07-01-2011, 20:14 | #1 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Bhumi Sang Mpu Aryya Wiraraja.
Member: 616567 Status: Offline Thanks Meter: 187 | help this Error : BOX FW : 01.B1 NOT SUPPORT Opening Connection... Device Location: 00000011 Connect Ok! Initializing Connection... JAF Firmware: 01.B1 JAF S/N ODJAF000 boot - Ok Switch jaf to FBUS... FbusMode set Ok Connect phone on selected interface... Read and Check phone data... Checking BUS... Switch jaf to FlashMode... FlashMode set Ok Booting phone... BOOT 1ST : C0 CMT part info : CMT ASICID : 000000030000022600010007600C192102031104 CMT EM0 ID : 00001051 CMT EM1 ID : 00001060 CMT PUB ID : 0D800011BEA40344B6173F9DC295AAD1D10B0827 CMT MODE ID : 00 CMT R_HASH : 916F75217F32081248B15C38DFC8E81B CMT ROM ID : E693EF0DAC22615B Error : BOX FW : 01.B1 NOT SUPPORT NEW PROTOCOL Upgrade to 1.B4 or later ... Switch jaf to FBUS... FbusMode set Ok Connect phone on selected interface... Connect phone on selected interface... Core version : 1.23 , Rev : 4.8 Selected FlashSettings : FullFlash Files Set for Flashing : MCU : rm639__06.00.mcusw PPM : rm639__06.00.ppm_x CNT : rm639__06.00.image_x_0598221_006 Checking BUS... Switch jaf to FlashMode... FlashMode set Ok Booting phone... BOOT 1ST : C0 CMT part info : CMT ASICID : 000000030000022600010007600C192102031104 CMT EM0 ID : 00001051 CMT EM1 ID : 00001060 CMT PUB ID : 0D800011BEA40344B6173F9DC295AAD1D10B0827 CMT MODE ID : 00 CMT R_HASH : 916F75217F32081248B15C38DFC8E81B CMT ROM ID : E693EF0DAC22615B Error : BOX FW : 01.B1 NOT SUPPORT NEW PROTOCOL Upgrade to 1.B4 or later ... Switch jaf to FBUS... FbusMode set Ok Connect phone on selected interface... |
07-01-2011, 21:14 | #2 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | hello here solution in ur Posted logs Quote:
The Following User Says Thank You to Mohsin-* For This Useful Post: |
07-01-2011, 21:35 | #3 (permalink) |
Member: 616567 Status: Offline Thanks Meter: 187 | thanks. Code: card found: S/N *******:rolleyes: Connect phone on selected interface... Opening Connection... Device Location: 00000011 Connect Ok! Initializing Connection... JAF Firmware: 01.B4 Authentificate JAF BOX... TEA Authentication Completed... JAF S/N ODJAF000 boot - Ok Switch jaf to FBUS... FbusMode set Ok Connect phone on selected interface... Read and Check phone data... Checking BUS... Switch jaf to FlashMode... FlashMode set Ok Booting phone... BOOT 1ST : C0 CMT part info : CMT ASICID : 000000030000022600010007600C192102031104 CMT EM0 ID : 00001051 CMT EM1 ID : 00001060 CMT PUB ID : 0D800011BEA40344B6173F9DC295AAD1D10B0827 CMT MODE ID : 00 CMT R_HASH : 916F75217F32081248B15C38DFC8E81B CMT ROM ID : E693EF0DAC22615B Change Protocol : NEW Using NEW Flashing Protocol CMT : Sending 2nd loader... Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 9.48.0 CMT Loader sent, Boot Ok Trans Req : 32 bit, DualLine, Set : 32 bit, DualLine CMT Flash ID : 003000EC < SAMSUNG [SEC] => K5W1G13ACB FLIC : 003000EC , NAND , CMT Sending Algo... Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 9.48.0 Finalize done, Algo sent! Trans Req : 32 bit, DualLine, Set : 32 bit, DualLine PapubKeysReq : 23B57C26A0C7A9C34544727AA1D2FC8F3265329C9A Boot done! Switch jaf to FBUS... FbusMode set Ok Phone not found :( Connect phone on selected interface... Connect phone on selected interface... Core version : 1.23 , Rev : 4.8 Selected FlashSettings : FullFlash Files Set for Flashing : MCU : rm639__06.00.mcusw PPM : rm639__06.00.ppm_x CNT : rm639__06.00.image_x_0598213_008 Checking BUS... Switch jaf to FlashMode... FlashMode set Ok Booting phone... BOOT 1ST : C0 CMT part info : CMT ASICID : 000000030000022600010007600C192102031104 CMT EM0 ID : 00001051 CMT EM1 ID : 00001060 CMT PUB ID : 0D800011BEA40344B6173F9DC295AAD1D10B0827 CMT MODE ID : 00 CMT R_HASH : 916F75217F32081248B15C38DFC8E81B CMT ROM ID : E693EF0DAC22615B Change Protocol : NEW Using NEW Flashing Protocol CMT : Sending 2nd loader... Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 9.48.0 CMT Loader sent, Boot Ok Trans Req : 32 bit, DualLine, Set : 32 bit, DualLine CMT Flash ID : 003000EC < SAMSUNG [SEC] => K5W1G13ACB FLIC : 003000EC , NAND , CMT Sending Algo... Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 9.48.0 Finalize done, Algo sent! Trans Req : 32 bit, DualLine, Set : 32 bit, DualLine PapubKeysReq : 23B57C26A0C7A9C34544727AA1D2FC8F3265329C9A Boot done! CMT : Read NPC certificate... IMEI : 355963041989302 CMT : Read CCC certificate... CMT : Read HWC certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\355963041989302_CRT_2nd.rpl Checking BUS... Switch jaf to FlashMode... FlashMode set Ok Booting phone... BOOT 1ST : C0 CMT part info : CMT ASICID : 000000030000022600010007600C192102031104 CMT EM0 ID : 00001051 CMT EM1 ID : 00001060 CMT PUB ID : 0D800011BEA40344B6173F9DC295AAD1D10B0827 CMT MODE ID : 00 CMT R_HASH : 916F75217F32081248B15C38DFC8E81B CMT ROM ID : E693EF0DAC22615B Change Protocol : NEW Using NEW Flashing Protocol CMT : Sending 2nd loader... Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 9.48.0 CMT Loader sent, Boot Ok Trans Req : 32 bit, DualLine, Set : 32 bit, DualLine CMT Flash ID : 003000EC < SAMSUNG [SEC] => K5W1G13ACB FLIC : 003000EC , NAND , CMT Sending Algo... Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 9.48.0 Finalize done, Algo sent! Trans Req : 32 bit, DualLine, Set : 32 bit, DualLine PapubKeysReq : 23B57C26A0C7A9C34544727AA1D2FC8F3265329C9A Boot done! SC : StoreCert Ok Partitioning.... Partitioning Ok... Erase : Processing rm639__06.00.mcusw Init Erase Mode Ok Found 4 data types Erasing Data.... Erase area : 0x00020000 - 0x000203FF , CMT , NAND Erase area : 0x00060000 - 0x0009FFFF , CMT , NAND Erase area : 0x000A0000 - 0x0041FFFF , CMT , NAND Erase area : 0x00420000 - 0x0069FFFF , CMT , NAND Erase area : 0x006A0000 - 0x006DFFFF , CMT , NAND Erase area : 0x006E0000 - 0x0123FFFF , CMT , NAND Erase area : 0x02060000 - 0x020BFFFF , CMT , NAND Erase area : 0x02CC0000 - 0x0333FFFF , CMT , NAND Erase area : 0x07540000 - 0x07B3FFFF , CMT , NAND Erase area : 0x01240000 - 0x0205FFFF , CMT , NAND Erase Ok... Erasing Partition.... Partition 0x08 Erase Ok... Erasing Partition.... Partition 0x0A Erase Ok... Erasing Partition.... Partition 0x0B Erase Ok... TIME : Erase time : 00:00:00 Write : Processing rm639__06.00.mcusw Init Write Mode Ok CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] Total writen 276 blocks TIME : Write time : 00:02:31 PrReq : NAND , 000300000000010000000100000000 Partitioning.... Partitioning Ok... Erase : Processing rm639__06.00.ppm_x Init Erase Mode Ok Found 1 data types Erasing Data.... Erase area : 0x020C0000 - 0x02CBFFFF , CMT , NAND Erase Ok... TIME : Erase time : 00:00:00 Write : Processing rm639__06.00.ppm_x Init Write Mode Ok Total writen 70 blocks TIME : Write time : 00:00:43 PrReq : NAND , 000300000000010000000100000000 ConvertImage: Processing rm639__06.00.image_x_0598213_008 ConvertImage: Page Size is 128K, no need convert Partitioning.... Partitioning Ok... Erase : Processing rm639__06.00.image_x_0598213_008 Init Erase Mode Ok Found 2 data types Erasing Data.... Erase area : 0x03340000 - 0x0753FFFF , CMT , NAND Erase Ok... Erasing Partition.... Partition 0x08 Erase Ok... TIME : Erase time : 00:00:01 Write : Processing rm639__06.00.image_x_0598213_008 Init Write Mode Ok Total writen 276 blocks TIME : Write time : 00:02:43 PrReq : NAND , 000300000000010000000100000000 Switch jaf to FBUS... FbusMode set Ok Phone not found :( Flashing done Connect phone on selected interface... but phone is keep blinking sir, what must i do now ? |
