06-10-2020, 09:52 | #1 (permalink) |
No Life Poster Join Date: Jan 2014 Location: gsmforum
Member: 2118052 Status: Offline Thanks Meter: 568 | Nokia 105 ta1010 blink Save Name : TA-1010_059Z0X8_12.00.11.vpl Build Finished! Done! Elapsed: 00:05:58 Reconnect Power/Cable! Open VPLfile : TA-1010_059Z0X8_40.00.11.vpl Description : TA-1010 MH DeviceType : TA-1010 ProductCode : 059Z0X8 SoftwareVer : 40.00.11 PPM LangPack : [1] : Gujarati (India) [2] : Kannada (India) [3] : Marathi (India) [4] : Telugu (India) [5] : Punjabi (India) [6] : Tamil (India) [7] : Hindi (India) [8] : Urdu (Islamic Republic of Pakistan) [9] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.20 ] Setting : UserData erase : True Setting : LangPack Only : True 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM23) MODE : NOKIA USB SERIAL PORT : 23 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : C60B3A4083E408DF92BEF0C6E3FE9661 BROM : Run BootLoader ... BROM : BootLoader start Failed! Check device Battery and BSI line! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Write FirmWare [ v1.20 ] Setting : UserData erase : True Setting : LangPack Only : True 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM23) MODE : NOKIA USB SERIAL PORT : 23 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : C60B3A4083E408DF92BEF0C6E3FE9661 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.40.00.11.p1 BOOT : SWR : 40.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : N103.40.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00EF : 0070 : 0016 : 0000 NOR: [Winbond] SF_W25Q32JV NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 40.00.11 [TA-1010] DEV SoftwareVersion : 40.00.11 SWInfo compare result : SAME Load FlashSet : LANG : TA-1010_LANG_PACK_ROM_MH_eMP_40.00.11_001 CUST : TA-1010_CUSTPACK_ROM_MH_eMP_40.00.11_001 JUMP : TA-1010_JUMP_TABLE_MH_eMP_40.00.11_001 Prepare FlashSet : DCR : TA-1010_LANG_PACK_ROM_MH_eMP_40.00.11_001 DCR : TA-1010_CUSTPACK_ROM_MH_eMP_40.00.11_001 DCR : TA-1010_JUMP_TABLE_MH_eMP_40.00.11_001 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : TA-1010_LANG_PACK_ROM_MH_eMP_40.00.11_001 Write : TA-1010_CUSTPACK_ROM_MH_eMP_40.00.11_001 Write : TA-1010_JUMP_TABLE_MH_eMP_40.00.11_001 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1010_LANG_PACK_ROM_MH_eMP_40.00.11_001 Verify : TA-1010_CUSTPACK_ROM_MH_eMP_40.00.11_001 Verify : TA-1010_JUMP_TABLE_MH_eMP_40.00.11_001 Done! Elapsed: 00:00:33 Reconnect Power/Cable! Operation : Write FirmWare [ v1.20 ] Setting : UserData erase : False Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM23) MODE : NOKIA USB SERIAL PORT : 23 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : C60B3A4083E408DF92BEF0C6E3FE9661 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.40.00.11.p1 BOOT : SWR : 40.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : N103.40.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00EF : 0070 : 0016 : 0000 NOR: [Winbond] SF_W25Q32JV NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 40.00.11 [TA-1010] DEV SoftwareVersion : 40.00.11 SWInfo compare result : SAME Load FlashSet : MROM : TA-1010_ROM_eMP_40.00.11 LANG : TA-1010_LANG_PACK_ROM_MH_eMP_40.00.11_001 CUST : TA-1010_CUSTPACK_ROM_MH_eMP_40.00.11_001 JUMP : TA-1010_JUMP_TABLE_MH_eMP_40.00.11_001 VIVA : TA-1010_VIVA_eMP_40.00.11 Prepare FlashSet : DCR : TA-1010_ROM_eMP_40.00.11 DCR : TA-1010_LANG_PACK_ROM_MH_eMP_40.00.11_001 DCR : TA-1010_CUSTPACK_ROM_MH_eMP_40.00.11_001 DCR : TA-1010_JUMP_TABLE_MH_eMP_40.00.11_001 DCR : TA-1010_VIVA_eMP_40.00.11 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 Erase Target Flash Erase done! Write Target Flash Write : TA-1010_ROM_eMP_40.00.11 Write : TA-1010_LANG_PACK_ROM_MH_eMP_40.00.11_001 Write : TA-1010_CUSTPACK_ROM_MH_eMP_40.00.11_001 Write : TA-1010_JUMP_TABLE_MH_eMP_40.00.11_001 Write : TA-1010_VIVA_eMP_40.00.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1010_ROM_eMP_40.00.11 Verify : TA-1010_LANG_PACK_ROM_MH_eMP_40.00.11_001 Verify : TA-1010_CUSTPACK_ROM_MH_eMP_40.00.11_001 Verify : TA-1010_JUMP_TABLE_MH_eMP_40.00.11_001 Verify : TA-1010_VIVA_eMP_40.00.11 Done! Elapsed: 00:00:58 Reconnect Power/Cable! I TRIED MANY FILE FROM SUPPORT BUT STILL BLINKING PROBLEM... I NEED 059Z1B8 LATest FILE. V40 IS ON SUPPORT MAY B COUNTRY VERSION PROBLEM.. |
