03-13-2020, 14:19 | #1 (permalink) |
Freak Poster Join Date: Aug 2016
Member: 2617962 Status: Offline Thanks Meter: 6 | InfinityBox BEST is not starting after inserting license file Now the software just ask for admin permission and after YES is not starting https://ibb.co/ZShKV4W thanks |
03-17-2020, 14:16 | #2 (permalink) | |
What is "admin permission" means ? What is the exact message text ? | |
03-21-2020, 13:41 | #3 (permalink) |
Member: 2617962 Status: Offline Thanks Meter: 6 | Even on freshly installed windows 10 today/32 bits/ and installed nessesary net framework: InfinityBox BEST2 is not starting - ask for permission , select YES and after that the blue image with the big font and that`s that - no error |
03-21-2020, 20:57 | #4 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
Also you can try to run software "As Administrator" via right click. result ? | |
03-23-2020, 18:38 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Dear Sir, List of installed apps required only if software can not run at all. If you can run software and after that you see some kind of error list of applications is not requered. Please make the next two steps and let us know about results: 1. login to your PC as Administrator. 2. run software "As Administrator" via right click. what is the result ? |
03-23-2020, 21:53 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | If "Run As Administrator" can not help follow this instruction - https://www.infinity-box.com/support/?r=100103 |
03-25-2020, 10:32 | #9 (permalink) |
Member: 2617962 Status: Offline Thanks Meter: 6 | everything is ok now. maybe the problem was mine (not) blond hair and have been trying to execute the application without inserting the dongle in pc. Everything needed is available - i am the admin of the os and click yes when the program is asking for yes or no(for rights) net framework is installed. use only the windows security and if something is found i allow it on my pc thank you |
The Following 2 Users Say Thank You to diretouch For This Useful Post: |
