10-27-2021, 07:29 | #1 (permalink) |
Insane Poster Join Date: Dec 2006
Member: 410375 Status: Offline Thanks Meter: 28 | ta-1030 after rest contact service Card found : 57531B8F , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.15 Operation : Reset Settings [ v1.15 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM4) MODE : NOKIA USB SERIAL PORT : 4 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : E569DED5F4BAEF59D9D2A7948438342D BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : RETRO.11.02.11.p1 BOOT : SWR : 11.02.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : RETRO.11.02.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8B NOR: 00EF : 0060 : 0018 : 0000 NOR: [WINBOND] W25Q128FW NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00CD0000 : 0x00324000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:45 Reconnect Power/Cable! |
10-27-2021, 07:46 | #2 (permalink) |
Member: 410375 Status: Offline Thanks Meter: 28 | same problem Card found : 57531B8F , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20 Open VPLfile : TA-1030_059Z014_11.02.11.vpl Description : TA-1030 IJ DeviceType : TA-1030 ProductCode : 059Z014 SoftwareVer : 11.02.11 PPM LangPack : [1] : Urdu (Islamic Republic of Pakistan) [2] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.20 ] Setting : UserData erase : False Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM4) MODE : NOKIA USB SERIAL PORT : 4 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : E569DED5F4BAEF59D9D2A7948438342D BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : RETRO.11.02.11.p1 BOOT : SWR : 11.02.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : RETRO.11.02.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8B NOR: 00EF : 0060 : 0018 : 0000 NOR: [WINBOND] W25Q128FW NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 11.02.11 [TA-1030] DEV SoftwareVersion : 11.02.11 SWInfo compare result : SAME Load FlashSet : MROM : TA-1030_ROM_eMP_11.02.11 LANG : TA-1030_LANG_PACK_ROM_IJ_eMP_11.02.11_001 CUST : TA-1030_CUSTPACK_ROM_IJ_eMP_11.02.11_001 JUMP : TA-1030_JUMP_TABLE_IJ_eMP_11.02.11_001 VIVA : TA-1030_VIVA_eMP_11.02.11 Prepare FlashSet : DCR : TA-1030_ROM_eMP_11.02.11 DCR : TA-1030_LANG_PACK_ROM_IJ_eMP_11.02.11_001 DCR : TA-1030_CUSTPACK_ROM_IJ_eMP_11.02.11_001 DCR : TA-1030_JUMP_TABLE_IJ_eMP_11.02.11_001 DCR : TA-1030_VIVA_eMP_11.02.11 Prepare Target SDS : OK : 0x00FF4000 : 0x0000C000 Erase Target Flash Erase done! Write Target Flash Write : TA-1030_ROM_eMP_11.02.11 Write : TA-1030_LANG_PACK_ROM_IJ_eMP_11.02.11_001 Write : TA-1030_CUSTPACK_ROM_IJ_eMP_11.02.11_001 Write : TA-1030_JUMP_TABLE_IJ_eMP_11.02.11_001 Write : TA-1030_VIVA_eMP_11.02.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1030_ROM_eMP_11.02.11 Verify : TA-1030_LANG_PACK_ROM_IJ_eMP_11.02.11_001 Verify : TA-1030_CUSTPACK_ROM_IJ_eMP_11.02.11_001 Verify : TA-1030_JUMP_TABLE_IJ_eMP_11.02.11_001 Verify : TA-1030_VIVA_eMP_11.02.11 Done! Elapsed: 00:02:48 Reconnect Power/Cable! |
10-27-2021, 14:45 | #3 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 36
Member: 2371500 Status: Offline Thanks Meter: 5,834 | Very important how to avoid contact service in new nokia phone CHECK ABOVE THREAD WHAT FLASH FILE U USED |
10-27-2021, 17:03 | #5 (permalink) |
Member: 410375 Status: Offline Thanks Meter: 28 | ta 1030 after rest to contract service Card found : 57531B8F , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20 Open VPLfile : TA-1030_059X9Q4_11.02.11.vpl Description : TA-1030 ME DeviceType : TA-1030 ProductCode : 059X9Q4 SoftwareVer : 11.02.11 PPM LangPack : [1] : Malay (Malaysia) [2] : Indonesian (Indonesia) [3] : Chinese (S) [4] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.20 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM7) MODE : NOKIA USB SERIAL PORT : 7 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : E569DED5F4BAEF59D9D2A7948438342D BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : RETRO.11.02.11.p1 BOOT : SWR : 11.02.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : RETRO.11.02.