04-26-2017, 10:16 | #46 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia X2-01 Read User Code Done :) Code: Connect phone on selected interface... Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000000000000022000509200C0000 CPU ID : BroadCom 21351 , Features : Dead-Test, USBRPL, FullUSB EM0 ID: 00005361 PUBLIC ID: 0000000000B4358CA7CC9A46172887BECC08807B ASIC MODE ID: 00 ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E ROM ID: DE56D582BDDE7A3A Use BCM21351_usb2nd.fg , Rev : 2.1 Ver : 12.8.0 Processing RAWLOADER... FLIC : 00300020 Req : XSR 1.6 Use BCM21351_XSR16_usbalg.fg , Rev : 2.1 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 37955B6FC432998EF0DB240E332228384D19ED09 ADL: Reading certificates... Reading NPC certificate... IMEI : 357915040391516 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... ADL: Reading certificates done! :) ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Wait, reconneting... SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok CMLA Key read ... Ok WMDRM read ... Ok CRT308 Backup Created NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... CMLA_KEY Data saved... RPL saved : F:\1+Flashing Software\1+Infinity Box\BEST\Backup\Cert\357915040391516.rpl All done, Disconnecting Elapsed: 00:00:49 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - X2-01 Software ver : V 07.11 22-12-10 RM-709 (c) Nokia IMEI : 357915040391516 XappVer : 000008E8 PPM : V 07.11 22-12-10 RM-709 (c) Nokia MC CNT : Content: mc_059C351 V 07.11 22-12-10 RM-709 (c) Nokia Product SN : 1F1495CAH Product code : 059C351 Base Prd.code: 059B859 Module code : 0204674 Long Prod.SN : 0 Hardware info======= HWID : 1001 Battery: 3742 mV CMT BT: 2.31-SP2.31 LCDVer: SEIKO Lock info =========== IMEI : 357915040391516 IMEI spNet : 3A 75 19 05 04 93 51 01 IMEI svNet : 33 75 19 05 04 93 51 21 F9 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= Error collect lock info, try again CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User Code : 33633 MMC pwd : Backup saved UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Reading MMC password... MMC pass Record found, saving... 1 MMC pwd records are found! Extracting... ------------------------------- We have next Pass: aaaaa ------------------------------- Done! Set phone in Normal mode... Restarting... Done! Phone disconected! Connect phone on selected interface... |
The Following User Says Thank You to syed tuqeer For This Useful Post: |
04-26-2017, 15:40 | #47 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia 110 Code: Core : v2.28 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm827__03.51.mcusw PPM : rm827__03.51.ppm_m2 CNT : rm827__03.51.image_m2_059N2R0 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.49_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 359981058150580 IMEI 2 : 359981058150598 PCcode : 059N403 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\359981058150580_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm827__03.51.mcusw Image : rm827__03.51.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01940000 Erasing, wait ... Erase done, time : 00:02:16 Write , Start : 0x40280000 , Len : 0x018C0000 Flashing , wait ... Region flash done, time : 00:00:34 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xA3D6 ===Flashing [PPM]=== File : rm827__03.51.ppm_m2 Image : package_m2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41BC0000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:16 Write , Start : 0x41BC0000 , Len : 0x0030F748 Flashing , wait ... Region flash done, time : 00:00:05 CRC check passed , 0x4605 ===Flashing [CNT]=== File : rm827__03.51.image_m2_059N2R0 Image : package_m2_059N2R0.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x421C0000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:04:28 Write , Start : 0x421C0000 , Len : 0x00F20000 Flashing , wait ... Region flash done, time : 00:00:24 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:08 No write data, skip CRC check passed , 0x7408 Flashing done! Total flash time : 00:08:24 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 110 Software Info: V 03.51 06-08-13 RM-827 (c) Nokia IMEI: 359981058150580 PPM version : V 03.51 06-08-13 RM-827 (c) Nokia M2 Product code: 059N403 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:09:28 |
The Following User Says Thank You to Luckey1 For This Useful Post: |
04-27-2017, 04:47 | #48 (permalink) |
No Life Poster Join Date: Apr 2004 Location: srilanka
