09-13-2013, 19:16 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Manhuaçu/MG/BR/
Member: 251218 Status: Offline Thanks Meter: 39 | How to repair Contact Service - Nokia C3-00 RM-614 [by Infinity BEST Dongle] Steps: 1. Having a latest Flash RM-614 (I used the BR 08.70) 2. Having the application Infinity BEST BB5 version 1.67.5 or higher 3. Have the device drivers installed on the computer Steps to proceed with procedures (must be performed very carefully): 1. Connect your cell phone to your computer without battery 2. Click the Repair tab 3. RPL field, select all options, unless EPA 4. Click Read RPL 5. When prompted, connect the battery to the phone and wait ... NOTE: Necessary finish without errors. If an error occurs, do it all again. Successfully made backup of RPL cell, depart for the next steps: 1. Click ERASE FLASH (uncheck Skip Backup Chk.) 2. Confirm YES to all questions (even saying that your device will die) 3. Finished, go to the tab BB5 Flash XG 4. Select the latest flash files (RM-614) 5. Flash the device with the option Fullflash 6. Click FLASH 7. Connect the mobile phone without battery 8. Connect the battery 9. Wait finalize (wait install drivers too) 10. Without disconnecting, check out our guide Repair 11. Click on Write RPL 12. When you open the file to select, CANCEL 13. Application will ask you if you want to apply the best RPL file found 14. When finished, disconnect the phone and remove the battery 15. Connect your phone again without battery and then click Key Rd 16. Follow the steps until you read the Key 17. When the Repair button SDD stay active, go ahead 18. Repair Super Dongle (clicking the Repair SDD) 19. Follow the application guidelines 20. Check the machine NOTE: If you are still with some failure, repeat steps 14-16, and click Check SL / SD / SECURITY / CMLA and see if anything appears in the list as failed. Translated by Google Como reparar Contact Service - Nokia C3-00 RM-614 [by BEST Infinity Dongle] |
