06-29-2011, 19:31 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Follow Me If U Can
Member: 304251 Status: Offline Thanks Meter: 789 | nokia 7210 supernova contacts service ?? registered to: xxxxxxxx Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 7210 Supernova Software ver : V 07.23 17-07-09 RM-436 (c) Nokia IMEI : 355231031200886 Ape Ver : APE Var : APE ADSP: DSP Ver : ICPR72_09w17 APE Test: PPM : V 07.23 17-07-09 RM-436 (c) Nokia MA CNT : Content: ma V 07.23 17-07-09 RM-436 (c) Nokia Product SN : DAQ295795 Product code : Base Prd.code: 0563951 Module code : 0203868 Long Prod.SN : 0 Hardware info======= HWID : 1001 Retu : 15 Tahvo : 22 Batery: 3840 mV Camera: CMT BT: 2222-143C APE BT: APE HW: LCDVer: SHARP RF ic : Lock info =========== IMEI : 355231031200886 IMEI spNet : 3A 55 32 01 13 02 80 08 IMEI svNet : 33 55 32 01 13 02 80 48 F0 Unable to read Lock table... CRT308 Backup Created User Code : not set MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! |
06-29-2011, 19:32 | #2 (permalink) |
Member: 304251 Status: Offline Thanks Meter: 789 | Initializing Tests... IMEI : 355231031200886 , Phone : RM-436 Nokia 7210 Supernova Get keys... PASSED | ST_EAR_DATA_LOOP_TEST PASSED | ST_SIM_CLK_LOOP_TEST PASSED | ST_SIM_IO_CTRL_LOOP_TEST PASSED | ST_SLEEP_X_LOOP_TEST PASSED | ST_UEM_CBUS_IF_TEST PASSED | ST_KEYBOARD_STUCK_TEST PASSED | ST_CAMERA_IF_TEST PASSED | ST_BACKUP_BATT_TEST PASSED | ST_LCD_TEST PASSED | ST_LPRF_IF_TEST PASSED | ST_LPRF_AUDIO_LINES_TEST PASSED | ST_CURRENT_CONS_TEST PASSED | ST_RADIO_TEST PASSED | ST_BACKLIGHT_TEST ->ERROR | ST_SIM_LOCK_TEST PASSED | ST_SECURITY_TEST PASSED | ST_BT_WAKEUP_TEST PASSED | ST_HOOKINT_TEST PASSED | ST_TAHVOINT_TEST PASSED | ST_BTEMP_TEST PASSED | ST_IIC_TEST PASSED | ST_EXT_DEVICE_TEST PASSED | ST_CDSP_SLEEPCLK_FREQ_TEST PASSED | ST_CDSP_SLEEPCLOCK_FREQ_TEST PASSED | ST_CDSP_RF_BB_IF_TEST PASSED | ST_CDSP_RF_SUPPLY_TEST NOT RUN | ST_CDSP_TX_PLL_PHASE_LOCK_TEST NOT RUN | ST_CDSP_RX_IQ_LOOP_BACK_TEST NOT RUN | ST_CDSP_GSM_TX_POWER_TEST SelfTests end |
06-29-2011, 19:36 | #3 (permalink) |
Member: 304251 Status: Offline Thanks Meter: 789 | Checking StartUp data ... ----------------------- SDD Key status : SDData Damaged!!!!! SimLock status : SimLock Damaged!!!!! Security status : Security is Ok ----------------------- |
06-29-2011, 21:03 | #4 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | Hello 7210c SL2 Fully Supported instruction How to Fix CS Repair Simlock / Repair SD / after Upload Tune with Custom SX4 Auth Br |
06-29-2011, 21:38 | #5 (permalink) | |
Member: 304251 Status: Offline Thanks Meter: 789 | Quote:
i do all what u said still same : card found: S/N xxxxxx registered to: xxxxxxxxxx Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 7210 Supernova Software ver : V 07.23 17-07-09 RM-436 (c) Nokia IMEI : 355231031200886 Ape Ver : APE Var : APE ADSP: DSP Ver : ICPR72_09w17 APE Test: PPM : V 07.23 17-07-09 RM-436 (c) Nokia MA CNT : Content: ma V 07.23 17-07-09 RM-436 (c) Nokia Product SN : DAQ295795 Product code : Base Prd.code: 0563951 Module code : 0203868 Long Prod.SN : 0 Hardware info======= HWID : 1001 Retu : 15 Tahvo : 22 Batery: 3840 mV Camera: CMT BT: 2222-143C APE BT: APE HW: LCDVer: SHARP RF ic : Lock info =========== IMEI : 355231031200886 IMEI spNet : 3A 55 32 01 13 02 80 08 IMEI svNet : 33 55 32 01 13 02 80 48 F0 Unable to read Lock table... CRT308 Backup Created User Code : not set MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Initializing Tests... IMEI : 355231031200886 , Phone : RM-436 Nokia 7210 Supernova Get keys... PASSED | ST_EAR_DATA_LOOP_TEST PASSED | ST_SIM_CLK_LOOP_TEST PASSED | ST_SIM_IO_CTRL_LOOP_TEST PASSED | ST_SLEEP_X_LOOP_TEST PASSED | ST_UEM_CBUS_IF_TEST