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8B NOR: 00EF : 0060 : 0018 : 0000 NOR: [WINBOND] W25Q128FW NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 11.02.11 [TA-1030] DEV SoftwareVersion : 11.02.11 SWInfo compare result : SAME Load FlashSet : MROM : TA-1030_ROM_eMP_11.02.11 LANG : TA-1030_LANG_PACK_ROM_ME_eMP_11.02.11_001 CUST : TA-1030_CUSTPACK_ROM_ME_eMP_11.02.11_001 JUMP : TA-1030_JUMP_TABLE_ME_eMP_11.02.11_001 VIVA : TA-1030_VIVA_eMP_11.02.11 Prepare FlashSet : DCR : TA-1030_ROM_eMP_11.02.11 DCR : TA-1030_LANG_PACK_ROM_ME_eMP_11.02.11_001 DCR : TA-1030_CUSTPACK_ROM_ME_eMP_11.02.11_001 DCR : TA-1030_JUMP_TABLE_ME_eMP_11.02.11_001 DCR : TA-1030_VIVA_eMP_11.02.11 Prepare Target SDS : OK : 0x00FF4000 : 0x0000C000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : TA-1030_ROM_eMP_11.02.11 Write : TA-1030_LANG_PACK_ROM_ME_eMP_11.02.11_001 Write : TA-1030_CUSTPACK_ROM_ME_eMP_11.02.11_001 Write : TA-1030_JUMP_TABLE_ME_eMP_11.02.11_001 Write : TA-1030_VIVA_eMP_11.02.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1030_ROM_eMP_11.02.11 Verify : TA-1030_LANG_PACK_ROM_ME_eMP_11.02.11_001 Verify : TA-1030_CUSTPACK_ROM_ME_eMP_11.02.11_001 Verify : TA-1030_JUMP_TABLE_ME_eMP_11.02.11_001 Verify : TA-1030_VIVA_eMP_11.02.11 Done! Elapsed: 00:03:06 Reconnect Power/Cable! Open VPLfile : TA-1030_059Z0X8_40.02.11.vpl Description : TA-1030 IC DeviceType : TA-1030 ProductCode : 059Z0X8 SoftwareVer : 40.02.11 PPM LangPack : [1] : Hindi (India) [2] : Urdu (Islamic Republic of Pakistan) [3] : Arabic (Saudi Arabia) [4] : Portuguese (Portugal) [5] : French (France) [6] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.20 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM7) MODE : NOKIA USB SERIAL PORT : 7 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : E569DED5F4BAEF59D9D2A7948438342D BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : RETRO.11.02.11.p1 BOOT : SWR : 11.02.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : RETRO.11.02.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8B NOR: 00EF : 0060 : 0018 : 0000 NOR: [WINBOND] W25Q128FW NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 40.02.11 [TA-1030] DEV SoftwareVersion : 11.02.11 SWInfo compare result : DEVICE SW ( Major version ) is LOWER, than in VPL! Load FlashSet : MROM : TA-1030_ROM_eMP_40.02.11 LANG : TA-1030_LANG_PACK_ROM_IC_eMP_40.02.11_001 CUST : TA-1030_CUSTPACK_ROM_IC_eMP_40.02.11_001 JUMP : TA-1030_JUMP_TABLE_IC_eMP_40.02.11_001 VIVA : TA-1030_VIVA_eMP_40.02.11 Prepare FlashSet : DCR : TA-1030_ROM_eMP_40.02.11 DCR : TA-1030_LANG_PACK_ROM_IC_eMP_40.02.11_001 DCR : TA-1030_CUSTPACK_ROM_IC_eMP_40.02.11_001 DCR : TA-1030_JUMP_TABLE_IC_eMP_40.02.11_001 DCR : TA-1030_VIVA_eMP_40.02.11 Prepare Target SDS : OK : 0x00FF4000 : 0x0000C000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : TA-1030_ROM_eMP_40.02.11 Write : TA-1030_LANG_PACK_ROM_IC_eMP_40.02.11_001 Write : TA-1030_CUSTPACK_ROM_IC_eMP_40.02.11_001 Write : TA-1030_JUMP_TABLE_IC_eMP_40.02.11_001 Write : TA-1030_VIVA_eMP_40.02.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1030_ROM_eMP_40.02.11 Verify : TA-1030_LANG_PACK_ROM_IC_eMP_40.02.11_001 Verify : TA-1030_CUSTPACK_ROM_IC_eMP_40.02.11_001 Verify : TA-1030_JUMP_TABLE_IC_eMP_40.02.11_001 Verify : TA-1030_VIVA_eMP_40.02.11 Done! Elapsed: 00:02:58 Reconnect Power/Cable! Operation : Reset Settings [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM7) MODE : NOKIA USB SERIAL PORT : 7 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : E569DED5F4BAEF59D9D2A7948438342D BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : RETRO.40.02.11.p1 BOOT : SWR : 40.02.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : RETRO.40.02.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8B NOR: 00EF : 0060 : 0018 : 0000 NOR: [WINBOND] W25Q128FW NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00CF0000 : 0x00304000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:45 Reconnect Power/Cable! notworking original file TA-1030_CUSTPACK_ROM_IJ_eMP_11.02 |