Member: 61595 Status: Offline Sonork: 100.1610188 Thanks Meter: 97 | lumia 650 rm1152 unlock don [WP8x] : Init TesMode [TSTM] : Use File : RM1152_1078.0021.10586.13053.207.331_enosw-wim-signed_516102.secwim === Base Phone Info Sw Version : 01078.00037.16082.41002 IMEI : 35512607830xxx ProductCode : M1012174-001 Device catched in BOOT mode! Collect Info... === Nokia Flash App info : Protocol Version : 2.41 Protocol Implementation : 2.75 === Phone Initial info : Phone Model ID : Microsoft.MSM8909.P6237.2.0 === eMMC info : eMMC Vendor : Samsung eMMC CID : 0015 eMMC Size : 14910 MiB === Security Initial info : Security Status : 010100000101 Secure Boot : Enabled Secure eFUSE : Enabled JTAG : Disabled RDC Key : Not Present (Retail) UEFI SBoot : Enabled SecHW Key : Exists Device RootKey : B8219CA0F88F67C2EF5C16BE975B61705FA14D95 === Other info : SD present : False SECWIM : RM1152_1078.0021.10586.13053.207.331_enosw-wim-signed_516102.secwim Sending WIM ... WIM Image sent! Trying init TestMode now... Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok Check SimLock info Conf key : 8000000000000000 Provider key : 2280100000000000 Country : Switzerland Operator : Swisscom Counters : Key 0 [3] , Fbus 0 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close ============================= LOCKS : Closed ============================= Done! WP8 Unlock Started Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Processing Step #1 Processing Step #2 Processing Step #3 Processing Step #4 Disconnected Need SDAuth to finish ... Started Connecting to SX4 server... Connected SX4 enter .. SDAuth Ok! SX4 Disconnected Unlock Done! Wait for phone reboot ... Reboot Ok! rm1152 eno file https://we.tl/VbCEVutwcK Last edited by naje; 04-27-2017 at 04:55. |
The Following 2 Users Say Thank You to naje For This Useful Post: |
04-27-2017, 04:51 | #49 (permalink) |
Member: 61595 Status: Offline Sonork: 100.1610188 Thanks Meter: 97 | lumia 650 RM-1152 unlock success [WP8x] : Init TesMode [TSTM] : Use File : RM1152_1078.0021.10586.13053.207.331_enosw-wim-signed_516102.secwim === Base Phone Info Sw Version : 01078.00037.16082.41002 IMEI : 355126078300724 ProductCode : M1012174-001 Device catched in BOOT mode! Collect Info... === Nokia Flash App info : Protocol Version : 2.41 Protocol Implementation : 2.75 === Phone Initial info : Phone Model ID : Microsoft.MSM8909.P6237.2.0 === eMMC info : eMMC Vendor : Samsung eMMC CID : 0015 eMMC Size : 14910 MiB === Security Initial info : Security Status : 010100000101 Secure Boot : Enabled Secure eFUSE : Enabled JTAG : Disabled RDC Key : Not Present (Retail) UEFI SBoot : Enabled SecHW Key : Exists Device RootKey : B8219CA0F88F67C2EF5C16BE975B61705FA14D95 === Other info : SD present : False SECWIM : RM1152_1078.0021.10586.13053.207.331_enosw-wim-signed_516102.secwim Sending WIM ... WIM Image sent! Trying init TestMode now... Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok Check SimLock info Conf key : 8000000000000000 Provider key : 2280100000000000 Country : Switzerland Operator : Swisscom Counters : Key 0 [3] , Fbus 0 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close ============================= LOCKS : Closed ============================= Done! WP8 Unlock Started Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Processing Step #1 Processing Step #2 Processing Step #3 Processing Step #4 Disconnected Need SDAuth to finish ... Started Connecting to SX4 server... Connected SX4 enter .. SDAuth Ok! SX4 Disconnected Unlock Done! Wait for phone reboot ... Reboot Ok! eno file https://we.tl/VbCEVutwcK |
The Following User Says Thank You to naje For This Useful Post: |
04-27-2017, 09:58 | #50 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | Nokia 130 (RM-1035) Blinking Repaired. Write Firmware: Code: Core : v2.28 , MTKx FlashEngine : v12.0 Verify files ... MAUI : RM-1035_ROM_eMP_10.01.11 VIVA : RM-1035_VIVA_eMP_10.01.11 LANG : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001 CUST : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 JMPT : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 256 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : DD694703B9A9A599E9364BE1EFAE9197 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_ROM_eMP_10.01.11 SecureDecrypt : RM-1035_VIVA_eMP_10.01.11 SecureDecrypt : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001 SecureDecrypt : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 SecureDecrypt : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 OVRLP : 000069B900000001 PHPID : CRYSTAL.10.01.11.p2 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_ROM_eMP_10.01.11 Write : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001 Write : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 Write : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 Write : RM-1035_VIVA_eMP_10.01.