07-02-2011, 10:29 | #5 (permalink) |
Member: 616567 Status: Offline Thanks Meter: 187 | ok i`ll try.... Code: card found: S/N 21XXXXXXX8 registered to: sensoooorrrrrrr Connect phone on selected interface... Connect phone on selected interface... Core version : 1.18 , Rev : 3.0 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm639__06.00.mcusw PPM : rm639__06.00.ppm_x CNT : rm639__06.00.image_x_0598213_008 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102031104 EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 0D800011BEA40344B6173F9DC295AAD1D10B0827 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 11.4.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 11.4.0 Transmission type request fail [000000] -> Boot error... :( -> Boot fail... Flashing failed... Phone disconected! Connect phone on selected interface... Core version : 1.18 , Rev : 3.0 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm639__06.00.mcusw PPM : rm639__06.00.ppm_x CNT : rm639__06.00.image_x_0598213_008 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102031104 EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 0D800011BEA40344B6173F9DC295AAD1D10B0827 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 11.4.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 11.4.0 Boot Done! :) TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] ADL: phone is in flash mode ===Flashing [MCU]=== Erase : Processing rm639__06.00.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm639__06.00.mcusw CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] Total writen 264 blocks TIME : Write time : 00:00:05 MCU Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [PPM]=== Erase : Processing rm639__06.00.ppm_x Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm639__06.00.ppm_x Total writen 70 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [CNT]=== Erase : Processing rm639__06.00.image_x_0598213_008 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm639__06.00.image_x_0598213_008 Total writen 276 blocks TIME : Write time : 00:00:06 CNT Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Flashing done! Total flash time : 00:00:15 Reboot phone now... card found: S/N 2140:0118 registered to: abrakadabra-service Connect phone on selected interface... Connect phone on selected interface... Core version : 1.18 , Rev : 3.0 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm639__06.00.mcusw PPM : rm639__06.00.ppm_x CNT : rm639__06.00.image_x_0598213_008 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102031104 EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 0D800011BEA40344B6173F9DC295AAD1D10B0827 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 11.4.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 11.4.0 Transmission type request fail [000000] -> Boot error... :( -> Boot fail... Flashing failed... Phone disconected! Connect phone on selected interface... Core version : 1.18 , Rev : 3.0 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm639__06.00.mcusw PPM : rm639__06.00.ppm_x CNT : rm639__06.00.image_x_0598213_008 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102031104 EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 0D800011BEA40344B6173F9DC295AAD1D10B0827 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 11.4.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 11.4.0 Boot Done! :) TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] ADL: phone is in flash mode ===Flashing [MCU]=== Erase : Processing rm639__06.00.