06-05-2011, 12:07 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Follow Me If U Can
Member: 304251 Status: Offline Thanks Meter: 789 | nokia 6700 slide contacts retlalier ?? registered to: xxxxxxxxx Connect phone on selected interface... Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 0710020D2F890344A009F8888D0A5B49D966BFA6 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 11.16.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 11.16.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] ADL: Reading certificates... Reading NPC certificate... IMEI : 354321041019581 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Cert Read done! ADL: Reading certificates done! ADL: Close_Session Content: 000300000000060000000600000000 ADL: Reboot Wait, reconneting... SL3 Simlock read ... ok WMDRM read ... ok CRT308 Backup Created NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\354321041019581.rp l All done, Disconnecting Elapsed: 00:00:23 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Initializing Tests... IMEI : 354321041019581 , Phone : RM-576 Nokia 6700s Get keys... PASSED | ST_SLEEP_X_LOOP_TEST PASSED | ST_UEM_CBUS_IF_TEST PASSED | ST_EAR_DATA_LOOP_TEST PASSED | ST_SIM_CLK_LOOP_TEST PASSED | ST_SIM_LOCK_TEST PASSED | ST_SECURITY_TEST PASSED | ST_PWR_KEY_TEST PASSED | ST_CURRENT_CONS_TEST PASSED | ST_HOOKINT_TEST PASSED | ST_BTEMP_TEST PASSED | ST_MBUS_RX_TX_LOOP_TEST PASSED | ST_KELVIN_BATVOLTAGE_TEST PASSED | ST_KELVIN_VIBRA_TEST PASSED | ST_KELVIN_CAPACITOR_TEST PASSED | ST_KELVIN_MISC_TEST PASSED | ST_KELVIN_CHARGING_TEST PASSED | ST_KELVIN_AUDIO_TEST PASSED | ST_KELVIN_XEAR_TEST PASSED | ST_AMB_LIGHT_SENSOR_TEST PASSED | ST_USB_CHARGING_TEST PASSED | ST_IIC_TEST PASSED | ST_DIGIMIC_TEST PASSED | ST_LED_CONTROLLER_TEST PASSED | ST_CDSP_SLEEPCLOCK_FREQ_TEST PASSED | ST_CDSP_RF_BB_IF_TEST PASSED | ST_CDSP_RF_SUPPLY_TEST PASSED | ST_CDSP_TX_IQ_TEST PASSED | ST_CDSP_TXC_DATA_TEST PASSED | ST_CDSP_RX_PLL_PHASE_LOCK_TEST NOT RUN | ST_CDSP_TX_PLL_PHASE_LOCK_TEST NOT RUN | ST_CDSP_WCDMA_TX_POWER_TEST NOT RUN | ST_CDSP_RX_IQ_LOOP_BACK_TEST NOT RUN | ST_CDSP_GSM_TX_POWER_TEST PASSED | ST_KEYBOARD_STUCK_TEST PASSED | ST_LPRF_IF_TEST PASSED | ST_CAMERA_IF_TEST PASSED | ST_SEC_CAMERA_IF_TEST PASSED | ST_LED_FLASH_TEST PASSED | ST_LPRF_AUDIO_LINES_TEST PASSED | ST_MAIN_LCD_IF_TEST PASSED | ST_BT_WAKEUP_TEST PASSED | ST_ACCEL_IF_TEST PASSED | ST_VIBRA_TEST NOT RUN | ST_USB_LOOP_TEST PASSED | ST_RADIO_TEST PASSED | ST_LED_FLASH_IF_TEST SelfTests end Done! Elapsed: 00:00:29 Format File System... Operating mode is OK, no need change... Scanning FS parametres... Checking Data... Detected : 2 drive(s)... Start formating.... Using Series 60 format algorithm... ================================== Formating drive : C now... Step1 : OK Step2 : OK End format... ================================== Formating drive : D now... Step1 : OK Step2 : OK End format... ================================== Done! Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:07 Set phone in Normal mode... Restarting... any help plz ?? |
06-05-2011, 12:10 | #2 (permalink) |
Member: 304251 Status: Offline Thanks Meter: 789 | this flashing log : card found: xxxxxxxx registered to: xxxxxxxx Connect phone on selected interface... Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 0710020D2F890344A009F8888D0A5B49D966BFA6 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 11.16.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 11.16.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] ADL: Reading certificates... Reading NPC certificate... IMEI : 354321041019581 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Cert Read done! ADL: Reading certificates done! ADL: Close_Session Content: 000300000000060000000600000000 ADL: Reboot Wait, reconneting... SL3 Simlock read ... ok WMDRM read ... ok CRT308 Backup Created NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\354321041019581.rp l All done, Disconnecting Elapsed: 00:00:23 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Initializing Tests... IMEI : 354321041019581 , Phone : RM-576 Nokia 6700s Get keys... PASSED | ST_SLEEP_X_LOOP_TEST PASSED | ST_UEM_CBUS_IF_TEST PASSED | ST_EAR_DATA_LOOP_TEST PASSED | ST_SIM_CLK_LOOP_TEST PASSED | ST_SIM_LOCK_TEST PASSED | ST_SECURITY_TEST PASSED | ST_PWR_KEY_TEST PASSED | ST_CURRENT_CONS_TEST PASSED | ST_HOOKINT_TEST PASSED | ST_BTEMP_TEST PASSED | ST_MBUS_RX_TX_LOOP_TEST PASSED | ST_KELVIN_BATVOLTAGE_TEST PASSED | ST_KELVIN_VIBRA_TEST PASSED | ST_KELVIN_CAPACITOR_TEST PASSED | ST_KELVIN_MISC_TEST PASSED | ST_KELVIN_CHARGING_TEST PASSED | ST_KELVIN_AUDIO_TEST PASSED | ST_KELVIN_XEAR_TEST PASSED | ST_AMB_LIGHT_SENSOR_TEST PASSED | ST_USB_CHARGING_TEST PASSED | ST_IIC_TEST PASSED | ST_DIGIMIC_TEST PASSED | ST_LED_CONTROLLER_TEST PASSED | ST_CDSP_SLEEPCLOCK_FREQ_TEST PASSED | ST_CDSP_RF_BB_IF_TEST PASSED | ST_CDSP_RF_SUPPLY_TEST PASSED | ST_CDSP_TX_IQ_TEST PASSED | ST_CDSP_TXC_DATA_TEST PASSED | ST_CDSP_RX_PLL_PHASE_LOCK_TEST NOT RUN | ST_CDSP_TX_PLL_PHASE_LOCK_TEST NOT RUN | ST_CDSP_WCDMA_TX_POWER_TEST NOT RUN | ST_CDSP_RX_IQ_LOOP_BACK_TEST NOT RUN | ST_CDSP_GSM_TX_POWER_TEST PASSED | ST_KEYBOARD_STUCK_TEST PASSED | ST_LPRF_IF_TEST PASSED | ST_CAMERA_IF_TEST PASSED | ST_SEC_CAMERA_IF_TEST PASSED | ST_LED_FLASH_TEST PASSED | ST_LPRF_AUDIO_LINES_TEST PASSED | ST_MAIN_LCD_IF_TEST PASSED | ST_BT_WAKEUP_TEST PASSED | ST_ACCEL_IF_TEST PASSED | ST_VIBRA_TEST NOT RUN | ST_USB_LOOP_TEST PASSED | ST_RADIO_TEST PASSED | ST_LED_FLASH_IF_TEST SelfTests end Done! Elapsed: 00:00:29 Format File System... Operating mode is OK, no need change... Scanning FS parametres... Checking Data... Detected : 2 drive(s)... Start formating.... Using Series 60 format algorithm... ================================== Formating drive : C now... Step1 : OK Step2 : OK End format... ================================== Formating drive : D now... Step1 : OK Step2 : OK End format... ================================== Done! Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:07 Set phone in Normal mode... Restarting... Done! Phone disconected! Connect phone on selected interface... Core version : 1.22 , Rev : 4.5 Selected FlashSettings : Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm576_062.001_prd.core.fpsx PPM : rm576_062.001_30.01_MEA_C_x3_prd.rofs2.fpsx CNT : rm576_062.001_C00.01_DEFAULT_prd.rofs3.fpsx APE : rm576_062.001_ULime001.000_prd.uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 0710020D2F890344A009F8888D0A5B49D966BFA6 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 11.16.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 11.16.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] ADL: phone is in flash mode ===Flashing [MCU]=== Erase : Processing rm576_062.001_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm576_062.001_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 366 blocks TIME : Write time : 00:00:15 MCU Write done ADL: Request programm status NAND status : 00000006 / 00000006 / 00000000 ===Flashing [PPM]=== Erase : Processing rm576_062.001_30.01_MEA_C_x3_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm576_062.001_30.01_MEA_C_x3_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 154 blocks TIME : Write time : 00:00:06 PPM Write done ADL: Request programm status NAND status : 00000006 / 00000006 / 00000000 ===Flashing [CNT]=== Erase : Processing rm576_062.001_C00.01_DEFAULT_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm576_062.001_C00.01_DEFAULT_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 2 blocks TIME : Write time : 00:00:00 CNT Write done ADL: Request programm status NAND status : 00000006 / 00000006 / 00000000 ===Flashing [APE]=== Erase : Processing rm576_062.001_ULime001.000_prd.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm576_062.001_ULime001.000_prd.uda.fpsx Total writen 15 blocks TIME : Write time : 00:00:00 APE Write done ADL: Request programm status NAND status : 00000006 / 00000006 / 00000000 ADL: Close_Session Content: 000300000000060000000600000000 ADL: Reboot Flashing done! Total flash time : 00:00:25 Reboot phone now... Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Resetting LifeTimer Reset Done! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:00:39 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok any help plz still same problem |
06-05-2011, 12:17 | #5 (permalink) |
Member: 304251 Status: Offline Thanks Meter: 789 | card found: xxxxxxx registered to: xxxxxxxx Connect phone on selected interface... Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 0710020D2F890344A009F8888D0A5B49D966BFA6 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 11.16.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 11.16.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] ADL: Reading certificates... Reading NPC certificate... IMEI : 354321041019581 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Cert Read done! ADL: Reading certificates done! ADL: Close_Session Content: 000300000000060000000600000000 ADL: Reboot Wait, reconneting... SL3 Simlock read ... ok WMDRM read ... ok CRT308 Backup Created NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\354321041019581_2n d.rpl All done, Disconnecting Elapsed: 00:00:15 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Checking StartUp data ... ----------------------- SDD Key status : SD Data is Ok SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL3 phone detected Done! |
