07-01-2012, 17:11 | #1 (permalink) |
No Life Poster Join Date: Dec 2001 Location: at home Age: 45
Member: 7810 Status: Offline Thanks Meter: 4 | Nokia 500 RM-750 still problem with security my phone was dead after flash I have made RPL and PM backup, tahn erase again flash, upload RPL + PM but I have still error Reading Phone Info.... Connected phone - Nokia N00 Software ver : V 79u_sr1_12w02_1 23-01-12 RM-750 (c) Nokia IMEI : 357924047903562 Ape Ver : 111.020.0059 APE Var : 111.020.0059111.020.0059.32.01111.020.0059.C10.01 APE ADSP: 256 DSP Ver : 79u_12w02_1 APE Test: RM-750_011.010v0.017 PPM : CNT : Product SN : MNI896842 Product code : 059L549 Base Prd.code: 059F2J8 Module code : 0204861 Long Prod.SN : 0 Hardware info======= HWID : 1002 Retu : 40 Tahvo : 00 Batery: 3533 mV APE BT: HCI Version 4 (rev. 192). LMP Version 4 (rev. 16651). Manufacturer 15. APE HW: 256 Lock info =========== IMEI : 357924047903562 IMEI spNet : 3A 75 29 04 74 09 53 06 IMEI svNet : 33 75 29 04 74 09 53 06 F8 Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok SimLock status : Ok Security status : Damaged!!!!! PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! |
07-01-2012, 20:41 | #5 (permalink) |
Member: 7810 Status: Offline Thanks Meter: 4 | have somebody RM-750.PP ? Checking StartUp data ... ----------------------- SDD Key status : SDData is Ok SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 Done! Initializing Tests... IMEI : 357924047903562 , Phone : RM-750 Nokia N00 Get keys... PASSED | ST_SLEEP_X_LOOP_TEST PASSED | ST_UEM_CBUS_IF_TEST PASSED | ST_EAR_DATA_LOOP_TEST PASSED | ST_SIM_CLK_LOOP_TEST PASSED | ST_SIM_LOCK_TEST PASSED | ST_SECURITY_TEST PASSED | ST_PWR_KEY_TEST PASSED | ST_CURRENT_CONS_TEST PASSED | ST_BACKUP_BATT_TEST PASSED | ST_HOOKINT_TEST PASSED | ST_BTEMP_TEST PASSED | ST_MBUS_RX_TX_LOOP_TEST PASSED | ST_KELVIN_BATVOLTAGE_TEST PASSED | ST_KELVIN_VIBRA_TEST PASSED | ST_KELVIN_CAPACITOR_TEST PASSED | ST_KELVIN_MISC_TEST PASSED | ST_KELVIN_CHARGING_TEST PASSED | ST_KELVIN_AUDIO_TEST PASSED | ST_KELVIN_XEAR_TEST PASSED | ST_INTERNAL_ANTENNA_TEST PASSED | ST_USB_CHARGING_TEST PASSED | ST_DIGIMIC_TEST PASSED | ST_HEADSET_AMPLIFIER_TEST PASSED | ST_LED_CONTROLLER_TEST PASSED | ST_RAM_IF_TEST PASSED | ST_CDSP_SLEEPCLOCK_FREQ_TEST PASSED | ST_CDSP_RF_BB_IF_TEST PASSED | ST_CDSP_STROBE_TEST PASSED | ST_CDSP_DIGI_RXTX_IF_TEST PASSED | ST_CDSP_RF_SUPPLY_TEST PASSED | ST_CDSP_PA_ID_PIN_TEST NOT RUN | ST_CDSP_WCDMA_TX_POWER_TEST PASSED | ST_KEYBOARD_STUCK_TEST PASSED | ST_LPRF_IF_TEST PASSED | ST_CAMERA_IF_TEST PASSED | ST_LPRF_AUDIO_LINES_TEST PASSED | ST_MAIN_LCD_IF_TEST PASSED | ST_TOUCH_TEST PASSED | ST_TOUCH_IF_TEST PASSED | ST_BT_WAKEUP_TEST PASSED | ST_WLAN_TEST PASSED | ST_BT_WLAN_COEXISTENCE_TEST PASSED | ST_MASS_MEMORY_IF_TEST PASSED | ST_ACCEL_IF_TEST PASSED | ST_LCD_CONTROLLER_TEST PASSED | ST_VIBRA_TEST NOT RUN | ST_USB_LOOP_TEST PASSED | ST_RADIO_TEST PASSED | ST_MAGNETOMETER_TEST PASSED | ST_USB_CHARGER_TEST PASSED | ST_PROXIMITY_TEST SelfTests end |
07-02-2012, 14:08 | #10 (permalink) |
Member: 7810 Status: Offline Thanks Meter: 4 | again erased, writed same product code which is under battery, than I have wrote RPL, all security and imei ok Switch jaf to FlashMode... FlashMode set Ok Booting phone... Switch jaf to FlashMode... FlashMode set Ok Booting phone... Switch jaf to FlashMode... FlashMode set Ok Booting phone... Switch jaf to FlashMode... FlashMode set Ok Booting phone... Connect phone on selected interface... Read Error Error fetching data... Read fail...! Connect phone on selected interface... Read Uniq key data started... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB PUBLIC ID: D8280004FFFB3C400B4ECEB7489A2FB137E8118E ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 Fetching data, wait... - > Reinsert cable and battery, press powerOn button again - > For X7, E7 - just waiting, near 1 minute - > When BEST start Search Phone - Press PowerOn if needed Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001060 PUBLIC ID: D8280004FFFB3C400B4ECEB7489A2FB137E8118E ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : F4C2F0A6BA76F178E59EBE710A8E1C85F3E122C0 ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Wait, reconneting... rap= D8280004FFFB3C400B4ECEB7489A2FB137E8118E hash= 3AB5DB70B45D23F1ADEEBB5734160706 key= 4051C0F3A02765ADE59D96CCE72CA9C8666AC814 Key file updated... Done! