here Code:
Phone found!
Series 40 Device detected!
read info... - Ok
Reading Phone Info....
Connected phone - Nokia 2700 classic
Software ver : V 09.98 06-09-10 RM-561 (c) Nokia
IMEI : 356240044910851
DSP Ver : ICPR72_09w26
PPM : V 09.98
06-09-10
RM-561
(c) Nokia
T
CNT : Content: ctv_au_black
V 09.98
06-09-10
RM-561
(c) Nokia
Product SN : 7325C85AI
Product code : 0588541
Base Prd.code: 0577212
Module code : 0204245
Long Prod.SN : 0
Hardware info=======
HWID : 2002
Retu : 16
Tahvo : 22
Batery: 4911 mV
CMT BT: 2222-302
LCDVer: SEIKO
RF ic : 06560601
Lock info ===========
IMEI spNet :
IMEI svNet :
Conf key : 0000000000000000
Provider key : 2440700000000000
Country : Finland
Operator : NOKIA (Open)
Counters : Key 0 [3] , Fbus 0 [10]
Blocks : 7
LOCK STATUS :
BLK : 1
Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open
BLK : 2
BLK : 3
BLK : 4
BLK : 5
BLK : 6
BLK : 7
LOCKS : All Open
User Code : 12345
MMC pwd : no any record found
UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery]
Done!
Core : v1.48 , FlashEngine : v1.7
Selected FlashSettings : Manual
Files Set for Flashing :
MCU : rm561__07.15.mcusw
PPM : rm561__07.15.ppm_ag
CNT : rm561__07.15_ISM_001.image_ag_black_optimus_pt_black
Check FlashFiles, Please, wait...
-> SWversion check skipped : Manual mode selected
Backup enabled, Will read Certificates now...
SLx Simlock Data read ... ok
SL3 Simlock Sign read ... ok
WMDRM read ... ok
CRT308 Backup Created
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT ASICID : 000000010000022600010006030C192101033000
CMT EM0 ID : 00000296
CMT EM1 ID : 00000B22
CMT PUB ID : 1B40020151E10456DBA08A79FBCB89D722565C9C
CMT MODE ID : 00
CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT ROM ID : 273F6D55DFAAF68F
CMT : Sending 2nd loader...
Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0
CMT Loader sent, Boot Ok
MCU Configuration
MCU Cfg Ok , 03
FLASHID : 89820089 , CMT , NOR
CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512
FLCNT : 00000000000000000000000000000000000000
FLASHID : 0000FFFF , CMT , MMC , EXT
CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok
Sending ALGO....
Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1
CMT Algo sent
CMT PAPUB : 3EA22A1DDA660002E56108DB5072A10F8709443FA8
Transmission mode : Dual (Ddr, TX2)
Boot Done!
CMT : Read NPC certificate...
Cert size : 20480 byte(s)
CMT : Read CCC certificate...
Cert size : 30600 byte(s)
CMT : Read HWC certificate...
CMT : Read VARIANT certificate...
Cert size : 0 byte(s)
Cert Read done!
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
SimLock Data saved...
SimLock Key saved...
WMDRM_PD Data saved...
RPL saved : d:\InfinityBox\BEST\Backup\Cert\356240044910851.rpl
Init Service mode... Wait...
DownGr: Prepare phone for downgrade... -> Failed to prepare > protected data > break!
-> Downgrade not possible for that phone... :(
Continue at user risk...
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
MCU Cfg Ok , 03
Sending ALGO....
CMT Algo sent
Boot Done!
Erase : Processing rm561__07.15.mcusw
Found 6 areas to erase, erase group
Asic : CMT , Sub : NOR
CMT , NOR , Area : 0x00000000 - 0x000006BF
CMT , NOR , Area : 0x000006C0 - 0x0001FFFF
CMT , NOR , Area : 0x00040000 - 0x000BFFFF
CMT , NOR , Area : 0x000C0000 - 0x0013FFFF
CMT , NOR , Area : 0x00140000 - 0x0137FFFF
CMT , NOR , Area : 0x01380000 - 0x0151FFFF
Using TimeOut : 7 min ( 430 sec )
Erasing, wait.....
CMT : Group erase Ok
TIME : Erase time : 00:02:06
PrReq : NOR , 00
Write : Processing rm561__07.15.mcusw
CMT: Writing Hash CERT [NOLO]
CMT: Writing Hash CERT [KEYS]
CMT: Writing Hash CERT [PRIMAPP]
CMT: Writing Hash CERT [PASUBTOC]
CMT: Writing Hash CERT [PAPUBKEYS]
CMT: Writing Hash CERT [UPDAPP]
CMT: Writing Hash CERT [DSP0]
CMT: Writing Hash CERT [MCUSW]
Total writen 1246 blocks
TIME : Write time : 00:02:39
PrReq : NOR , 00
Erase : Processing rm561__07.15.ppm_ag
Found 1 areas to erase, erase group
CMT , NOR , Area : 0x01520000 - 0x01DBFFFF
Erasing, wait.....