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_ROM_eMP_10.01.11 [VERIFY] DONE : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001 [VERIFY] DONE : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 [VERIFY] DONE : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 [VERIFY] DONE : RM-1035_VIVA_eMP_10.01.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:00:52 Reboot phone Ok |
The Following User Says Thank You to Nasir Mobiles For This Useful Post: |
05-01-2017, 08:59 | #52 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 501 Write Firmware Done :) Code: Core : v2.28 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual File [Ok] : rm902_14.0.6.mcusw.fpsx File [Ok] : rm902_14.0.3_059R2T6_m1_245_03_452443.rofs.fpsx File [Ok] : rm902_14.0.3_059R2T6_m1_245_03_452443.image.fpsx Dead Mode is Selected Waiting for USB device... If PC not detect phone - Insert Cable first, then Insert battery If stuck on boot - remove MicroSD card from phone! --- Press phone's power button or insert cable & charger! --- 1st Boot Done, processing booting now ASIC ID_F : 00000C201610004049B22E099A69F14AEC469A00 ASIC ID_E : 00000C2016100040 PUBLIC ID : 358CC06FB31096C349B22E099A69F14AEC469A00 XGCHIP ID : 358CC06FB31096C3 ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579 ROM ID : 535882252F54C676 Prepare and send 2nd loader... 2nd boot Ok Prepare and send Algo loader... Algo boot Ok IMEI [1] : 358139058311360 IMEI [2] : 358139058311378 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : F:\1+Flashing Software\1+Infinity Box\BEST\Backup\Cert\358139058311360_XG223_CRT.rpl PAPUBkeys : 7E4AA99553DB48A5F2DD39E02FA1B862ECB0EF5E === SW Version Check === - > UPGRADE === SW Version Check === === Flashing MCU === Processing file : rm902_14.0.6.mcusw.fpsx Erasing... Writing... Total blocks : 82 Writing RKH CRT [ISSW] Writing RKH CRT [MEMSET] Writing RKH CRT [PRIMAPP] Writing RKH CRT [LOADER] Writing RKH CRT [PASUBTOC] Writing RKH CRT [PAPUBKEYS] [PAKeys : 7E4AA99553DB48A5F2DD39E02FA1B862ECB0EF5E] Writing RKH CRT [UPDAPP] Writing RKH CRT [MCUSW] File processed Ok, 81 blocks were writen === Flashing PPM === Processing file : rm902_14.0.3_059R2T6_m1_245_03_452443.rofs.fpsx Erasing... Writing... Total blocks : 13 Writing RKH CRT [PPM] File processed Ok, 13 blocks were writen === Flashing CNT === Processing file : rm902_14.0.3_059R2T6_m1_245_03_452443.image.fpsx Erasing... Writing... Total blocks : 59 File processed Ok, 59 blocks were writen Flashing done , total time : 00:00:58 Reboot phone to service mode... Reading Phone Info.... Connected phone - 501 Software Info: V 14.0.6 10-07-14 RM-902 (c) Nokia IMEI: 358139058311360 PPM version : ea6d94589d9f63b081391ac0aae46b014a8938b3 Product code: 059T1W3 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 59 certs Certificates found, skip upload ... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
05-03-2017, 12:31 | #53 (permalink) |
Member: 355782 Status: Offline Thanks Meter: 1,265 | Nokia 2700 Classic (RM-561) Flashing Done. Code: Core : v2.28 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm561__09.98.mcusw PPM : rm561__09.98.ppm_t CNT : rm561__09.98.image_t_ph_blac Flashing phone now... [Gen] Rules accepted for : RAP3x Generation Check files done... -> SWversion check skipped : Manual mode selected Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\357017045004143_SIM.rpl Batery valtage : 3711 mV -> Batery voltage less, than 3,8V (3711mV). Continue at user risk Getting product info... RAP_BOOT: 0803000302010000 RAP_PUBLIC: 1F300010BD710F569738948293B51EF2CDAFA9F5 CMT_ROOTKEY: 9DDBFCFE6E73CED7D8C6268C8EB85723 RAP_PAPUBKEY: 3EA22A1DDA660002E56108DB5072A10F8709443F Checking CNT sector PN<>FL PN CNT sector : 128 kb ConvertImage: Processing rm561__09.98.image_t_ph_blac ConvertImage: Page Size is 128K, no need convert Loader len: 308032, CHK: 037B ADL -> Sending loader... Update Server code succesfully sent to phone! TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ===Flashing [MCU]=== Erase : Processing rm561__09.98.