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) SimLock Data found! SimLock key found! WMDRM key found! -> Skip Flash keys Part, for Flash Part use Dead Mode or Fbus Done! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Repair SD procedure started... - > IMEI Validation : IMEI Damaged!!!! - > SDD Info will be wrong! - > RESTORE NPC FIRST Phone Imei: 12345610654321? Key file exists, no need to read... Break SdRepReq (on alive SD) by user Repair fail...! Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) SimLock Data found! SimLock key found! WMDRM key found! -> Skip Flash keys Part, for Flash Part use Dead Mode or Fbus Done! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Repair SD procedure started... - > IMEI Validation : IMEI Damaged!!!! - > SDD Info will be wrong! - > RESTORE NPC FIRST Phone Imei: 12345610654321? Key file exists, no need to read... Accepted SdRepReq (on alive SD) by user Operating mode is OK, no need change... Writing Super Dongle Key... Ok! Done! Will Write CCC/HWC keys now... Using : RM-750.rpl CCC Data found! HWC Data found! Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001060 PUBLIC ID: D8280004FFFB3C400B4ECEB7489A2FB137E8118E ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : F4C2F0A6BA76F178E59EBE710A8E1C85F3E122C0 ADL: Preparing for write certificates... Erase CCC... Ok Writing CCC... Ok Erase HWC... Ok Writing HWC... Ok ADL: Writing Flash certs done! ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot All done, disconneting... Done! Elapsed: 00:00:06 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Repair SD procedure started... - > IMEI Validation : IMEI Damaged!!!! - > SDD Info will be wrong! - > RESTORE NPC FIRST Phone Imei: 12345610654321? Key file exists, no need to read... Break SdRepReq (on alive SD) by user Repair fail...! -> Cert Earse can be done only in DEAD mode, Check DEAD mode, and connect powered OFF phone Checking StartUp data ... ----------------------- IMEI Validation : IMEI Damaged!!!! - > SIMLOCK , SECURITY Info can be wrong! - > Need restore NPC backup or RPL SDD Key status : SDData is Ok SimLock status : SimLock is Ok Security status : Security Damaged!!!!! - > Do Local SX4 or Server SX4 , Upload Tune ( checkbox or manual ) ----------------------- PA_SimLock Version : PA_SL phone detected Done! Read and Check phone data... IMEI DAMAGED : Check impossible, Live status : BAD ------------------------ IMEI Validation : IMEI Damaged!!!! - > SIMLOCK , SECURITY Info can be wrong! - > Need restore NPC backup or RPL SDD Key status : SDData is Ok SimLock status : SimLock is Ok Security status : Security Damaged!!!!! - > Do Local SX4 or Server SX4 , Upload Tune ( checkbox or manual ) ----------------------- PA_SimLock Version : PA_SL phone detected -> Cert Earse can be done only in DEAD mode, Check DEAD mode, and connect powered OFF phone Phone disconected! Connect phone on selected interface... Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) SimLock Data found! SimLock key found! WMDRM key found! Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001060 PUBLIC ID: D8280004FFFB3C400B4ECEB7489A2FB137E8118E ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : F4C2F0A6BA76F178E59EBE710A8E1C85F3E122C0 ADL: Preparing for write certificates... Erase NPC... Ok Writing NPC... Ok Erase CCC... Ok Writing CCC... Ok Erase HWC... Ok Writing HWC... Ok ADL: Writing Flash certs done! ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Wait, reconneting... Writing SimLock Key... Ok! Writing SimLock Data... Ok! Product Code Update : 059L549 SDD Key status : SD Data is Ok SimLock status : SimLock is Ok Security status : Security Damaged!!!!! WMDRM_PD key sent... Ok Done! