04-05-2021, 09:09 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: iran,isfahan
Member: 269202 Status: Offline Thanks Meter: 281 | Socket Error # 10060 hi i want to flash nokia 2 ta-1029 always socket error # 10060 antiviruse and firewall disabled Code: > Old : Power Off Phone, wait 5-10 seconds, Insert USB cable -> New : Power Off Phone, press and hold VOL_DOWN and POWER keys, until FASTBOOT screen appear Wait for phone... Connect Ok! Device Found! Initialize ... Initialize Ok! Dev Model : E1A HW version : 3.0 HW RF_BAND : G_850_900_1800_1900^W_1_2_5_8^L_1_3_5_7_8_20_28_38_40 SW version : E1M-068R-0-00WW-B01 SW serialnm : E1MGAP0812612089 Bootloader type : RETAIL Security Version : 0004 OP : Activate SVC Device : E1A ( E1M1 ) BLType : RETAIL SecVer : 04 Device authentification ... Processing server operation ... Connecting to server... Connection faled: Socket Error # 10060 Connection timed out. Disconnected Error : Server Connection failed! Connection error or bad credentials? Check previous message for more info! Reconnect Power/Cable! |
04-05-2021, 11:32 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Some phones need a server authorization for flash etc. This kind of paid service is currently offline. btw, in some cases you should use VPN. |
04-05-2021, 13:22 | #4 (permalink) | |
Member: 269202 Status: Offline Thanks Meter: 281 | Quote:
Hi i use vpn and now show this Code: > Old : Power Off Phone, wait 5-10 seconds, Insert USB cable -> New : Power Off Phone, press and hold VOL_DOWN and POWER keys, until FASTBOOT screen appear Wait for phone... Connect Ok! Device Found! Initialize ... Initialize Ok! Dev Model : E1A HW version : 3.0 HW RF_BAND : G_850_900_1800_1900^W_1_2_5_8^L_1_3_5_7_8_20_28_38_40 SW version : E1M-068R-0-00WW-B01 SW serialnm : E1MGAP0812612089 Bootloader type : RETAIL Security Version : 0004 OP : Activate SVC Device : E1A ( E1M1 ) BLType : RETAIL SecVer : 04 Device authentification ... Processing server operation ... Connecting to server... Connected Authenticating... Authentication error:Connection Closed Gracefully. Disconnected Disconnected Finished Error : Device auth failed! Server reported error! Send log and report.log to support! Include device info also! Reconnect Power/Cable! | |
04-05-2021, 18:40 | #5 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,992 | Some phones need a server authorization for flash etc. This kind of paid service is currently offline. |
04-07-2021, 17:19 | #9 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,992 | Quote:
You can do it via code by imei. See list of supporterd networks/operatords here https://www.infinity-box.com/price/ | |
The Following 2 Users Say Thank You to YellowBoss For This Useful Post: |
04-08-2021, 19:14 | #10 (permalink) |
Junior Member Join Date: Jul 2017 Location: malawi
Member: 2739204 Status: Offline Thanks Meter: 0 | thank for guiders on lumia phones how to unlock network nokia 150 rm 1189 mtk i tried to unlock with infinity best it shows an error not supported with 20 digits |
04-10-2021, 08:54 | #12 (permalink) | |
Member: 2739204 Status: Offline Thanks Meter: 0 | Quote:
Registered to: dennis Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Reading Phone Info.... Software ver : 11.00.11 00-00-00 RM-1189 IMEI 1 : 354886083547046 IMEI 2 : 123456789012345 XappVer : 000008F2 Ape Ver : NEMO G 4122fe8d/1 (00000000+0) T Thu Dec 29 01:31:09 2016 U d61db836 PPM : AE2 CNT : DUBAI61D.11.00.11.p1 Product SN : 11D1C0EBU Product code : 059X9H4 Base Prd.code: 059X7J4 Module code : 0207086 Hardware info======= HWID : 1200 LCDVer: TPO Lock info =========== IMEI : 354886083547046 IMEI spNet : 3A 45 88 06 38 45 07 64 Conf key : 800000000004000B Provider key : 2341500000000000 Country : United Kingdom Operator : vodafone UK Lock info: Block 1 L1:Close; SimLock status : Ok Security status : Ok Done! Upload Job procedure started... Software Info: 11.00.11 00-00-00 RM-1189 IMEI: 354886083547046 PPM version : AE2 Product code: 059X9H4 Rebooting phone to FlashMode... Wait for phone... Phone found! [ 26 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : AD23188FD2100CD67FC062B6D7FB816C BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : DUBAI61D.11.00.11.p1 BROM/BL stage done Configure RAMINIT Ok Reading flash now ... Done! Read Ok Collect initial info IMEI : 354886083547046 UID : F4F3FFC191835E59 Get Security Info Ok SimLock : Closed Sl Conf : 800000000004000-B Country : United Kingdom Operator : vodafone UK PA_SIMLOCK : PA_SL30 [ NCK : 20 Digits ] SL30 20 digits phone detected. Unlock not possible. Stopping operation!!! Connect phone on selected interface... | |
04-10-2021, 10:48 | #13 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,537 | Quote:
You should order unlock code for locked netwok/operator. List of supported operators is here https://www.infinity-box.com/price/ | |
04-10-2021, 16:41 | #14 (permalink) | |
but am still confused on which option should i choose between these two 1.Generic - Spain Vodafone (all models except iPhone) unlock code by imei 2.Generic - UK EE/Orange/T-Mobile (all models without iPhone) unlock code by imei since my phones is from uk and operators is vodafone uk in 1 generic operators is spain vodafone and second operator is uk ee/ orange / t- mobile so help me which one suitable for my phone | |