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:16 Write : Processing rm561__09.98.mcusw Total 1256 [1256/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:00:57 MCU Write done ===Flashing [PPM]=== Erase : Processing rm561__09.98.ppm_t Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:59 Write : Processing rm561__09.98.ppm_t Total 353 [353/0/0] blocks to write, writing... TIME : Write time : 00:00:16 PPM Write done ===Flashing [CNT]=== Erase : Processing rm561__09.98.image_t_ph_blac Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:05:54 Write : Processing rm561__09.98.image_t_ph_blac Total 696 [696/0/0] blocks to write, writing... TIME : Write time : 00:00:32 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:10:56 Reboot phone now... Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 0 certs Uploading User Certificates... Uploaded 26 certs! Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:11:57 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Set phone in Normal mode... Restarting... Done! Phone disconected! |
05-03-2017, 17:16 | #54 (permalink) |
Freak Poster Join Date: May 2010
Member: 1297521 Status: Offline Thanks Meter: 28 | Lumia 650 RM-1152 unlocked Init TEST mode: Code: [WP8x] : Init TesMode [TSTM] : Use File : RM1152_1078.0021.10586.13053.207.331_enosw-wim-signed_516102.secwim === Base Phone Info Sw Version : 01078.00042.16352.50003 IMEI : 355126078671454 ProductCode : M1012174-001 Device catched in BOOT mode! Collect Info... === Nokia Flash App info : Protocol Version : 2.41 Protocol Implementation : 2.75 === Phone Initial info : Phone Model ID : Microsoft.MSM8909.P6237.2.0 === eMMC info : eMMC Vendor : Samsung eMMC CID : 0015 eMMC Size : 14910 MiB === Security Initial info : Security Status : 010100000101 Secure Boot : Enabled Secure eFUSE : Enabled JTAG : Disabled RDC Key : Not Present (Retail) UEFI SBoot : Enabled SecHW Key : Exists Device RootKey : B8219CA0F88F67C2EF5C16BE975B61705FA14D95 === Other info : SD present : False SECWIM : RM1152_1078.0021.10586.13053.207.331_enosw-wim-signed_516102.secwim Sending WIM ... WIM Image sent! Trying init TestMode now... Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok Code: SD Authentification : not done Local SX4 Card Not Found, wil use Server Started Connecting to SX4 server... Connected SX4 enter .. SDAuth Ok! SX4 Disconnected SX4 Done! Done! Unlock: Code: WP8 Unlock Started Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Processing Step #1 Processing Step #2 Processing Step #3 Processing Step #4 Disconnected Unlock Done! Wait for phone reboot ... Reboot Ok! Done! |
The Following User Says Thank You to servis.kompa For This Useful Post: |
05-05-2017, 12:32 | #55 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia 206 Code: Core : v2.28 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm872__04.52.mcusw PPM : rm872__04.52.ppm_m2 CNT : rm872__04.52.image_m2_059Q8L5 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.53_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 359991057334549 IMEI 2 : 359991057334556 PCcode : 059Q4L5 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\359991057334549_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm872__04.52.mcusw Image : rm872__04.52.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:00:50 Write , Start : 0x40280000 , Len : 0x01800000 Flashing , wait ... Region flash done, time : 00:00:34 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xFA4D ===Flashing [PPM]=== File : rm872__04.52.ppm_m2 Image : package_m2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A80000 , Len : 0x00680000 Erasing, wait ... Erase done, time : 00:00:08 Write , Start : 0x41A80000 , Len : 0x003C68F0 Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0xC9E6 ===Flashing [CNT]=== File : rm872__04.52.image_m2_059Q8L5 Image : package_m2_059Q8L5.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42100000 , Len : 0x01D20000 Erasing, wait ... Erase done, time : 00:01:10 Write , Start : 0x42100000 , Len : 0x01040000 Flashing , wait ... Region flash done, time : 00:00:21 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0xDE0E Flashing done! Total flash time : 00:03:17 Reboot phone now... Reading Phone Info.... Connected phone - 206 Software Info: V 04.52 30-06-13 RM-872 (c) Nokia IMEI: 359991057334549 PPM version : V 04.52 30-06-13 RM-872 (c) Nokia M2 Product code: 059Q4L5 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:04:11 |