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm639__06.00.mcusw CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] Total writen 264 blocks TIME : Write time : 00:00:05 MCU Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [PPM]=== Erase : Processing rm639__06.00.ppm_x Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm639__06.00.ppm_x Total writen 70 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [CNT]=== Erase : Processing rm639__06.00.image_x_0598213_008 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm639__06.00.image_x_0598213_008 Total writen 276 blocks TIME : Write time : 00:00:06 CNT Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Flashing done! Total flash time : 00:00:15 Reboot phone now... -> Flashing Failed! :( Maybee HW error, or Downgrade try???! Anyway - try reinsert battery and PowerUp phone manualy Connect phone on selected interface... Done! Elapsed: 00:02:16 Connect phone on selected interface... Core version : 1.18 , Rev : 3.0 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm639__06.00.mcusw PPM : rm639__06.00.ppm_x CNT : rm639__06.00.image_x_0598213_008 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102031104 EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 0D800011BEA40344B6173F9DC295AAD1D10B0827 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 11.4.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 11.4.0 Boot Done! :) TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] ADL: phone is in flash mode ===Flashing [MCU]=== Erase : Processing rm639__06.00.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm639__06.00.mcusw CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] Total writen 264 blocks TIME : Write time : 00:00:04 MCU Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [PPM]=== Erase : Processing rm639__06.00.ppm_x Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm639__06.00.ppm_x Total writen 70 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [CNT]=== Erase : Processing rm639__06.00.image_x_0598213_008 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm639__06.00.image_x_0598213_008 Total writen 276 blocks TIME : Write time : 00:00:06 CNT Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Flashing done! Total flash time : 00:00:14 Reboot phone now... -> Flashing Failed! :( Maybee HW error, or Downgrade try???! Anyway - try reinsert battery and PowerUp phone manualy Connect phone on selected interface... Done! Elapsed: 00:02:18 Connect phone on selected interface... still blinking sir, any solutions???? |
07-02-2011, 13:19 | #7 (permalink) | |
Member: 616567 Status: Offline Thanks Meter: 187 | Quote:
card found: S/N sensoorr registered to: sensoorr Connect phone on selected interface... Opening Connection... Device Location: 00000011 Connect Ok! Initializing Connection... JAF Firmware: 01.B4 Authentificate JAF BOX... TEA Authentication Completed... JAF S/N ODTF7M0G boot - Ok Switch jaf to FBUS... FbusMode set Ok Connect phone on selected interface... Core version : 1.23 , Rev : 4.8 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm639__06.00.mcusw PPM : rm639__06.00.ppm_x CNT : rm639__06.00.image_x_0598213_008 Checking BUS... Switch jaf to FlashMode... FlashMode set Ok Booting phone... BOOT 1ST : C0 CMT part info : CMT ASICID : 000000030000022600010007600C192102031104 CMT EM0 ID : 00001051 CMT EM1 ID : 00001060 CMT PUB ID : 0D800011BEA40344B6173F9DC295AAD1D10B0827 CMT MODE ID : 00 CMT R_HASH : 916F75217F32081248B15C38DFC8E81B CMT ROM ID : E693EF0DAC22615B Change Protocol : NEW Using NEW Flashing Protocol CMT : Sending 2nd loader... Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 9.48.0 CMT Loader sent, Boot Ok Trans Req : 32 bit, DualLine, Set : 32 bit, DualLine CMT Flash ID : 003000EC < SAMSUNG [SEC] => K5W1G13ACB FLIC : 003000EC , NAND , CMT Sending Algo... Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 9.48.0 Finalize done, Algo sent! Trans Req : 32 bit, DualLine, Set : 32 bit, DualLine PapubKeysReq : 23B57C26A0C7A9C34544727AA1D2FC8F3265329C9A Boot done! SC : StoreCert Ok Partitioning.... Partitioning Ok... Erase : Processing rm639__06.00.mcusw Init Erase Mode Ok Found 4 data types Erasing Data.... Erase area : 0x00020000 - 0x000203FF , CMT , NAND Erase area : 0x00060000 - 0x0009FFFF , CMT , NAND Erase area : 0x000A0000 - 0x0041FFFF , CMT , NAND Erase area : 0x00420000 - 0x0069FFFF , CMT , NAND Erase area : 0x006A0000 - 0x006DFFFF , CMT , NAND Erase area : 0x006E0000 - 0x0123FFFF , CMT , NAND Erase area : 0x02060000 - 0x020BFFFF , CMT , NAND Erase area : 0x02CC0000 - 0x0333FFFF , CMT , NAND Erase area : 0x07540000 - 0x07B3FFFF , CMT , NAND Erase area : 0x01240000 - 0x0205FFFF , CMT , NAND Erase Ok... Erasing Partition.... Partition 0x08 Erase Ok... Erasing Partition.... Partition 0x0A Erase Ok... Erasing Partition.... Partition 0x0B Erase Ok... TIME : Erase time : 00:00:00 Write : Processing rm639__06.00.mcusw Init Write Mode Ok CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] Total writen 276 blocks TIME : Write time : 00:02:36 PrReq : NAND , 000300000000010000000100000000 Partitioning.... Partitioning Ok... Erase : Processing rm639__06.00.ppm_x Init Erase Mode Ok Found 1 data types Erasing Data.... Erase area : 0x020C0000 - 0x02CBFFFF , CMT , NAND Erase Ok... TIME : Erase time : 00:00:00 Write : Processing rm639__06.00.ppm_x Init Write Mode Ok Total writen 70 blocks TIME : Write time : 00:00:42 PrReq : NAND , 000300000000010000000100000000 ConvertImage: Processing rm639__06.00.image_x_0598213_008 ConvertImage: Page Size is 128K, no need convert Partitioning.... Partitioning Ok... Erase : Processing rm639__06.00.image_x_0598213_008 Init Erase Mode Ok Found 2 data types Erasing Data.... Erase area : 0x03340000 - 0x0753FFFF , CMT , NAND Erase Ok... Erasing Partition.... Partition 0x08 Erase Ok... TIME : Erase time : 00:00:01 Write : Processing rm639__06.00.image_x_0598213_008 Init Write Mode Ok Total writen 276 blocks TIME : Write time : 00:02:47 PrReq : NAND , 000300000000010000000100000000 Switch jaf to FBUS... FbusMode set Ok Phone not found Flashing done Connect phone on selected interface... phone still blink˛ sirr..... | |
07-02-2011, 13:32 | #8 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | We talking about USB flashing. JAF mostly designed in BEST for RAPIDO new phones fbus flashing. At now all new phones can be done by USB cable. In your case - need try with 1.23 by USB. If still no luck - need digg HW. |
The Following User Says Thank You to Dzirt For This Useful Post: |
04-20-2012, 01:30 | #9 (permalink) |
Freak Poster Join Date: Jan 2010 Location: ScBraga-Portugal
Member: 1218089 Status: Offline Sonork: 100.1615672 Thanks Meter: 8 | FlashMode set Ok Booting phone... Switch jaf to FlashMode... FlashMode set Ok Booting phone... BOOT 1ST : 00 Error : BOX FW : 01.B1 NOT SUPPORT NEW PROTOCOL - > Upgrade to 1.B4 or later ... Switch jaf to FBUS... FbusMode set Ok Connect phone on selected interface... Connect phone on selected interface... Read and Check phone data... Checking BUS... Switch jaf to FlashMode... FlashMode set Ok Booting phone... Switch jaf to FlashMode... FlashMode set Ok Booting phone... BOOT 1ST : C0 Error : BOX FW : 01.B1 NOT SUPPORT NEW PROTOCOL - > Upgrade to 1.B4 or later ...Switch jaf to FBUS... FbusMode set Ok Connect phone on selected interface... Connect phone on selected interface... Phone found! Series 40 Device detected! [DCT4+] read info... - Ok Write SL RPL procedure procedure started... Read Lock Info Locked to TMN;Portugal Unlocking... All done ! Besides the error the unlock was done!!!!! i cant detect nokia 5800.... its the firmware from my jaf box? |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
