08-07-2012, 13:33 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: spain
Member: 1038811 Status: Offline Sonork: 100.1585462 Thanks Meter: 974 | How to downgrade nokia 2700, rm-561 it is at 9.98, but if I try to flash it with 9.97 I get a white screen. If I tick on downgrade, I get a NOT SUPPORTED if I try to write pm or rpl via dead mode... I get NOT SUPPORTED I think my 5130xm fbus cable is faulty because it connect and disconect the phone very quickly, so I though "let do it via USB" guess I was wrong. |
08-07-2012, 13:40 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello. why not ask it in other great nokia tool section? X) Maybe, they have excellent solution for you. Ok, without piece of sarcasm, RAP3 can't be serviced fully via USB. Way only - FBUS. Need erase it, before readout RPL, PM. |
The Following User Says Thank You to Dzirt For This Useful Post: |
08-07-2012, 14:15 | #3 (permalink) | |
Member: 1038811 Status: Offline Sonork: 100.1585462 Thanks Meter: 974 | Quote:
For this particular job I trust only the best at it. I flash 9.97 and then tried to write rpl and pm but not joy. I took out cyclone and flash it with 9.98 and it came back to live. Then I flashed 9.97 using cyclone trying to downgrade and it didnt make it, when it finished it was as dead as the first try. I got my infinity and fire up BEST again and flash it with 9.98 and again it is working. I got RPL and PM using USB, but cannot write them back after the downgrade. I was asking if somehow I was making a mistake. Just to be clear, I will try to get the fbus cable to work. But after that what is it that I am suppose to do? 1. RPL and PM backup 2. Full Erase 3 Flash 4. Write back RPL & PM br | |
08-07-2012, 14:53 | #7 (permalink) |
Member: 1038811 Status: Offline Sonork: 100.1585462 Thanks Meter: 974 | here Code: Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 2700 classic Software ver : V 09.98 06-09-10 RM-561 (c) Nokia IMEI : 356240044910851 DSP Ver : ICPR72_09w26 PPM : V 09.98 06-09-10 RM-561 (c) Nokia T CNT : Content: ctv_au_black V 09.98 06-09-10 RM-561 (c) Nokia Product SN : 7325C85AI Product code : 0588541 Base Prd.code: 0577212 Module code : 0204245 Long Prod.SN : 0 Hardware info======= HWID : 2002 Retu : 16 Tahvo : 22 Batery: 4911 mV CMT BT: 2222-302 LCDVer: SEIKO RF ic : 06560601 Lock info =========== IMEI : 356240044910851 IMEI spNet : IMEI svNet : Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Core : v1.48 , FlashEngine : v1.7 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm561__07.15.mcusw PPM : rm561__07.15.ppm_ag CNT : rm561__07.15_ISM_001.image_ag_black_optimus_pt_black Check FlashFiles, Please, wait... -> SWversion check skipped : Manual mode selected Backup enabled, Will read Certificates now... SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok CRT308 Backup Created Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 1B40020151E10456DBA08A79FBCB89D722565C9C CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : 3EA22A1DDA660002E56108DB5072A10F8709443FA8 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 356240044910851 CMT : Read CCC certificate... Cert size : 30600 byte(s) CMT : Read HWC certificate... Cert size : 20480 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : d:\InfinityBox\BEST\Backup\Cert\356240044910851.rpl Init Service mode... Wait... DownGr: Prepare phone for downgrade... -> Failed to prepare > protected data > break! -> Downgrade not possible for that phone... :( Continue at user risk... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 1B40020151E10456DBA08A79FBCB89D722565C9C CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : 3EA22A1DDA660002E56108DB5072A10F8709443FA8 Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm561__07.15.mcusw Found 6 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x000BFFFF CMT , NOR , Area : 0x000C0000 - 0x0013FFFF CMT , NOR , Area : 0x00140000 - 0x0137FFFF CMT , NOR , Area : 0x01380000 - 0x0151FFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:02:06 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm561__07.15.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] Total writen 1246 blocks TIME : Write time : 00:02:39 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm561__07.15.ppm_ag Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01520000 - 0x01DBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:42 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm561__07.15.ppm_ag Total writen 395 blocks TIME : Write time : 00:00:49 PrReq : NOR , 00 ConvertImage: Processing rm561__07.15_ISM_001.image_ag_black_optimus_pt_black ConvertImage: Page Size is 128K, no need convert Transmission mode : Dual (Ddr, TX2) Erase : Processing rm561__07.15_ISM_001.image_ag_black_optimus_pt_black Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01DC0000 - 0x0215FFFF CMT , NOR , Area : 0x02160000 - 0x03FBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:03:34 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm561__07.15_ISM_001.image_ag_black_optimus_pt_black Total writen 568 blocks TIME : Write time : 00:01:10 PrReq : NOR , 00 Init Service mode... Wait... Init Service mode Failed! Skip AfterFlash :( Connect phone on selected interface... Connect phone on selected interface... Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) SimLock Data found! SimLock key found! WMDRM key found! Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 1B40020151E10456DBA08A79FBCB89D722565C9C CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : 3EA22A1DDA660002E56108DB5072A10F8709443FA8 Transmission mode : Dual (Ddr, TX2) Boot Done! Preparing for write certificates... Switching to CMT... CMT : NPC erase Ok Writing NPC... Ok CMT : CCC erase Ok Writing CCC... Ok CMT : HWC erase Ok Writing HWC... Ok Init Service mode... Wait... Service mode init failed! :( Check Cable/BSI/HW, try again Connect phone on selected interface... User confirm Format Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 1B40020151E10456DBA08A79FBCB89D722565C9C CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : 3EA22A1DDA660002E56108DB5072A10F8709443FA8 Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase User Area now, Selected model : RM-561, 2700c Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Format Ok PrReq : NOR , 00 UserArea format done Core : v1.48 , FlashEngine : v1.7 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm561__09.80.mcusw PPM : rm561__09.80.ppm_ag CNT : rm561__09.80_ISM_001.image_ag_black_voda_pt_pblack Check FlashFiles, Please, wait... -> SWversion check skipped : Dead mode selected Backup enabled, Will read Certificates now... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 1B40020151E10456DBA08A79FBCB89D722565C9C CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : 3EA22A1DDA660002E56108DB5072A10F8709443FA8 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 356240044910851 CMT : Read CCC certificate... Cert size : 30600 byte(s) CMT : Read HWC certificate... Cert size : 20480 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! Init Service mode... Wait... Init Service Mode Failed! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : d:\InfinityBox\BEST\Backup\Cert\356240044910851_CRT.rpl Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 1B40020151E10456DBA08A79FBCB89D722565C9C CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : 3EA22A1DDA660002E56108DB5072A10F8709443FA8 Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm561__09.80.mcusw Found 6 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x000BFFFF CMT , NOR , Area : 0x000C0000 - 0x0013FFFF CMT , NOR , Area : 0x00140000 - 0x0137FFFF CMT , NOR , Area : 0x01380000 - 0x0151FFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:02:07 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm561__09.80.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] Total writen 1247 blocks TIME : Write time : 00:02:40 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm561__09.80.ppm_ag Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01520000 - 0x01DBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:40 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm561__09.80.ppm_ag Total writen 379 blocks TIME : Write time : 00:00:47 PrReq : NOR , 00 ConvertImage: Processing rm561__09.80_ISM_001.image_ag_black_voda_pt_pblack ConvertImage: Page Size is 128K, no need convert Transmission mode : Dual (Ddr, TX2) Erase : Processing rm561__09.80_ISM_001.image_ag_black_voda_pt_pblack Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01DC0000 - 0x0215FFFF CMT , NOR , Area : 0x02160000 - 0x03FBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:31 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm561__09.80_ISM_001.image_ag_black_voda_pt_pblack Total writen 552 blocks TIME : Write time : 00:01:08 PrReq : NOR , 00 Init Service mode... Wait... Init Service mode Failed! Skip AfterFlash :( Connect phone on selected interface... Connect phone on selected interface... Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) SimLock Data found! SimLock key found! WMDRM key found! Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 1B40020151E10456DBA08A79FBCB89D722565C9C CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : 3EA22A1DDA660002E56108DB5072A10F8709443FA8 Transmission mode : Dual (Ddr, TX2) Boot Done! Preparing for write certificates... Switching to CMT... CMT : NPC erase Ok Writing NPC... Ok CMT : CCC erase Ok Writing CCC... Ok CMT : HWC erase Ok Writing HWC... Ok Init Service mode... Wait... Service mode init failed! :( Check Cable/BSI/HW, try again Connect phone on selected interface... will flash it with 9.98 just to be sure. |
08-07-2012, 15:06 | #8 (permalink) |