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Repair SD procedure started... Phone Imei: 357924047903562 Key file exists, no need to read... Break SdRepReq (on alive SD) by user Repair fail...! Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 357924047903562 Key file exists, no need to read... Step 1... Step 2... SX4 Auth fail... - > "Custom Keys" enabled, try again now - > If SDD original - "Use Server Sx4" Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 357924047903562 Use custom key... Step 1... Step 2... Step 3... SX4 Auth - Ok Upload PM checked Uploading RF/Battery tune to phone... Using : RM-750.pm Setting to : 059G733 Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => OK Done! Elapsed: 00:00:02 Upload done Checking StartUp data ... ----------------------- SDD Key status : SDData is Ok SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 Done! |
07-02-2012, 14:09 | #11 (permalink) |
Member: 7810 Status: Offline Thanks Meter: 4 | than I have do sx4 and have wrote backup of PM Field 1 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 4 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 13 write - Ok Record 15 write - Ok Record 16 write - Ok Record 17 write - Ok Record 18 write - Ok Record 19 write - Ok Record 20 write - Ok Record 22 write - Ok Record 23 write - Ok Record 24 write - Ok Record 26 write - Ok Record 27 write - Ok Record 28 write - Ok Record 29 write - Ok Record 30 write - Ok Record 31 write - Ok Record 32 write - Ok Record 33 write - Ok Record 34 write - Ok Record 35 write - Ok Record 36 write - Ok Record 37 write - Ok Record 38 write - Ok Record 39 write - Ok Record 40 write - Ok Record 41 write - Ok Record 42 write - Ok Record 43 write - Ok Record 44 write - Ok Record 45 write - Ok Field 2 Record 0 write - Ok Field 4 Record 1 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 9 write - Ok Record 28 write - Ok Field 8 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Field 11 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Field 12 Record 0 write - Ok Field 31 Record 4 write - Ok Field 44 Record 0 write - Ok Field 50 Record 0 write - Ok Record 1 write - Ok Field 54 Record 0 write - Ok Record 2 write - Ok Field 96 Record 0 write - Ok Record 1 write - Ok Field 117 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 8 write - Ok Record 13 write - Ok Record 14 write - Ok Record 16 write - Ok Field 120 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Field 153 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Field 193 Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 9 write - Ok Field 217 Record 0 write - Ok Field 239 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Field 291 Record 0 write - Ok Field 296 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Field 308 Record 0 write - Error Record 1 write - Error Record 2 write - Error Record 3 write - Error Record 4 write - Error Record 6 write - Error Record 7 write - Error Record 9 write - Error Field 309 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 7 write - Ok Record 8 write - Ok Record 17 write - Ok Record 22 write - Ok Field 313 Record 0 write - Ok Field 322 Record 0 write - Ok Field 329 Record 0 write - Ok Field 334 Record 0 write - Ok Field 341 Record 0 write - Ok Record 3 write - Ok Record 4 write - Ok Field 354 Record 0 write - Ok Field 356 Record 0 write - Ok Field 360 Record 0 write - Ok Record 1 write - Ok Field 369 Record 0 write - Ok Field 382 Record 0 write - Ok Record 1 write - Ok Field 388 Record 0 write - Ok Field 395 Record 0 write - Ok Done! Elapsed: 00:00:02 Operating mode is OK, no need change... Done! Elapsed: 00:00:00 |
07-02-2012, 14:49 | #12 (permalink) |
