08-22-2017, 23:11 | #487 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Please see instruction here - http://forum.gsmhosting.com/vbb/f641.../#post11718276 |
08-25-2017, 06:01 | #488 (permalink) |
Freak Poster Join Date: Jan 2011 Location: viet nam
Member: 1486276 Status: Offline Thanks Meter: 39 | === DongleManager [Infinity] v1.70 [25/08/2017 11:56:56] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 01077483147D1292 === Process started: 25/08/2017 11:56:57 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
08-25-2017, 12:30 | #489 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
What to do: 1. Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - http://www.infinity-box.com/support/?r=6 OR 1. Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: 2. Run DongleManager 3. Update Dongle firmware - DO NOT update Smart-Card many times otherwise your account will be locked automatically after 3 tries for 24 hours - DO NOT use any kind of usb sharing/trace/spy/debug software to avoid problem with Dongle ! | |
08-26-2017, 04:06 | #490 (permalink) |
Member: 1486276 Status: Offline Thanks Meter: 39 | I did not follow, I waited 2 days === DongleManager [Infinity] v1.70 [26/08/2017 10:04:10] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 01077483147D1292 === Process started: 26/08/2017 10:04:10 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
09-02-2017, 00:18 | #491 (permalink) | |
09-08-2017, 15:55 | #492 (permalink) | |
Member: 1486276 Status: Offline Thanks Meter: 39 | Quote:
CardID: Card-Reader: FT SCR2000 0 ATR: 3B7D95000080318065B0831148C883009000 Card Manager: A000000018434D00 SerialNumber: 01077483 ROM: Integrated Circuit Fabricator: 4250 Integrated Circuit Type: 3272 OS: Identifier: 1291 Release Date: 6181 Release Level: 0700 EEPROM: Fabrication Date: 1177 Serial Number: 01077483 Batch Identifier: 147D Module Fabricator: 1292 Module Packaging Date: 1250 IC Card Manufacturer: 2003 IC Em******* Date: 1250 Pre Personalizer: 2004 Pre Personalization Date: 1250 Pre Personalization Equipment Identifier: 00000019 Personalizer: 0000 Personalization Date: 0000 Personalization Equipment Identifier: 00000000 m_iopCard.Serial: 01077483147D1292 GP Version: SCP Version: 0, Option: 0 DongleManager === DongleManager [Infinity] v1.70 [08/09/2017 21:55:02] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 01077483147D1292 === Process started: 08/09/2017 21:55:04 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 | |
09-08-2017, 19:19 | #493 (permalink) | |
09-09-2017, 04:41 | #494 (permalink) | |
