10-22-2014, 09:43 | #1 (permalink) |
Freak Poster Join Date: Jan 2012 Location: YOUR HEART
Member: 1714224 Status: Offline Thanks Meter: 18 | nokia 5800 after flash vibrate only === SW Version Check === - > REFLASHING or UPGRADE === SW Version Check === ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-356_60.0.003_prd.core.C00 Found 5 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x09E5FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing RM-356_60.0.003_prd.core.C00 Total 510 [510/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*ENO] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:35 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-356_60.0.003_prd.rofs2.V12 Found 1 areas to erase Erasing area 0x07180000 - 0x0915FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-356_60.0.003_prd.rofs2.V12 Total 87 [87/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:06 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-356_60.0.003_C02_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x09160000 - 0x09E5FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-356_60.0.003_C02_prd.rofs3.fpsx Total 11 [11/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:00 PPM Write done ===Flashing [CNT]=== Erase : Processing RM-356_60.0.001_026_000_U01.uda.fpsx Found 1 areas to erase Erasing area 0x09E60000 - 0x0F71FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-356_60.0.001_026_000_U01.uda.fpsx Total 29 [29/0/0] blocks to write, writing... TIME : Write time : 00:00:02 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:45 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5800 XpressMusic Software Info: V ICPR72_10w29_tube1 24-05-11 RM-356 (c) Nokia IMEI: 354216034740658 Ape Version: V 60.0.003 Product code: 0575950 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:01:27 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
10-22-2014, 12:22 | #7 (permalink) |
Member: 1714224 Status: Offline Thanks Meter: 18 | Bsi is ok now i have one way flash with same product but same product flash avial in downgrade version sir if u guide me how to downgrade i ahve make rpl backup only now i can erase full or not |
10-22-2014, 12:54 | #10 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Downgrade Instruction http://forum.gsmhosting.com/vbb/f641...c-how-1363981/ |
10-22-2014, 13:22 | #11 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | White screen in most cases - is BSI problem. If you can't check it correct - maybe better give it someone, who can? Enough simple FBUS check. It will not work , because BSI is faulty. |
10-23-2014, 07:38 | #15 (permalink) |
Member: 1714224 Status: Offline Thanks Meter: 18 | hmmmmmm now last stage is the clear downgrade with same product code all is well but phone proble same i think power ic problem === SW Version Check === - > REFLASHING or UPGRADE === SW Version Check === ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-356_52.0.007_prd.core.C00 Found 5 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x09E5FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing RM-356_52.0.007_prd.core.C00 Total 501 [501/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*ENO] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:33 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-356_52.0.007_prd.rofs2.V14 Found 1 areas to erase Erasing area 0x07180000 - 0x0915FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-356_52.0.007_prd.rofs2.V14 Total 94 [94/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:07 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-356_52.0.007_C01_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x09160000 - 0x09E5FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-356_52.0.007_C01_prd.rofs3.fpsx Total 11 [11/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:00 PPM Write done ===Flashing [CNT]=== Erase : Processing RM-356_52.0.007_026_000_U01.uda.fpsx Found 1 areas to erase Erasing area 0x09E60000 - 0x0F71FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-356_52.0.007_026_000_U01.uda.fpsx Total 29 [29/0/0] blocks to write, writing... TIME : Write time : 00:00:02 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:44 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5800 XpressMusic Software Info: V ICPR72_10w25.3 11-10-10 RM-356 (c) Nokia IMEI: 354216034740658 Ape Version: V 52.0.007 Product code: Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:01:12 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