Member: 7810 Status: Offline Thanks Meter: 4 | here I have flashed 111.020.0067 and still not start correctly ... Core : v1.47 , FlashEngine : v1.5 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-750_111.020.0067_79u_prd.core.fpsx PPM : RM-750_111.020.0067_01.01_Euro1_79u_prd.rofs2.fpsx PPM2 : RM-750_111.020.0067_304.01_default_79u.2012.17_prd.ro fs3.fpsx CNT : RM-750_v0.017_APEONLY_prd.fpsx APE : RM-750_111.020.0067_U01.01_79u.uda.fpsx CNT3 : RM-750_M304.01_default.emmc.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- -> Phone not found.. -> Boot fail... Flashing failed... Core : v1.47 , FlashEngine : v1.5 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-750_111.020.0067_79u_prd.core.fpsx PPM : RM-750_111.020.0067_01.01_Euro1_79u_prd.rofs2.fpsx PPM2 : RM-750_111.020.0067_304.01_default_79u.2012.17_prd.ro fs3.fpsx CNT : RM-750_v0.017_APEONLY_prd.fpsx APE : RM-750_111.020.0067_U01.01_79u.uda.fpsx CNT3 : RM-750_M304.01_default.emmc.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001060 PUBLIC ID: D8280004FFFB3C400B4ECEB7489A2FB137E8118E ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : F4C2F0A6BA76F178E59EBE710A8E1C85F3E122C0 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 357924047903562 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\357924047903562_CR T.rpl ===Flashing [MCU]=== Erase : Processing RM-750_111.020.0067_79u_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing RM-750_111.020.0067_79u_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [SOS+DECOMP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 487 blocks TIME : Write time : 00:00:18 MCU Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [PPM]=== Erase : Processing RM-750_111.020.0067_01.01_Euro1_79u_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-750_111.020.0067_01.01_Euro1_79u_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 210 blocks TIME : Write time : 00:00:08 PPM Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [PPM2]=== Erase : Processing RM-750_111.020.0067_304.01_default_79u.2012.17_prd.ro fs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-750_111.020.0067_304.01_default_79u.2012.17_prd.ro fs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 4 blocks TIME : Write time : 00:00:00 PPM Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [CNT]=== Erase : Processing RM-750_v0.017_APEONLY_prd.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-750_v0.017_APEONLY_prd.fpsx CMT: Writing Hash CERT [SOS*ENO] Total writen 17 blocks TIME : Write time : 00:00:00 CNT Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [APE]=== Erase : Processing RM-750_111.020.0067_U01.01_79u.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-750_111.020.0067_U01.01_79u.uda.fpsx Total writen 550 blocks TIME : Write time : 00:00:24 APE Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [CNT3]=== Erase : Processing RM-750_M304.01_default.emmc.fpsx Partitioning eMMC area.... ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 Partitioning Ok... Partitioning.... Partitioning Ok... Erase : No any region, skip erase TIME : Erase time : 00:00:00 Write : Processing RM-750_M304.01_default.emmc.fpsx Total writen 2520 blocks TIME : Write time : 00:02:33 CNT Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Flashing done! Total flash time : 00:03:29 Reboot phone now... Reading Phone Info.... Connected phone - Nokia N00 Software Info: V 79u_sr1_12w02_3 19-04-12 RM-750 (c) Nokia IMEI: 357924047903562 Ape Version: 111.020.0067 Product code: 059L466 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Set phone to Normal mode... AfterFlash operations done ;D |
01-25-2016, 08:12 | #15 (permalink) |
No Life Poster Join Date: Aug 2015 Location: Bd+
Member: 2441719 Status: Offline Sonork: uninstall Thanks Meter: 2,073 | Reading Phone Info.... Connected phone - Nokia N00 Software ver : V 79u_sr1_12w02_1 23-01-12 RM-750 (c) Nokia IMEI : 1234567891234567? Ape Ver : 111.020.0059 APE Var : 111.020.0059111.020.0059.32.01111.020.0059.C10.01 APE ADSP: 256 DSP Ver : 79u_12w02_1 APE Test: RM-750_011.010v0.017 PPM : CNT : Product SN : MNI896842 Product code : 059L549 Base Prd.code: 059F2J8 Module code : 0204861 Long Prod.SN : 0 Hardware info======= HWID : 1002 Retu : 40 Tahvo : 00 Batery: 3533 mV APE BT: HCI Version 4 (rev. 192). LMP Version 4 (rev. 16651). Manufacturer 15. APE HW: 256 Lock info =========== IMEI : 357924047903562 IMEI spNet : 3A 75 29 04 74 09 53 06 IMEI svNet : 33 75 29 04 74 09 53 06 F8 Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 |