Member: 1038811 Status: Offline Sonork: 100.1585462 Thanks Meter: 974 | phone is back Code: Selected FlashSettings : Manual Files Set for Flashing : MCU : rm561__09.98.mcusw PPM : rm561__09.98.ppm_t CNT : rm561__09.98.image_ctv_au_black Check FlashFiles, Please, wait... -> SWversion check skipped : Dead mode selected Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 1B40020151E10456DBA08A79FBCB89D722565C9C CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : 3EA22A1DDA660002E56108DB5072A10F8709443FA8 Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm561__09.98.mcusw Found 6 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x000BFFFF CMT , NOR , Area : 0x000C0000 - 0x0013FFFF CMT , NOR , Area : 0x00140000 - 0x0137FFFF CMT , NOR , Area : 0x01380000 - 0x0151FFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:02:08 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm561__09.98.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] Total writen 1247 blocks TIME : Write time : 00:02:40 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm561__09.98.ppm_t Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01520000 - 0x01DBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:39 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm561__09.98.ppm_t Total writen 423 blocks TIME : Write time : 00:00:52 PrReq : NOR , 00 ConvertImage: Processing rm561__09.98.image_ctv_au_black ConvertImage: Page Size is 128K, no need convert Transmission mode : Dual (Ddr, TX2) Erase : Processing rm561__09.98.image_ctv_au_black Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01DC0000 - 0x0215FFFF CMT , NOR , Area : 0x02160000 - 0x03FBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:28 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm561__09.98.image_ctv_au_black Total writen 696 blocks TIME : Write time : 00:01:26 PrReq : NOR , 00 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 2700 classic Software Info: V 09.98 06-09-10 RM-561 (c) Nokia IMEI: 356240044910851 Product code: 0588541 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done ;D Connect phone on selected interface... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
08-07-2012, 15:47 | #10 (permalink) |
Member: 1038811 Status: Offline Sonork: 100.1585462 Thanks Meter: 974 | I will try your suggestion, but it worked when I selected 9.98 mcu with 9.97 ppm and cnt. Code: Files Set for Flashing : MCU : rm561__09.98.mcusw PPM : rm561__09.97.ppm_ag CNT : rm561__09.97.image_ag_gray Check FlashFiles, Please, wait... -> SWversion check skipped : Manual mode selected Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 1B40020151E10456DBA08A79FBCB89D722565C9C CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : 3EA22A1DDA660002E56108DB5072A10F8709443FA8 Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm561__09.98.mcusw Found 6 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x000BFFFF CMT , NOR , Area : 0x000C0000 - 0x0013FFFF CMT , NOR , Area : 0x00140000 - 0x0137FFFF CMT , NOR , Area : 0x01380000 - 0x0151FFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:02:09 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm561__09.98.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] Total writen 1247 blocks TIME : Write time : 00:02:40 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm561__09.97.ppm_ag Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01520000 - 0x01DBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:36 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm561__09.97.ppm_ag Total writen 379 blocks TIME : Write time : 00:00:47 PrReq : NOR , 00 ConvertImage: Processing rm561__09.97.image_ag_gray ConvertImage: Page Size is 128K, no need convert Transmission mode : Dual (Ddr, TX2) Erase : Processing rm561__09.97.image_ag_gray Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01DC0000 - 0x0215FFFF CMT , NOR , Area : 0x02160000 - 0x03FBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:02:36 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm561__09.97.image_ag_gray Total writen 520 blocks TIME : Write time : 00:01:04 PrReq : NOR , 00 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 2700 classic Software Info: V 09.98 06-09-10 RM-561 (c) Nokia IMEI: 356240044910851 Product code: 0588541 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done ;D Connect phone on selected interface... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... do some tests. now I am going to do it your way. |
08-07-2012, 16:12 | #11 (permalink) |
Member: 1038811 Status: Offline Sonork: 100.1585462 Thanks Meter: 974 | Code: Checking StartUp data ... ----------------------- SDD Key status : SDData is Ok SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL3 phone detected , SP_CODE_LEN : 15 Done! User ACCEPTED FULL ERASE Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 1B40020151E10456DBA08A79FBCB89D722565C9C CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : 3EA22A1DDA660002E56108DB5072A10F8709443FA8 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 356240044910851 CMT : Read CCC certificate... Cert size : 30600 byte(s) CMT : Read HWC certificate... Cert size : 20480 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... [COLOR="rgb(0, 255, 255)"] RPL saved : d:\InfinityBox\BEST\Backup\Cert\356240044910851_CRT_2nd.rpl [/COLOR] Full Erase started... Asic : CMT , Sub : NOR Erase Area 0x00000000-0x03FFFFFF Using TimeOut : 10 min ( 600 sec ) Erasing, wait..... Erase CMT Finished , [FF] CMT : Erase Ok Done Phone disconected! Connect phone on selected interface... Core : v1.48 , FlashEngine : v1.7 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm561__09.97.mcusw PPM : rm561__09.97.ppm_ag CNT : rm561__09.97.image_ag_gray Check FlashFiles, Please, wait... -> SWversion check skipped : Dead mode selected Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 1B40020151E10456DBA08A79FBCB89D722565C9C CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent PAPUBkeys blank (erased or HW failure) Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm561__09.97.mcusw Found 6 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x000BFFFF CMT , NOR , Area : 0x000C0000 - 0x0013FFFF CMT , NOR , Area : 0x00140000 - 0x0137FFFF CMT , NOR , Area : 0x01380000 - 0x0151FFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:05 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm561__09.97.