PASSED | ST_KEYBOARD_STUCK_TEST PASSED | ST_CAMERA_IF_TEST PASSED | ST_BACKUP_BATT_TEST PASSED | ST_LCD_TEST PASSED | ST_LPRF_IF_TEST PASSED | ST_LPRF_AUDIO_LINES_TEST PASSED | ST_CURRENT_CONS_TEST PASSED | ST_RADIO_TEST PASSED | ST_BACKLIGHT_TEST ->ERROR | ST_SIM_LOCK_TEST PASSED | ST_SECURITY_TEST PASSED | ST_BT_WAKEUP_TEST PASSED | ST_HOOKINT_TEST PASSED | ST_TAHVOINT_TEST PASSED | ST_BTEMP_TEST PASSED | ST_IIC_TEST PASSED | ST_EXT_DEVICE_TEST PASSED | ST_CDSP_SLEEPCLK_FREQ_TEST PASSED | ST_CDSP_SLEEPCLOCK_FREQ_TEST PASSED | ST_CDSP_RF_BB_IF_TEST PASSED | ST_CDSP_RF_SUPPLY_TEST NOT RUN | ST_CDSP_TX_PLL_PHASE_LOCK_TEST NOT RUN | ST_CDSP_RX_IQ_LOOP_BACK_TEST NOT RUN | ST_CDSP_GSM_TX_POWER_TEST SelfTests end Done! Elapsed: 00:00:44 Read Uniq key data started... Power Off phone, Press RdKey and follow instructions Read fail...! Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Set phone in Test mode... Restarting... Done! Read Uniq key data started... Power Off phone, Press RdKey and follow instructions Read fail...! Checking StartUp data ... ----------------------- SDD Key status : SDData Damaged!!!!! SimLock status : SimLock Damaged!!!!! Security status : Security is Ok ----------------------- Done! Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Read Uniq key data started... Power Off phone, Press RdKey and follow instructions Read fail...! Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Nothing to set ... Skip operations Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... UFS S/N 78286 boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Repair SL procedure started... Phone Imei: 355231031200886 Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 0C900007071A7E56BC3ACF945A3B31DA93E33DD8 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... CMT Loader sent, Boot Ok rap= 0C900007071A7E56BC3ACF945A3B31DA93E33DD8 hash= 9DDBFCFE6E73CED7D8C6268C8EB85723 key= 953C7FEFD7993AD358047E26F1B6E233345F4C34 Init Service mode... Wait... Key file updated... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Writing SimLock Data... Ok Writing SimLock Key... Ok Done! Repair SD procedure started... Phone Imei: 355231031200886 Key file exists, no need to read... Operating mode is OK, no need change... Writing Super Dongle Key... Ok Done! Uploading RF/Battery tune to phone... Using : RM-436.pm Operating mode is OK, no need change... Field 1 Record 0 write - Error Record 2 write - Error Record 3 write - Error Record 4 write - Error Record 6 write - Error Record 7 write - Error Record 10 write - Error Record 11 write - Error Record 14 write - Error Record 17 write - Error Field 309 Record 0 write - Error Record 1 write - Error Record 2 write - Error Record 4 write - Error Record 5 write - Error Record 7 write - Error Record 8 write - Error Record 17 write - Error Record 22 write - Error Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED Done! Elapsed: 00:00:19 Uploading RF/Battery tune to phone... Using : RM-436.pm Operating mode is OK, no need change... Field 1 Record 0 write - Error Record 2 write - Error Record 3 write - Error Record 4 write - Error Record 6 write - Error Record 7 write - Error Record 10 write - Error Record 11 write - Error Record 14 write - Error Record 17 write - Error Field 309 Record 0 write - Error Record 1 write - Error Record 2 write - Error Record 4 write - Error Record 5 write - Error Record 7 write - Error Record 8 write - Error Record 17 write - Error Record 22 write - Error Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED Done! Elapsed: 00:00:19 Initializing Tests... IMEI : 355231031200886 , Phone : RM-436 Nokia 7210 Supernova Get keys... PASSED | ST_EAR_DATA_LOOP_TEST PASSED | ST_SIM_CLK_LOOP_TEST PASSED | ST_SIM_IO_CTRL_LOOP_TEST