10-12-2014, 15:16 | #1 (permalink) |
No Life Poster Join Date: Jun 2011 Location: pakistan
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | nokia 225 bugs...what's solution? Core : v1.97 , MTKx FlashEngine : v5.0 Verify files ... MAUI : RM-1011_ROM_eMP_20.10.11 VIVA : RM-1011_VIVA_eMP_20.10.11 LANG : RM-1011_LANG_PACK_ROM_IJ_eMP_20.10.11_002 CUST : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.10.11_002 JMPT : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_20.10.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 71 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 2AB50A549C643B5E2AACB1523951D7C9 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : PEARL.10.01.11.p3 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Pearl.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 SecureDecrypt : RM-1011_ROM_eMP_20.10.11 SecureDecrypt : RM-1011_VIVA_eMP_20.10.11 SecureDecrypt : RM-1011_LANG_PACK_ROM_IJ_eMP_20.10.11_002 SecureDecrypt : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.10.11_002 SecureDecrypt : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_20.10.11_002 OVRLP : 000069B900000001 PHPID : PEARL.10.01.11.p3 OVRLP : 00004DF900000001 [ERROR] : DA_CBR_NOT_FOUND DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok ERASE_MAUI_INFO : 0x00040000 WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1011_ROM_eMP_20.10.11 Write : RM-1011_LANG_PACK_ROM_IJ_eMP_20.10.11_002 Write : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.10.11_002 Write : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_20.10.11_002 Write : RM-1011_VIVA_eMP_20.10.11 [ERROR] : CODE_DNLOAD : Ok [VERIFY] DONE : RM-1011_ROM_eMP_20.10.11 [VERIFY] DONE : RM-1011_LANG_PACK_ROM_IJ_eMP_20.10.11_002 [VERIFY] DONE : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.10.11_002 [VERIFY] ERROR : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_20.10.11_002 [ERROR] : FORMAT FFS : skipped Rebooting phone now Flashing done! Total flash time : 00:05:36 Reboot phone Ok Connect phone on selected interface... i mentiond error in red letters |
10-12-2014, 23:05 | #3 (permalink) | |
No Life Poster Join Date: Feb 2006
Member: 237256 Status: Offline Thanks Meter: 91 | Quote:
Try tick REPAIR MODE before you start flash again. | |
10-14-2014, 12:45 | #4 (permalink) | |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Quote:
10-14-2014, 13:04 | #6 (permalink) | |
v1.96 same error how to solved problem Core : v1.96 , MTKx FlashEngine : v4.9 Verify files ... MAUI : RM-1011_ROM_eMP_20.10.11 VIVA : RM-1011_VIVA_eMP_20.10.11 LANG : RM-1011_LANG_PACK_ROM_IJ_eMP_20.10.11_002 CUST : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.10.11_002 JMPT : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_20.10.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 9 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : F68020B5B9AB21A1CF20E85F94829AA0 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : PEARL.20.10.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Pearl.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 SecureDecrypt : RM-1011_ROM_eMP_20.10.11 SecureDecrypt : RM-1011_VIVA_eMP_20.10.11 SecureDecrypt : RM-1011_LANG_PACK_ROM_IJ_eMP_20.10.11_002 SecureDecrypt : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.10.11_002 SecureDecrypt : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_20.10.11_002 OVRLP : 000069B900000001 PHPID : PEARL.20.10.11.p1 OVRLP : 00004DF900000001 [ERROR] : DA_CBR_NOT_FOUND DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok ERASE_MAUI_INFO : 0x00040000 WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1011_ROM_eMP_20.10.11 Write : RM-1011_LANG_PACK_ROM_IJ_eMP_20.10.11_002 Write : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.10.11_002 Write : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_20.10.11_002 Write : RM-1011_VIVA_eMP_20.10.11 [ERROR] : CODE_DNLOAD : Ok [VERIFY] DONE : RM-1011_ROM_eMP_20.10.11 [VERIFY] DONE : RM-1011_LANG_PACK_ROM_IJ_eMP_20.10.11_002 [VERIFY] ERROR : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.10.11_002 [ERROR] : SECURITY_BOOTLOADER_IMAGE_SIGNATURE_FAIL Executing FFS FORMAT now... Error Initialize SAFE_FORMAT Mode! [ERROR] Rebooting phone now Flashing done! Total flash time : 00:05:13 Reboot phone Ok Connect phone on selected interface... | |
10-15-2014, 11:18 | #8 (permalink) |
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Format FS done solved my problem V 1.95 Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 9 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : F68020B5B9AB21A1CF20E85F94829AA0 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : PEARL.20.10.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Pearl.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 Executing FFS FORMAT now... FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Connect phone on selected interface... |
11-19-2014, 09:07 | #10 (permalink) |
Freak Poster Join Date: Nov 2006
Member: 399228 Status: Offline Thanks Meter: 66 | Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 609 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 443CB31D2887FF56AE4DC1645004894E BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : PEARL.20.10.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Pearl.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 Executing FFS FORMAT now... FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Connect phone on selected interface... Core : v1.98 , MTKx FlashEngine : v6.0 Verify files ... MAUI : RM-1011_ROM_eMP_20.10.11 VIVA : RM-1011_VIVA_eMP_20.10.11 LANG : RM-1011_LANG_PACK_ROM_MH_eMP_20.10.11_002 CUST : RM-1011_CUSTPACK_ROM_MH_INDIA_IN_eMP_20.10.11_002 JMPT : RM-1011_JUMP_TABLE_MH_INDIA_IN_eMP_20.10.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 609 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 443CB31D2887FF56AE4DC1645004894E BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : PEARL.20.10.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Pearl.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 SecureDecrypt : RM-1011_ROM_eMP_20.10.11 SecureDecrypt : RM-1011_VIVA_eMP_20.10.11 SecureDecrypt : RM-1011_LANG_PACK_ROM_MH_eMP_20.10.11_002 SecureDecrypt : RM-1011_CUSTPACK_ROM_MH_INDIA_IN_eMP_20.10.11_002 SecureDecrypt : RM-1011_JUMP_TABLE_MH_INDIA_IN_eMP_20.10.11_002 OVRLP : 000069B900000001 PHPID : PEARL.20.10.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok ERASE_MAUI_INFO : 0x00040000 WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1011_ROM_eMP_20.10.11 Write : RM-1011_LANG_PACK_ROM_MH_eMP_20.10.11_002 Write : RM-1011_CUSTPACK_ROM_MH_INDIA_IN_eMP_20.10.11_002 Write : RM-1011_JUMP_TABLE_MH_INDIA_IN_eMP_20.10.11_002 Write : RM-1011_VIVA_eMP_20.10.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1011_ROM_eMP_20.10.11 [VERIFY] ERROR : RM-1011_LANG_PACK_ROM_MH_eMP_20.10.11_002 [ERROR] : SECURITY_BOOTLOADER_IMAGE_SIGNATURE_FAIL Executing FFS FORMAT now... Error Initialize SAFE_FORMAT Mode! [ERROR] Rebooting phone now Flashing done! Total flash time : 00:05:40 Reboot phone Ok Connect phone on selected interface... Phone was hanging but was in working condition . I flashed the phone with 1.97. Hang on logo condition then again flashed with 1.98. Still same . Then reformatted and again flashed but hang on logo display light blink and then off. Please help. |
