06-28-2011, 03:39 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Midle of the Earth
Member: 575851 Status: Offline Thanks Meter: 544 | i cannot restore simlock data 6730c Phone found! Series 60 Device detected! read info... - Ok Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) SimLock Data found! SimLock key found! WMDRM key found! Checking BUS... Switch jaf to FlashMode... FlashMode set Ok Booting phone... BOOT 1ST : C0 CMT part info : CMT ASICID : 000000030000022600010007600C192102011104 CMT EM0 ID : 00000C34 CMT EM1 ID : 00000C30 CMT PUB ID : 15D00116F95E03441B9994A46EBCC2894BD90850 CMT MODE ID : 00 CMT R_HASH : 25B977A055BE9B5DEC0C38A2A279C695 CMT ROM ID : 3E273BF637BE26FA Change Protocol : NEW Using NEW Flashing Protocol CMT : Sending 2nd loader... Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 9.48.0 CMT Loader sent, Boot Ok Trans Req : 32 bit, DualLine, Set : 32 bit, DualLine CMT Flash ID : 00400020 < ST => M39BORBOAD FLIC : 00400020 , NAND , CMT Sending Algo... Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 9.48.0 Finalize done, Algo sent! Trans Req : 32 bit, DualLine, Set : 32 bit, DualLine PapubKeysReq : 397DCE210733C335E84BAD369EC893FCA06D1BC3F2 Boot done! Preparing for write certificates... Switching to CMT... Erase NPC... Ok Writing NPC... Ok Erase CMT CCC... Ok Writing CMT CCC... Ok Erase CMT HWC... Ok Writing CMT HWC... Ok CMT cert write done! Switch jaf to FBUS... FbusMode set Ok Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Writing SimLock Key... Error! Writing SimLock Data... Error! SDD Key status : SD Data is Ok SimLock status : SimLock Damaged!!!!! Security status : Security is Ok WMDRM_PD key sent... Ok Done! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
06-28-2011, 08:13 | #7 (permalink) | |
Member: 575851 Status: Offline Thanks Meter: 544 | Quote:
Connect phone on selected interface... Opening Connection... Device Location: 00000031 Connect Ok! Initializing Connection... JAF Firmware: 01.B5 JAF S/N ODJAF000 boot - Ok Switch jaf to FBUS... FbusMode set Ok Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) SimLock Data found! SimLock key found! WMDRM key found! No any FLASH keys selected, Skip FLASH part Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Writing SimLock Key... Error! Writing SimLock Data... Error! SDD Key status : SD Data is Ok SimLock status : SimLock Damaged!!!!! Security status : Security is Ok Done! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 6730c Software ver : V ICPR82_10w08 26-02-10 RM-566 (c) Nokia IMEI : 354212031640728 Ape Ver : 031.022 APE Var : 031.022031.022.16.01031.022.C01.01 APE ADSP: 256 DSP Ver : ICPR82_10w08 APE Test: PPM : CNT : Product SN : 0 Product code : Base Prd.code: Module code : Long Prod.SN : 0 Hardware info======= HWID : Retu : 34 Tahvo : 00 Batery: 4782 mV Camera: CMT BT: APE BT: HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652. APE HW: 256 LCDVer: RF ic : |Vapaus_5.1 | Aura_?.? Lock info =========== IMEI : 354212031640728 IMEI spNet : IMEI svNet : Unable to read Lock table... User code : Crypted UserDataExLevel : Low [Gallery] Done! | |
06-28-2011, 10:16 | #12 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | USB work pewrfectly for rapuyama. Please, try by usb. If not luck - will be need erase phone and after reflash it will be ok. Erase can be done by usb too |
The Following User Says Thank You to Dzirt For This Useful Post: |
cellular data suite kabel | vingis | Main Sales Section | 0 | 11-25-1999 19:18 |
SimLock Level 4 counter | HitMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-12-1999 00:17 |
The Best Dual Data cable FBUS-M2BUS for your NOKIA 5110 6110 | Nk_Cable | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-10-1999 10:08 |
Cellular Data Suite Cables avaliable !!! | vingis | Main Sales Section | 0 | 11-02-1999 17:35 |
The Best Dual Data cable FBUS-M2BUS for your NOKIA 5110 6110 | nk.cable | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-14-1999 15:33 |