TIME : Erase time : 00:00:42
PrReq : NOR , 00
Write : Processing rm561__07.15.ppm_ag
Total writen 395 blocks
TIME : Write time : 00:00:49
PrReq : NOR , 00
ConvertImage: Processing rm561__07.15_ISM_001.image_ag_black_optimus_pt_black
ConvertImage: Page Size is 128K, no need convert
Erase : Processing rm561__07.15_ISM_001.image_ag_black_optimus_pt_black
Found 2 areas to erase, erase group
CMT , NOR , Area : 0x01DC0000 - 0x0215FFFF
CMT , NOR , Area : 0x02160000 - 0x03FBFFFF
Erasing, wait.....
TIME : Erase time : 00:03:34
PrReq : NOR , 00
Write : Processing rm561__07.15_ISM_001.image_ag_black_optimus_pt_black
Total writen 568 blocks
TIME : Write time : 00:01:10
PrReq : NOR , 00 Init Service mode... Wait...
Init Service mode Failed! Skip AfterFlash :(
Connect phone on selected interface...
Will Write RPL keys now...
Check RPL file...
NPC Data found! (CMT)
CCC Data found! (CMT)
HWC Data found! (CMT)
SimLock Data found!
SimLock key found!
WMDRM key found!
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
MCU Cfg Ok , 03
Sending ALGO....
CMT Algo sent
Boot Done!
Preparing for write certificates...
Switching to CMT...
CMT : NPC erase Ok
Writing NPC... Ok
CMT : CCC erase Ok
Writing CCC... Ok
CMT : HWC erase Ok
Writing HWC... Ok
Service mode init failed! :(
Check Cable/BSI/HW, try again
User confirm Format
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
MCU Cfg Ok , 03
Sending ALGO....
CMT Algo sent
Boot Done!
Erase User Area now, Selected model : RM-561, 2700c
Using TimeOut : 5 min ( 300 sec )
Erasing, wait.....
CMT : Format Ok
PrReq : NOR , 00
UserArea format done
MCU : rm561__09.80.mcusw
PPM : rm561__09.80.ppm_ag
CNT : rm561__09.80_ISM_001.image_ag_black_voda_pt_pblack
-> SWversion check skipped : Dead mode selected
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
MCU Cfg Ok , 03
Sending ALGO....
CMT Algo sent
Boot Done!
Cert Read done!
Init Service Mode Failed!
RPL saved : d:\InfinityBox\BEST\Backup\Cert\356240044910851_CRT.rpl
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
MCU Cfg Ok , 03
Sending ALGO....
CMT Algo sent
Boot Done!
Erase : Processing rm561__09.80.mcusw
Erasing, wait.....
TIME : Erase time : 00:02:07
PrReq : NOR , 00
Write : Processing rm561__09.80.mcusw
Total writen 1247 blocks
TIME : Write time : 00:02:40
PrReq : NOR , 00
Erase : Processing rm561__09.80.ppm_ag
Erasing, wait.....
TIME : Erase time : 00:00:40
PrReq : NOR , 00
Write : Processing rm561__09.80.ppm_ag
Total writen 379 blocks
TIME : Write time : 00:00:47
PrReq : NOR , 00
ConvertImage: Processing rm561__09.80_ISM_001.image_ag_black_voda_pt_pblack
Erase : Processing rm561__09.80_ISM_001.image_ag_black_voda_pt_pblack
Erasing, wait.....
TIME : Erase time : 00:00:31
PrReq : NOR , 00
Write : Processing rm561__09.80_ISM_001.image_ag_black_voda_pt_pblack
Total writen 552 blocks
TIME : Write time : 00:01:08
PrReq : NOR , 00
Check RPL file...
SimLock Data found!
SimLock key found!
WMDRM key found!
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
MCU Cfg Ok , 03
Sending ALGO....
CMT Algo sent
Boot Done!
Switching to CMT...
CMT : NPC erase Ok
Writing NPC... Ok
CMT : CCC erase Ok
Writing CCC... Ok
CMT : HWC erase Ok
Writing HWC... Ok Init Service mode... Wait...
Connect phone on selected interface... I just do not get it, I got a white screen after the nokia logo.
will flash it with 9.98 just to be sure. |
