![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2004 Location: iran Age: 37
Member: 90307 Status: Offline Sonork: not hav e Thanks Meter: 24 ![]() | n9 flashing failed error see log card found: S/N 178A:0118 registered to: qassem Connect phone on selected interface... Check : Processing DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_006-OEM1-958_ARM.bin ========== FW APE version : 40.2012.21-3 FW CMT version : 9.2.2011.51 FW PRx release : PR_1.3 FW Region info : MIDDLE EAST FW Region ver : 006 KERNEL version : 2.6.32-20121301+0m8 ========== Check : File Is Ok ! Check : Processing DFL61_HARMATTAN_40.2012.13-7.SSAEUCITIES_EMMC_SSAEUCITIES.bin ========== eMMC version : DFL61_HARMATTAN_40.2012.13-7.SSAEUCITIES ========== Check : File Is Ok ! Core : v1.50 , FlashEngine : v2.00 Insert cable in to powered OFF phone! (Ignore if phone Connected) Waiting for NOLO... Core : v1.50 , FlashEngine : v2.00 Insert cable in to powered OFF phone! (Ignore if phone Connected) Waiting for NOLO... Connect phone on selected interface... Maemo Phone not found ![]() Core : v1.50 , FlashEngine : v2.00 Insert cable in to powered OFF phone! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RM-696 , HWRev : 1603 NOLO : 01/06/23 SWVer: DFL61_HARMATTAN_10.2011.34-1.368.01.13_PR_368 Device mode : Production mode Read info Ok Processing APE Boot... File : DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_006-OEM1-958_ARM.bin Processing : ape-algo APE Algorithm boot Ok Reopening the connection... RFS mode init Ok Device : RM-696 HW build : 1603 Bat.level : 63 SW release : (empty) Protocol : 108 UPDAPP ver : 1.7.2 Upd/Dev PT : 3 , 3 FL_images : cert-sw,xloader,secondary,rootfs,kernel,moslo,config,mm c,tar,cmt-2nd,cmt-algo,cmt-mcusw Last errors : bb5_rdc_cert_read failed Code Match Ok HW match Ok RFS Set : Host Protocol set to 108 RFS Set : CMT Verify On RFS Set : Perform RFS On RFS Set : eMMC preserve Off ---Processing MCU image--- Processing File : DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_006-OEM1-958_ARM.bin RFS : Sending config for [cert-sw] -> Ver T : RM-696 -> Ver H : 1507 , 1508 , 1509 , 1510 , 1601 , 1602 , 1603 , 1604 , 1605 , 1701 , 1702 , 1703 , 1704 , 1705 , 1801 , 1802 , 1803 , 1804 , 1805 RFS : Init pipe 00 RFS : Flashing... RFS : Finalizing... cert-sw Flash done RFS : Sending config for [kernel] -> Ver I : 2.6.32-20121301+0m8 RFS : Init pipe 01 RFS : Flashing... RFS : Finalizing... kernel Flash done RFS : Sending config for [rootfs] -> Ver I : DFL61_HARMATTAN_40.2012.21-3_PR_006 RFS : Init pipe 02 RFS : Flashing... after that tis error:::::::RFS : Flashing... RFS : ERROR_PIPE_CHECK_REQ FAILED Receiving error list... Last errors : mmc: Could not find device path under /sys/class/mmc_host/mmc0 mmc: Failed to init mmc block device scconf_parse_entries failed: (null) Unable to parse layout mmc: Could not remove mount directory /tmp/sudmmc5M361Z/mnt: No such file or directory mmc: Could not unlink (null): Bad address [Pipe 2] Finishing in error state with status 1 |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
