12-18-2013, 05:50 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: gadgets works station
Member: 1019591 Status: Offline Sonork: 100.1592733 Thanks Meter: 634 | rm944 cant flash but always stuck in this Code: --- Insert USB cable now! --- Wait for phone... Phone found! [ 1027 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL failed! (CMD not accepted, 0xAA) Check Power / Cable! BootLoader Init Failed (HW/Connection Error) Connect phone on selected interface... |
12-18-2013, 06:20 | #2 (permalink) | |
No Life Poster Join Date: Feb 2008 Location: pakistan hafizabad
Member: 700741 Status: Offline Sonork: 100.1617188 Thanks Meter: 409 | Quote:
direct sold point & insert bettrey 100000% done ur mobile here is log Connect phone on selected interface... Core : v1.77 , MTKx FlashEngine : v1.2 Verify files ... MAUI : RM-944_ROM_eMP_10.04.11 VIVA : RM-944_VIVA_eMP_10.04.11 LANG : RM-944_LANG_PACK_ROM_IJ_eMP_10.04.11 CUST : RM-944_CUSTPACK_ROM_IJ_MEA_IR_eMP_10.04.11 JMPT : RM-944_JUMP_TABLE_IJ_MEA_IR_eMP_10.04.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 15 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : Bree.10.04.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 SecureDecrypt : RM-944_ROM_eMP_10.04.11 SecureDecrypt : RM-944_VIVA_eMP_10.04.11 SecureDecrypt : RM-944_LANG_PACK_ROM_IJ_eMP_10.04.11 SecureDecrypt : RM-944_CUSTPACK_ROM_IJ_MEA_IR_eMP_10.04.11 SecureDecrypt : RM-944_JUMP_TABLE_IJ_MEA_IR_eMP_10.04.11 OVRLP : 000069B900000001 PHPID : Bree.10.04.11.p2 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok ERASE_MAUI_INFO : 0x0001B000 WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-944_ROM_eMP_10.04.11 Write : RM-944_LANG_PACK_ROM_IJ_eMP_10.04.11 Write : RM-944_CUSTPACK_ROM_IJ_MEA_IR_eMP_10.04.11 Write : RM-944_JUMP_TABLE_IJ_MEA_IR_eMP_10.04.11 Write : RM-944_VIVA_eMP_10.04.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-944_ROM_eMP_10.04.11 [VERIFY] DONE : RM-944_LANG_PACK_ROM_IJ_eMP_10.04.11 [VERIFY] DONE : RM-944_CUSTPACK_ROM_IJ_MEA_IR_eMP_10.04.11 [VERIFY] DONE : RM-944_JUMP_TABLE_IJ_MEA_IR_eMP_10.04.11 [VERIFY] DONE : RM-944_VIVA_eMP_10.04.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:00:56 Reboot phone Ok Connect phone on selected interface... | |
The Following User Says Thank You to MALIKTARIQ For This Useful Post: |
09-22-2014, 15:44 | #6 (permalink) |
Freak Poster Join Date: Jun 2010 Location: South Azerbaycan Age: 40
Member: 1333047 Status: Offline Sonork: 100.1618775 Thanks Meter: 278 | You can connect another side of 108 cable (RJ45) to ufs box for good power. Last edited by aydin.gsm1; 09-22-2014 at 15:52. |
The Following User Says Thank You to aydin.gsm1 For This Useful Post: |
