11-27-2014, 13:40 | #1 (permalink) |
No Life Poster Join Date: Feb 2011 Location: Android Modding
Member: 1507693 Status: Offline Thanks Meter: 131 | nokia X2 RM-709 simlock Damaged asks for Restriction code |
11-28-2014, 11:54 | #4 (permalink) |
Member: 1507693 Status: Offline Thanks Meter: 131 | Done via simlock restore by infinity BEST I Click on RESTORE SIMLOCK log Code: Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000000000000022000509200C0000 CPU ID : BroadCom 21351 , Features : Dead-Test, USBRPL, FullUSB EM0 ID: 00005361 PUBLIC ID: 00000000007220272B51FD9A7E0F3225CAD401D6 ASIC MODE ID: 00 ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E ROM ID: DE56D582BDDE7A3A Use BCM21351_usb2nd.fg , Rev : 2.1 Ver : 12.8.0 Processing RAWLOADER... FLIC : 00300020 Req : XSR 1.6 Use BCM21351_XSR16_usbalg.fg , Rev : 2.1 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 37955B6FC432998EF0DB240E332228384D19ED09 ADL: phone is in flash mode Reading NPC certificate... IMEI : 351689059921366 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\351689059921366_CRT_2nd.rpl Trying read spr block , wait ... Get phone data... Get flash data... SPR Read Ok! Spr saved to : 351689059921366.spr ADL: Close_Session Content: 000300000000080000000700000000 ADL: Reboot Processing SimLock extraction.... Checking readed data, wait few seconds ID_INFO : Not Found (Minor) #1st block Ok [SLT] #2nd block Ok [SHA] #3rd block Ok [SIG] Initial data found, start fun... SimLock RPL saved : c:\InfinityBox\BEST\Backup\Cert\351689059921366_SIM.rpl SimLock PM saved : c:\InfinityBox\BEST\Backup\Cert\351689059921366_SIM.pm Done! Code: Will Write RPL keys now... Check RPL file... SIMLOCK Data found! SIMLOCK KEY found! Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000000000000022000509200C0000 CPU ID : BroadCom 21351 , Features : Dead-Test, USBRPL, FullUSB EM0 ID: 00005361 PUBLIC ID: 00000000007220272B51FD9A7E0F3225CAD401D6 ASIC MODE ID: 00 ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E ROM ID: DE56D582BDDE7A3A Use BCM21351_usb2nd.fg , Rev : 2.1 Ver : 12.8.0 Processing RAWLOADER... FLIC : 00300020 Req : XSR 1.6 Use BCM21351_XSR16_usbalg.fg , Rev : 2.1 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 37955B6FC432998EF0DB240E332228384D19ED09 ADL: Preparing for write certificates... ADL: Writing Flash certs done! :) ADL: Close_Session Content: 000300000000080000000700000000 ADL: Reboot Wait, reconneting... Writing SimLock Key... Ok! Writing SimLock Data... Ok! SDD Key status : SD Data is Ok SimLock status : SimLock is Ok Security status : Security is Ok Done! Code: Reading Phone Info.... Connected phone - X2-01 Software ver : V 08.75 11-01-12 RM-709 (c) Nokia IMEI : 351689059921366 XappVer : 000007B2 PPM : V 08.75 11-01-12 RM-709 (c) Nokia MS CNT : Content: ms_059H465 V 08.75 11-01-12 RM-709 (c) Nokia Product SN : CJR290162 Product code : 059G230 Base Prd.code: 059B859 Module code : 0204674 Long Prod.SN : 0 Hardware info======= HWID : 1001 Batery: 3712 mV CMT BT: 2.31-SP2.31 LCDVer: SEIKO Lock info =========== IMEI : 351689059921366 IMEI spNet : 3A 15 86 09 95 29 31 06 IMEI svNet : 33 15 86 09 95 29 31 46 F4 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Not Present SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Phone disconected! Connect phone on selected interface... I KNOW THIS IS OLD NEWS TO SENIORS BUT I THANK YOU INFINITY TEAM FOR GREAT WORK |
The Following 3 Users Say Thank You to Fragga For This Useful Post: |
