10-23-2014, 13:44 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: hall road pakistan
Member: 782530 Status: Offline Thanks Meter: 8,136 | Rm-1030 After Flash Dead Now Cant Conect When Conect Just sound ...... Here Is Logs Core : v1.97 , NXP FlashEngine : v3.4 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : RM1030_V2_1.2.3.21_059W170_IMEA_PK_V2_variant.img Ok, Set : RM1030_V2_1.2.3.21_boot.img Ok, Set : RM1030_V2_1.2.3.21_cache.img Ok, Set : RM1030_V2_1.2.3.21_emmc_appsboot.mbn Ok, Set : RM1030_V2_1.2.3.21_emmc_appsboothd.mbn Ok, Set : RM1030_V2_1.2.3.21_fat.bin Ok, Set : RM1030_V2_1.2.3.21_oemsbl.mbn Ok, Set : RM1030_V2_1.2.3.21_oemsblhd.mbn Ok, Set : RM1030_V2_1.2.3.21_persist.img Ok, Set : RM1030_V2_1.2.3.21_preload.img Ok, Set : RM1030_V2_1.2.3.21_qcsbl.mbn Ok, Set : RM1030_V2_1.2.3.21_qcsblhd_cfgdata.mbn Ok, Set : RM1030_V2_1.2.3.21_recovery.img Ok, Set : RM1030_V2_1.2.3.21_system.img Ok, Set : RM1030_V2_1.2.3.21_udisk.bin Ok, Set : RM1030_V2_1.2.3.21_userdata.img File HW revision is : HW Revision V2 HW Revision V2 files flashing accepted by user Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Press and hold 'Volume Down' and 'Power' buttons 3. When feel short vibra - release 'Power' button, but keep hold 'Volume Down' button 4. Insert USB cable and hold button, until phone will be detected Or 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Connect Ok Get Phone Initial Info Product : MSM7627A Version : 0.5 Serial : 2C4AD492 Processing : RM1030_V2_1.2.3.21_qcsblhd_cfgdata.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_qcsbl.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_oemsblhd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_oemsbl.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM1030_V2_1.2.3.21_emmc_appsboothd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_emmc_appsboot.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM1030_V2_1.2.3.21_boot.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_recovery.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_persist.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_fat.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_system.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_cache.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_userdata.img Erase Partition : USERDATA Partition Erase Done Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_udisk.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_preload.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_059W170_IMEA_PK_V2_variant.img Init Ok, send data ... Data sent, start flashing Region Flash Done Rebooting phone now Flashing done! Total flash time : 00:05:40 Reboot phone Ok |
10-23-2014, 13:54 | #3 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello. Did you read message, which BEST write 2 times? Did you even try understand - what software ask? Ok, I will explain - It warn 2 TIMES about check which HW phone have via product code. You ignore that and killed your V1 phone by flashing V2 firmware. Now jtag and repair boot. |
The Following User Says Thank You to Dzirt For This Useful Post: |
10-23-2014, 13:55 | #4 (permalink) |
10-23-2014, 14:04 | #5 (permalink) | |
Member: 782530 Status: Offline Thanks Meter: 8,136 | Quote:
i missing i used worng way to i kill my phone anyway thanks you very much brother. | |