05-06-2017, 07:05 | #56 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Old Is Gold > Nokia 2690 Flashing Done Code: Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm635__10.65.mcusw PPM : rm635__10.65.ppm_ms CNT : rm635__10.65.image_ms_black Flashing phone now... [Gen] Rules accepted for : RAP3x Generation Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- -> Phone not found.. :( -> Error while flashing... :( Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm635__10.65.mcusw PPM : rm635__10.65.ppm_ms CNT : rm635__10.65.image_ms_black Flashing phone now... [Gen] Rules accepted for : RAP3x Generation Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 1FE0000E6C9D7D5622A3EF87E4B7637699BD5E6B CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ===Flashing [MCU]=== Erase : Processing rm635__10.65.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:28 Write : Processing rm635__10.65.mcusw Total 1165 [1165/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:00:55 MCU Write done ===Flashing [PPM]=== Erase : Processing rm635__10.65.ppm_ms Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:01 Write : Processing rm635__10.65.ppm_ms Total 172 [172/0/0] blocks to write, writing... TIME : Write time : 00:00:08 PPM Write done ===Flashing [CNT]=== Erase : Processing rm635__10.65.image_ms_black Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:07:19 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm635__10.65.image_ms_black Total 496 [496/0/0] blocks to write, writing... TIME : Write time : 00:00:28 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:12:23 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 2690 Software Info: V 10.65 09-12-10 RM-635 (c) Nokia IMEI: 353411041214323 PPM version : V 10.65 09-12-10 RM-635 (c) Nokia MS Product code: 0592552 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 0 certs Uploading User Certificates... Uploaded 26 certs! Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:13:25 |
The Following 4 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
05-06-2017, 07:06 | #57 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 215 Format Done Code: --- Insert USB cable now! --- Wait for phone... Phone found! [ 23 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : E66FC4442AF4E79BEAC9822FB964B106 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : JET.10.01.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Jet.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00E80000-0x00FF3FFF , LEN : 0x00174000 Executing FFS FORMAT now... FAT_RANGE : 0x00E80000-0x00FF3FFF , LEN : 0x00174000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Elapsed: 00:00:20 Connect phone on selected interface... |
05-12-2017, 12:25 | #58 (permalink) |
No Life Poster Join Date: Oct 2012 Location: Pakistan ,Sahiwal ,Bwn Age: 30
Member: 1819120 Status: Offline Sonork: 100.1648344 Thanks Meter: 1,448 | Nokia 105 New Full Flash Done Nokia 105 New Full Flash Done Code: Core : v2.28 , MTKx FlashEngine : v12.0 Verify files ... MAUI : RM-1133_ROM_eMP_13.00.11 VIVA : RM-1133_VIVA_eMP_13.00.11 LANG : RM-1133_LANG_PACK_ROM_IJ_eMP_13.00.11_002 CUST : RM-1133_CUSTPACK_ROM_IJ_MEA_PK_eMP_13.00.11_002 JMPT : RM-1133_JUMP_TABLE_IJ_MEA_PK_eMP_13.00.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 46 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : E967416C4DB2F30326CA695BC8469147 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : LAGOS61D.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Lagos.fg DA_VERIFY : 00 DA_JUMP : 00100000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32 [0] : FLASH_DIE : 00C8 0060 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x00368000-0x003F7FFF , LEN : 0x00090000 SecureDecrypt : RM-1133_ROM_eMP_13.00.11 SecureDecrypt : RM-1133_VIVA_eMP_13.00.11 SecureDecrypt : RM-1133_LANG_PACK_ROM_IJ_eMP_13.00.11_002 SecureDecrypt : RM-1133_CUSTPACK_ROM_IJ_MEA_PK_eMP_13.00.11_002 SecureDecrypt : RM-1133_JUMP_TABLE_IJ_MEA_PK_eMP_13.00.11_002 OVRLP : 000069B900000001 PHPID : LAGOS61D.10.01.11.p2 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1133_ROM_eMP_13.00.11 Write : RM-1133_LANG_PACK_ROM_IJ_eMP_13.00.11_002 Write : RM-1133_CUSTPACK_ROM_IJ_MEA_PK_eMP_13.00.11_002 Write : RM-1133_JUMP_TABLE_IJ_MEA_PK_eMP_13.00.11_002 Write : RM-1133_VIVA_eMP_13.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1133_ROM_eMP_13.00.11 [VERIFY] DONE : RM-1133_LANG_PACK_ROM_IJ_eMP_13.00.11_002 [VERIFY] DONE : RM-1133_CUSTPACK_ROM_IJ_MEA_PK_eMP_13.00.11_002 [VERIFY] DONE : RM-1133_JUMP_TABLE_IJ_MEA_PK_eMP_13.00.11_002 [VERIFY] DONE : RM-1133_VIVA_eMP_13.00.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x00368000-0x003F7FFF , LEN : 0x00090000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:00:59 Reboot phone Ok Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Br Muzammal Mudasser |