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] Total writen 1247 blocks TIME : Write time : 00:02:41 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm561__09.97.ppm_ag Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01520000 - 0x01DBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:02 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm561__09.97.ppm_ag Total writen 379 blocks TIME : Write time : 00:00:51 PrReq : NOR , 00 ConvertImage: Processing rm561__09.97.image_ag_gray ConvertImage: Page Size is 128K, no need convert Transmission mode : Dual (Ddr, TX2) Erase : Processing rm561__09.97.image_ag_gray Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01DC0000 - 0x0215FFFF CMT , NOR , Area : 0x02160000 - 0x03FBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:08 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm561__09.97.image_ag_gray Total writen 520 blocks TIME : Write time : 00:01:05 PrReq : NOR , 00 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 2700 classic Software Info: V 09.97 18-06-10 RM-561 (c) Nokia IMEI: 12345610654321? Product code: Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done ;D Connect phone on selected interface... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Checking StartUp data ... ----------------------- IMEI Validation : IMEI Damaged!!!! - > SIMLOCK , SECURITY Info can be wrong! - > Need restore NPC backup or RPL SDD Key status : SDData Damaged!!!!! :( - > Do REPAIR SDD , Local SX4 if needed SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL phone detected Done! Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) SimLock Data found! SimLock key found! WMDRM key found! Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 1B40020151E10456DBA08A79FBCB89D722565C9C CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : 3EA22A1DDA660002E56108DB5072A10F8709443FA8 Transmission mode : Dual (Ddr, TX2) Boot Done! Preparing for write certificates... Switching to CMT... CMT : NPC erase Ok Writing NPC... Ok CMT : CCC erase Ok Writing CCC... Ok CMT : HWC erase Ok Writing HWC... Ok Init Service mode... Wait... Writing SimLock Key... Ok! Writing SimLock Data... Ok! Product code update... SDD Key status : SDData Damaged!!!!! :( SimLock status : SimLock is Ok Security status : Security is Ok Done! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Repair SD procedure started... Phone Imei: 356240044910851 Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 1B40020151E10456DBA08A79FBCB89D722565C9C CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... CMT Loader sent, Boot Ok rap= 1B40020151E10456DBA08A79FBCB89D722565C9C hash= 9DDBFCFE6E73CED7D8C6268C8EB85723 key= 296EFEA02936BB8031F8841073EE00962A94CBE1 Init Service mode... Wait... Key file updated... Check phone mode... Phone already in Test mode, skip change... Writing Super Dongle Key... Ok Done! Checking StartUp data ... ----------------------- SDD Key status : SDData is Ok SimLock status : SimLock is Ok Security status : Security Damaged!!!!! :( - > Do Local SX4 or Server SX4 , Upload Tune ( checkbox or manual ) ----------------------- PA_SimLock Version : PA_SL3 phone detected , SP_CODE_LEN : 15 Done! Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 356240044910851 Key file exists, no need to read... Step 1... Step 2... Step 3... SX4 Auth - Ok Upload PM checked Uploading RF/Battery tune to phone... Using : RM-561.pm Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => OK Done! Elapsed: 00:00:01 Upload done Checking StartUp data ... ----------------------- SDD Key status : SDData is Ok SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL3 phone detected , SP_CODE_LEN : 15 Done! Phone disconected! Connect phone on selected interface... |
08-07-2012, 21:56 | #12 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | sir please tell me first.way you this phone downgrade? if you want to change the phone language so try this method (1)select mcu 9.98 (2)select ppm (any ver )wich you want languge change (3)select cnt 9.98 AND FULL FLASH YOUR PHONE if you want completely remove ver 9.98 .or downgrade.sl3 not possible downgrade only possible downgrade sl1 and sl2 ok so completely removing sl3 try this method for sl3 downgrade (1) Backup RPL (2)ERASE FLASH (3)Rewrite needed FW (4)Write back RPL (5)Make SDD repair (6)Make SX4 (7)Write back PM BR SAEEDULLAH_KHAN |
08-10-2012, 22:01 | #13 (permalink) |
Member: 1038811 Status: Offline Sonork: 100.1585462 Thanks Meter: 974 | @dzirt, look here my opinion about the best nokia flasher. http://forum.gsmhosting.com/vbb/8284852-post83.html Thank you again. Enviado desde mi A100 usando Tapatalk 2 |
