02-17-2012, 12:14 | #17 (permalink) | |
Freak Poster Join Date: Aug 2011 Location: European Union Age: 34
Member: 1628887 Status: Offline Sonork: 100.1648746 Thanks Meter: 70 | Quote:
02-17-2012, 14:30 | #18 (permalink) |
No Life Poster Join Date: Jan 2011 Location: in your Heart
Member: 1484062 Status: Offline Sonork: 1610135 Thanks Meter: 218 | Alas .. . .i have Gpg Original 7pin cable and i chk without strip and camera and i,m chk total erase phone and repeat Backup nd flash result LOCK Code? why, ,, , , ,, , , |
02-17-2012, 14:44 | #19 (permalink) |
Freak Poster Join Date: Sep 2010 Location: Ukraine, Ivano-Frankivsk Age: 31
Member: 1397329 Status: Offline Thanks Meter: 73 | If you erase your phone, after you can*t restore sld, sd and security without local))) do as i say, try to get hardware local using resistor and reset phone via usb) |
02-18-2012, 08:22 | #23 (permalink) |
Member: 1484062 Status: Offline Sonork: 1610135 Thanks Meter: 218 | my problem will be solved from Gpg Universal cable set. Connect phone on selected interface... Connect phone on selected interface... UFS S/N 102310 boot - Ok Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:14 Checking StartUp data ... ----------------------- SDD Key status : SDData is Ok SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL phone detected Done! thanx all members and supporters. |
The Following 2 Users Say Thank You to Malik Irfan85 For This Useful Post: |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
PIN1/PIN2 CODE | Jon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-26-2012 04:40 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