PASSED | ST_SLEEP_X_LOOP_TEST PASSED | ST_UEM_CBUS_IF_TEST PASSED | ST_KEYBOARD_STUCK_TEST PASSED | ST_CAMERA_IF_TEST PASSED | ST_BACKUP_BATT_TEST PASSED | ST_LCD_TEST PASSED | ST_LPRF_IF_TEST PASSED | ST_LPRF_AUDIO_LINES_TEST PASSED | ST_CURRENT_CONS_TEST PASSED | ST_RADIO_TEST PASSED | ST_BACKLIGHT_TEST PASSED | ST_SIM_LOCK_TEST MINOR | ST_SECURITY_TEST PASSED | ST_BT_WAKEUP_TEST PASSED | ST_HOOKINT_TEST PASSED | ST_TAHVOINT_TEST PASSED | ST_BTEMP_TEST PASSED | ST_IIC_TEST PASSED | ST_EXT_DEVICE_TEST PASSED | ST_CDSP_SLEEPCLK_FREQ_TEST NOT EXECUTED | ST_CDSP_SLEEPCLOCK_FREQ_TEST NOT EXECUTED | ST_CDSP_RF_BB_IF_TEST NOT EXECUTED | ST_CDSP_RF_SUPPLY_TEST NOT EXECUTED | ST_CDSP_TX_PLL_PHASE_LOCK_TEST NOT EXECUTED | ST_CDSP_RX_IQ_LOOP_BACK_TEST NOT EXECUTED | ST_CDSP_GSM_TX_POWER_TEST SelfTests end Done! Elapsed: 00:00:41 Connect phone on selected interface... Core version : 1.23 , Rev : 4.8 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm436__07.23.mcusw PPM : rm436__07.23.ppm_ma CNT : rm436__07.23.image_ma Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 0C900007071A7E56BC3ACF945A3B31DA93E33DD8 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm436__07.23.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0119FFFF, NOR, CMT Result: 0000 Erasing area 0x011A0000 - 0x0133FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:59 Write : Processing rm436__07.23.mcusw Total 1170 [1170/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:00:55 MCU Write done ===Flashing [PPM]=== Erase : Processing rm436__07.23.ppm_ma Found 1 areas to erase Erasing area 0x01340000 - 0x01BDFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:53 Write : Processing rm436__07.23.ppm_ma Total 387 [387/0/0] blocks to write, writing... TIME : Write time : 00:00:18 PPM Write done ===Flashing [CNT]=== Erase : Processing rm436__07.23.image_ma Found 2 areas to erase Erasing area 0x01BE0000 - 0x01F7FFFF, NOR, CMT Result: 0000 Erasing area 0x01F80000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:04:22 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm436__07.23.image_ma Total 1296 [1296/0/0] blocks to write, writing... TIME : Write time : 00:01:03 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:09:33 Reboot phone now... Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:10:22 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Initializing Tests... IMEI : 355231031200886 , Phone : RM-436 Nokia 7210 Supernova Get keys... PASSED | ST_EAR_DATA_LOOP_TEST PASSED | ST_SIM_CLK_LOOP_TEST PASSED | ST_SIM_IO_CTRL_LOOP_TEST PASSED | ST_SLEEP_X_LOOP_TEST PASSED | ST_UEM_CBUS_IF_TEST PASSED | ST_KEYBOARD_STUCK_TEST PASSED | ST_CAMERA_IF_TEST PASSED | ST_BACKUP_BATT_TEST PASSED | ST_LCD_TEST PASSED | ST_LPRF_IF_TEST PASSED | ST_LPRF_AUDIO_LINES_TEST PASSED | ST_CURRENT_CONS_TEST PASSED | ST_RADIO_TEST PASSED | ST_BACKLIGHT_TEST PASSED | ST_SIM_LOCK_TEST ->ERROR | ST_SECURITY_TEST PASSED | ST_BT_WAKEUP_TEST PASSED | ST_HOOKINT_TEST PASSED | ST_TAHVOINT_TEST PASSED | ST_BTEMP_TEST PASSED | ST_IIC_TEST PASSED | ST_EXT_DEVICE_TEST PASSED | ST_CDSP_SLEEPCLK_FREQ_TEST NOT EXECUTED | ST_CDSP_SLEEPCLOCK_FREQ_TEST NOT EXECUTED | ST_CDSP_RF_BB_IF_TEST NOT EXECUTED | ST_CDSP_RF_SUPPLY_TEST NOT RUN | ST_CDSP_TX_PLL_PHASE_LOCK_TEST NOT RUN | ST_CDSP_RX_IQ_LOOP_BACK_TEST NOT RUN | ST_CDSP_GSM_TX_POWER_TEST SelfTests end Done! Elapsed: 00:00:21 Phone disconected! Connect phone on selected interface... | |
06-29-2011, 21:45 | #6 (permalink) |
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | hello u Forgot 1 operation Custom SX4 and after Upload Tune ( Do this Now ) i hope its Help u more http://www.youtube.com/watch?v=lCOMVQxv1Eg Br Last edited by Mohsin-*; 06-29-2011 at 21:51. |