The Following User Says Thank You to muzammal mudass For This Useful Post: |
05-12-2017, 12:40 | #59 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia C1-01 Code: Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm607__04.40.mcusw PPM : rm607__04.40.ppm_m_c CNT : rm607__04.40.image_m_c_0595609 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_2.3_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI : 357913042838790 PCcode : 059G896 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\357913042838790_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm607__04.40.mcusw Image : rm607__04.40.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40040000 , Len : 0x00040000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40080000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40080000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 4/5 Erase , Start : 0x400A0000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x400A0000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 5/5 Erase , Start : 0x40400000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:02:02 Write , Start : 0x40400000 , Len : 0x01780000 Flashing , wait ... Region flash done, time : 00:00:31 CRC check passed , 0xD471 ===Flashing [PPM]=== File : rm607__04.40.ppm_m_c Image : package_m_c.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41C00000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:16 Write , Start : 0x41C00000 , Len : 0x0031A50C Flashing , wait ... Region flash done, time : 00:00:03 CRC check passed , 0x4A12 ===Flashing [CNT]=== File : rm607__04.40.image_m_c_0595609 Image : package_m_c_0595609.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42200000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:05:26 Write , Start : 0x42200000 , Len : 0x00B60000 Flashing , wait ... Region flash done, time : 00:00:21 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:08 No write data, skip CRC check passed , 0x17AA Flashing done! Total flash time : 00:09:01 Reboot phone now... Reading Phone Info.... Connected phone - C1-01 Software Info: V 04.40 23-02-11 RM-607 (c) Nokia IMEI: 357913042838790 PPM version : V 04.40 23-02-11 RM-607 (c) Nokia M_C Product code: 059G896 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 39 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:09:59 |
05-12-2017, 12:41 | #60 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia 220 Rm-969 Code: Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-969_ROM_eMP_30.06.11 VIVA : RM-969_VIVA_eMP_30.06.11 LANG : RM-969_LANG_PACK_ROM_IJ_eMP_30.06.11_001 CUST : RM-969_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001 JMPT : RM-969_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 38 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : E8E1F8BD6479163B9D3AD5EF0E84D725 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Rivendell.10.03.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 SecureDecrypt : RM-969_ROM_eMP_30.06.11 SecureDecrypt : RM-969_VIVA_eMP_30.06.11 SecureDecrypt : RM-969_LANG_PACK_ROM_IJ_eMP_30.06.11_001 SecureDecrypt : RM-969_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001 SecureDecrypt : RM-969_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001 OVRLP : 000069B900000001 PHPID : Rivendell.10.03.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-969_ROM_eMP_30.06.11 Write : RM-969_LANG_PACK_ROM_IJ_eMP_30.06.11_001 Write : RM-969_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001 Write : RM-969_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001 Write : RM-969_VIVA_eMP_30.06.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-969_ROM_eMP_30.06.11 [VERIFY] DONE : RM-969_LANG_PACK_ROM_IJ_eMP_30.06.11_001 [VERIFY] DONE : RM-969_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001 [VERIFY] DONE : RM-969_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001 [VERIFY] DONE : RM-969_VIVA_eMP_30.06.11 CODE_VERIFY : Ok Will Upload FAT Image now Write : RM-969_FATIMAGE_IJ_30.06.11 FAT Image Flash done! FAT Verify Ok Rebooting phone now Flashing done! Total flash time : 00:05:04 Reboot phone Ok |
