06-10-2011, 14:32 | #7 (permalink) |
No Life Poster Join Date: Mar 2008
Member: 729558 Status: Offline Thanks Meter: 45 | http://forum.gsmhosting.com/vbb/7402376-post3.html You follow the steps but ihave mobile 1112 rh 93 Mobile working flash vergion 7.2 when flash mcucfgnot done err (ff) , break error 2nd boot, chek conection -hw error while flashing(, switch jaf fbus..... errorr powring on fbus mode set ok connect phone on select interface NB mobile good worked |
06-11-2011, 13:46 | #9 (permalink) | |
No Life Poster Join Date: Jul 2008
Member: 811779 Status: Offline Thanks Meter: 242 | Quote:
Code: Connect phone on selected interface... Opening Connection... Device Location: 00000012 Connect Ok! Initializing Connection... JAF Firmware: 01.B6 JAF S/N ODJAF000 boot - Ok Switch jaf to FBUS... FbusMode set Ok Connect phone on selected interface... Phone found! Series 40 Device detected! [DCT4+] read info... - Ok Reading Phone Info.... SW ver : V 6.00 24-10-06 RH-93 (c) NMP IMEI : 353645018520432 PPM : V 6.00 24-10-06 RH-93 (c) NMP IA DSP Ver : 5w06.v34 PCode : 0541331 BPCode : 0536354 HWID : 0526 LCDVer : INLUX:MYKS01 IMEI : 353645018520432 Sl Conf : 001-01-00000000000 Sl Prof : 800000000001000-2 Sl Aux : 00020000 Hw Sig : 89FC27C2C1A4717D Provider : Default Test Operator Lock info: Block 1 L1:Close; L2:Close; L3:Close; L4:Close; L5:Close; Block 2 L1:Close; L2:Close; L3:Close; L4:Close; L5:Close; Block 3 L1:Close; L2:Close; L3:Close; L4:Close; L5:Close; Block 4 L1:Close; L2:Close; L3:Close; L4:Close; L5:Close; Block 5 L1:Close; L2:Close; L3:Close; L4:Close; L5:Close; Block 6 L1:Close; L2:Close; L3:Close; L4:Close; L5:Close; Block 7 L1:Close; L2:Close; L3:Close; L4:Close; L5:Close; Done! Code: Core version : 1.22 , Rev : 4.5 Selected FlashSettings : Files Set for Flashing : MCU : rh93_06.930 PPM : rh93_06.93ia CNT : rh930_nai6.93ia ===Flashing [MCU]=== Processing : rh93_06.930 1st boot Ok , UPP : 2201 Sending 2nd... Use : u_2nd.fia 2nd patched Ok 2nd boot sent MCUcfg Ok , 03 FL [01] : ID 00EC2268 , rev 00000121 , SAMSUNG , Not In Base FL [02] : ID 00000001 , rev 00000000 , EMPTY , Not Used FLCNT : AD7EB61A1BBE0BE27D586BE4DBEE6514 Sending Algo... Use : u_amd.fia Algo patched Ok Algorithm sent Claudia Ok MSID : 84F2DF4D264F4C2B6313E674E5BC DMSID : 3E4EBAE9004A27E6AA000000 EFAID : E7C8152AB84E35F4CE4CB50A Set FAID Ok Erase : Processing rh93_06.930 Erasing area 0x01000000 - 0x0100FFFF Erasing area 0x01010000 - 0x013BFFFF Erasing area 0x013C0000 - 0x013EFFFF Erasing area 0x017C0000 - 0x017EFFFF Erasing area 0x01FC0000 - 0x01FEFFFF Erase done , in 00:01:43 Write : Processing rh93_06.930 Init Write Mode Ok Write done , in 00:00:11 Perm.Data restored Ok MCU flash done ===Flashing [PPM]=== Processing : rh93_06.93ia 1st boot Ok , UPP : 2201 Sending 2nd... Use : u_2nd.fia 2nd patched Ok 2nd boot sent MCUcfg Ok , 03 FL [01] : ID 00EC2268 , rev 00000121 , SAMSUNG , Not In Base FL [02] : ID 00000001 , rev 00000000 , EMPTY , Not Used FLCNT : AD7EB61A1BBE0BE27D586BE4DBEE6514 Sending Algo... Use : u_amd.fia Algo patched Ok Algorithm sent Claudia Ok MSID : 84C29797C80406890E79FF89BB66 DMSID : 3E4EBAE9004A27E6A8000000 EFAID : 6F62FC0E6C12D3D323453162 Set FAID Ok Erase : Processing rh93_06.93ia Erasing area 0x011E0000 - 0x011EFFFF Erasing area 0x011F0000 - 0x0137FFFF Erase done , in 00:00:39 Write : Processing rh93_06.93ia Init Write Mode Ok Write done , in 00:00:07 Perm.Data restored Ok PPM flash done ===Flashing [CNT]=== Processing : rh930_nai6.93ia 1st boot Ok , UPP : 2201 Sending 2nd... Use : u_2nd.fia 2nd patched Ok 2nd boot sent MCUcfg Ok , 03 FL [01] : ID 00EC2268 , rev 00000121 , SAMSUNG , Not In Base FL [02] : ID 00000001 , rev 00000000 , EMPTY , Not Used FLCNT : AD7EB61A1BBE0BE27D586BE4DBEE6514 Sending Algo... Use : u_amd.fia Algo patched Ok Algorithm sent Claudia Ok MSID : 84C29797C80406890E79FF89BB66 DMSID : 3E4EBAE9004A27E6A8000000 EFAID : 6F62FC0E6C12D3D323453162 Set FAID Ok Erase : Processing rh930_nai6.93ia Erasing area 0x01380000 - 0x013BFFFF Erase done , in 00:00:03 Write : Processing rh930_nai6.93ia Init Write Mode Ok Write done , in 00:00:01 Perm.Data restored Ok CNT flash done Switch jaf to FBUS... FbusMode set Ok Phone connected Reading Phone Info.... Software Info: V 6.93 10-08-07 RH-93 (c) NMP IMEI: 353645018520432 PPM version : V 6.00 24-10-06 RH-93 (c) NMP IA Product code: 0541331 Flashing done Connect phone on selected interface... Phone found! Series 40 Device detected! [DCT4+] read info... - Ok Read and Check phone data... Checking bus... DCT4 mode selected 1st boot Ok , UPP : 2201 Sending 2nd... Use : u_2nd.fia 2nd patched Ok 2nd boot sent MCUcfg Ok , 03 FL [01] : ID 00EC2268 , rev 00000121 , SAMSUNG , Not In Base FL [02] : ID 00000001 , rev 00000000 , EMPTY , Not Used FLCNT : AD7EB61A1BBE0BE27D586BE4DBEE6514 Sending Algo... Use : u_amd.fia Algo patched Ok Algorithm sent MSID : 8444C3D5E7EFE412C2D787D89447 DMSID : 17CABAE9004A27E6A8000000 EFAID : 228498EBC63E8B6BD314307B Set FAID Ok Switch jaf to FBUS... FbusMode set Ok Connect phone on selected interface... Phone found! Series 40 Device detected! [DCT4+] read info... - Ok Reading Phone Info.... SW ver : V 6.93 10-08-07 RH-93 (c) NMP IMEI : 353645018520432 PPM : V 6.93 10-08-07 RH-93 (c) NMP IA DSP Ver : 5w06.v34 PCode : 0541331 BPCode : 0536354 HWID : 0526 LCDVer : INLX:MYKSv01 ST7506 IMEI : 353645018520432 Sl Conf : 001-01-00000000000 Sl Prof : 800000000001000-2 Sl Aux : 00024C58 Hw Sig : 89FC27C2C1A4717D Provider : Default Test Operator Lock info: Block 1 L1:Close; L2:Close; L3:Close; L4:Close; L5:Close; Block 2 L1:Close; L2:Close; L3:Close; L4:Close; L5:Close; Block 3 L1:Close; L2:Close; L3:Close; L4:Close; L5:Close; Block 4 L1:Close; L2:Close; L3:Close; L4:Close; L5:Close; Block 5 L1:Close; L2:Close; L3:Close; L4:Close; L5:Close; Block 6 L1:Close; L2:Close; L3:Close; L4:Close; L5:Close; Block 7 L1:Close; L2:Close; L3:Close; L4:Close; L5:Close; Done! Phone disconected! Connect phone on selected interface... | |
