
Old 02-13-2012, 22:39   #30 (permalink)
BesTCooL's Avatar
Member: 18442
Sonork: 111110
Thanks Meter: 622
Originally Posted by Dzirt View Post
Flash it :
Flash as MCU eno.
Do Restore ccc/hwc
MATE u wonderful without problem ALL OK very very thx ı very happy use and sell best tool 2x 701 OK
ATF and MX key cant repair
Page generated in 0.30885 seconds with 9 queries
