06-16-2011, 18:25 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: india Age: 37
Member: 1146038 Status: Offline Thanks Meter: 196 | pls... help me in 5130.. Code: Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm495__07.97.mcusw PPM : rm495__07.97.ppm_mh CNT : rm495__07.97.image_CTV_INDIA_HINDI_Wsilver_REFRESH Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 1700020BB6D646501413228CD570048216CEA306 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:08 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 Waiting for response: 26 Waiting for response: 25 Waiting for response: 24 Waiting for response: 23 Waiting for response: 22 Waiting for response: 21 Waiting for response: 20 Waiting for response: 19 Waiting for response: 18 Waiting for response: 17 Waiting for response: 16 Waiting for response: 15 Waiting for response: 14 Waiting for response: 13 Waiting for response: 12 Waiting for response: 11 Waiting for response: 10 Waiting for response: 9 Waiting for response: 8 Waiting for response: 7 Waiting for response: 6 Waiting for response: 5 Waiting for response: 4 Waiting for response: 3 Waiting for response: 2 Waiting for response: 1 -> Phone not found... :( -> Error while flashing... :( Phone disconected! |
06-17-2011, 06:13 | #3 (permalink) |
Member: 1146038 Status: Offline Thanks Meter: 196 | i will try with fbus ut saME....? Code: registered to: arun Connect phone on selected interface... UFS S/N 16338 boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 5130c-2 Software ver : V 07.97 13-09-10 RM-495 (c) Nokia IMEI : 351521049015662 Ape Ver : APE Var : APE ADSP: DSP Ver : ICPR72_10w01 APE Test: PPM : V 07.97 13-09-10 RM-495 (c) Nokia MH CNT : Content: mh_red V 07.97 13-09-10 RM-495 (c) Nokia Product SN : IDV877152 Product code : 0591480 Base Prd.code: 0578151 Module code : 0204024 Long Prod.SN : 0 Hardware info======= HWID : 2002 Retu : 16 Tahvo : 22 Batery: 4831 mV Camera: CMT BT: 2222-302 APE BT: APE HW: LCDVer: SEIKO RF ic : 06540601 Lock info =========== IMEI : 351521049015662 IMEI spNet : IMEI svNet : Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Backup Certificates now... CRT308 Backup Created... :) Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 1700020BB6D646501413228CD570048216CEA306 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 240000EC , CMT , NOR CMT Flash ID : 240000EC < UNKNOW [NOT IN BASE] FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 917F11196FDB7378C18EF7260698CA4489DCA02700 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 351521049015662 CMT : Read CCC certificate... Cert size : 30600 byte(s) CMT : Read HWC certificate... Cert size : 20480 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\351521049015662.rpl Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Format File System... Operating mode is OK, no need change... Scanning FS parametres... Checking Data... Detected : 1 drive(s)... Start formating.... Using Series 40 format algorithm... ================================== Formating drive : C now... Step1 : Error Step2 : Error End format... ================================== Info : Reflash CNT only for repair content and user certificates Done! Format File System... Operating mode is OK, no need change... Scanning FS parametres... Checking Data... Detected : 1 drive(s)... Start formating.... Using Series 40 format algorithm... ================================== Formating drive : C now... Step1 : Error Step2 : Error End format... ================================== Info : Reflash CNT only for repair content and user certificates Done! Initializing Tests... IMEI : 351521049015662 , Phone : RM-495 Nokia 5130c-2 Get keys... PASSED | ST_EAR_DATA_LOOP_TEST PASSED | ST_SIM_CLK_LOOP_TEST PASSED | ST_SIM_IO_CTRL_LOOP_TEST PASSED | ST_SLEEP_X_LOOP_TEST PASSED | ST_UEM_CBUS_IF_TEST PASSED | ST_KEYBOARD_STUCK_TEST PASSED | ST_CAMERA_IF_TEST PASSED | ST_BACKUP_BATT_TEST PASSED | ST_LCD_TEST PASSED | ST_LPRF_IF_TEST PASSED | ST_LPRF_AUDIO_LINES_TEST PASSED | ST_CURRENT_CONS_TEST PASSED | ST_RADIO_TEST PASSED | ST_BACKLIGHT_TEST PASSED | ST_SIM_LOCK_TEST PASSED | ST_SECURITY_TEST PASSED | ST_BT_WAKEUP_TEST PASSED | ST_HOOKINT_TEST PASSED | ST_TAHVOINT_TEST PASSED | ST_BTEMP_TEST PASSED | ST_IIC_TEST PASSED | ST_EXT_DEVICE_TEST PASSED | ST_CDSP_SLEEPCLK_FREQ_TEST NOT EXECUTED | ST_CDSP_SLEEPCLOCK_FREQ_TEST NOT EXECUTED | ST_CDSP_RF_BB_IF_TEST NOT EXECUTED | ST_CDSP_RF_SUPPLY_TEST NOT EXECUTED | ST_CDSP_TX_PLL_PHASE_LOCK_TEST NOT EXECUTED | ST_CDSP_RX_IQ_LOOP_BACK_TEST NOT EXECUTED | ST_CDSP_GSM_TX_POWER_TEST SelfTests end Done! Elapsed: 00:00:32 Core version : 1.20 , Rev : 4.0 Selected FlashSettings : Files Set for Flashing : MCU : rm495__07.97.mcusw PPM : rm495__07.97.ppm_mh CNT : rm495__07.97.image_CTV_INDIA_HINDI_Wsilver_REFRESH Check FlashFiles, Please, wait... -> Check SW version... FlashFile version : 07.97 Phone version : 07.97 13-09-10 RM-495 (c) Nokia -> Check SW version : Reflash Backup enabled, Will read Certificates now... CRT308 Backup Created... :) Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 1700020BB6D646501413228CD570048216CEA306 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 240000EC , CMT , NOR CMT Flash ID : 240000EC < UNKNOW [NOT IN BASE] FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 917F11196FDB7378C18EF7260698CA4489DCA02700 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 351521049015662 CMT : Read CCC certificate... Cert size : 30600 byte(s) CMT : Read HWC certificate... Cert size : 20480 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\351521049015662_2nd.rpl Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 1700020BB6D646501413228CD570048216CEA306 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 240000EC , CMT , NOR CMT Flash ID : 240000EC < UNKNOW [NOT IN BASE] FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 917F11196FDB7378C18EF7260698CA4489DCA02700 Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm495__07.97.mcusw Found 6 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x000BFFFF CMT , NOR , Area : 0x000C0000 - 0x0013FFFF CMT , NOR , Area : 0x00140000 - 0x0137FFFF CMT , NOR , Area : 0x01380000 - 0x0151FFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:14 Transmission mode : Dual (Ddr, TX2) Write : Processing rm495__07.97.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] Total writen 1169 blocks TIME : Write time : 00:02:15 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm495__07.97.ppm_mh Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01520000 - 0x01DBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:29 Transmission mode : Dual (Ddr, TX2) Write : Processing rm495__07.97.ppm_mh Total writen 450 blocks TIME : Write time : 00:00:52 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm495__07.97.image_CTV_INDIA_HINDI_Wsilver_REFRESH Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01DC0000 - 0x0215FFFF CMT , NOR , Area : 0x02160000 - 0x03FBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:02:27 Transmission mode : Dual (Ddr, TX2) Write : Processing rm495__07.97.image_CTV_INDIA_HINDI_Wsilver_REFRESH Total writen 536 blocks TIME : Write time : 00:01:02 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 5130c-2 Software Info: V 07.97 13-09-10 RM-495 (c) Nokia IMEI: 351521049015662 Product code: 0591480 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Set phone in Normal mode... Restarting... Done! Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
06-17-2011, 11:06 | #6 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | |
