01-17-2024, 10:06 | #1 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | How to make factory firmware from Nokia 150 DS 2023 - TA-1582 ? [code] Start at : [17.01.2024 / 10:54:31] Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 36 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : AA1CEF1AC90771ED2837B1D35FFA56C7 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Reading Flash Content now ... Read Flash now Read Ok , 4194304 bytes read Check and collect compile info File_Info : DL273_GX2732_RO_PCB01_gsm_MT6261_S00.10_02_17_00.b in FileVersion : 10.02.17.00 [ScatCFG] : MT6261 / 10.02.17.00 / NOR , SF Firmware saved to : D:\InfinityBox\CM2MTK\Read_out\DL273_GX2732_RO_PCB 01_gsm_MT6261_S00\ Done! Elapsed: 00:00:14 Reconnect Power/Cable! Finish at : [17.01.2024 / 10:54:46] [code] But is this is enougt to rewrite such phone for Language change for example? BR, DebeliaMark, BG |
