08-25-2019, 06:53 | #901 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Nokia 230 reset password done by best Card found : 30C22462 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.18 Operation : Identify [ v1.18 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM5) MODE : NOKIA USB SERIAL PORT : 5 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 402BF91FFE5F0470E82D7852EA143607 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : DOHA.14.00.11.p1 BOOT : SWR : 14.00.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : DOHA.14.00.11.p1 FLASH : 00EF : 0060 : 0018 : 0000 BBSN : 402BF91FFE5F0470E82D7852EA143607 PRDC : 059X4P8 IMEI[1] : 357285087527426 IMEI[2] : 357285087527434 NCK : 20 digits PROV : 24407000 Saved as : 357285087527426.mtsec Saved to : C:\InfinityBox\BEST2\Backup\ Done! Elapsed: 00:01:00 Reconnect Power/Cable! Operation : Reset Settings [ v1.18 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM5) MODE : NOKIA USB SERIAL PORT : 5 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 402BF91FFE5F0470E82D7852EA143607 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0000 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : DOHA.14.00.11.p1 BOOT : SWR : 14.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : DOHA.14.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8B NOR: 00EF : 0060 : 0018 : 0000 NOR: [WINBOND] W25Q128FW NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00DC0000 : 0x00234000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
The Following User Says Thank You to A.G.Shahid For This Useful Post: |
08-26-2019, 10:18 | #902 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,428 | Nokia 206 Flash Done Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm872__04.52.mcusw PPM : rm872__04.52.ppm_m2 CNT : rm872__04.52.image_m2_059Q4J7 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.53_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 353660060653361 IMEI 2 : 353660060653379 PCcode : 059Q843 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\353660060653361_XG 213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm872__04.52.mcusw Image : rm872__04.52.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:00:46 Write , Start : 0x40280000 , Len : 0x01800000 Flashing , wait ... Region flash done, time : 00:00:29 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xFA4D ===Flashing [PPM]=== File : rm872__04.52.ppm_m2 Image : package_m2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A80000 , Len : 0x00680000 Erasing, wait ... Erase done, time : 00:00:07 Write , Start : 0x41A80000 , Len : 0x003C68F0 Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0xC9E6 ===Flashing [CNT]=== File : rm872__04.52.image_m2_059Q4J7 Image : package_m2_059Q4J7.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42100000 , Len : 0x01D20000 Erasing, wait ... Erase done, time : 00:01:00 Write , Start : 0x42100000 , Len : 0x01040000 Flashing , wait ... Region flash done, time : 00:00:18 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0x5521 Flashing done! Total flash time : 00:02:54 Reboot phone now... Reading Phone Info.... Connected phone - 206 Software Info: V 04.52 30-06-13 RM-872 (c) Nokia IMEI: 353660060653361 PPM version : V 04.52 30-06-13 RM-872 (c) Nokia M2 Product code: 059Q843 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:03:43 Connect phone on selected interface... |
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
08-26-2019, 12:01 | #903 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Nokia 105 ta 1010 reset password done by best Card found : 30C22462 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.18 Operation : Identify [ v1.18 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM5) MODE : NOKIA USB SERIAL PORT : 5 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 75E8DAE0BD61F2BC63FA49CA3399253F BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.30.04.11.p1 BOOT : SWR : 30.04.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : N103.30.04.11.p1 FLASH : 00C2 : 0025 : 0036 : 0000 BBSN : 75E8DAE0BD61F2BC63FA49CA3399253F PRDC : 059Z182 IMEI[1] : 35418xxxxxxxxxx NCK : 20 digits PROV : 24407000 Saved as : 35418xxxxxxxxxx.mtsec Saved to : C:\InfinityBox\BEST2\Backup\ Done! Elapsed: 00:00:56 Reconnect Power/Cable! Operation : Reset Settings [ v1.18 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM5) MODE : NOKIA USB SERIAL PORT : 5 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 75E8DAE0BD61F2BC63FA49CA3399253F BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.30.04.11.p1 BOOT : SWR : 30.04.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : N103.30.04.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00EF : 0070 : 0016 : 0000 NOR: [Winbond] SF_W25Q32JV NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00370000 : 0x00088000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
08-26-2019, 18:01 | #904 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,770 | Nokia ta-1010 format done Operation : Identify [ v1.18 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM48) MODE : NOKIA USB SERIAL PORT : 48 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 3203288056253B93CC3E977F0FCFAD59 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.10.02.11.p1 BOOT : SWR : 10.02.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : N103.10.02.11.p1 FLASH : 00C2 : 0025 : 0036 : 0000 BBSN : 3203288056253B93CC3E977F0FCFAD59 PRDC : 059Z149 IMEI[1] : XXXXXXXXXXXXXXX NCK : 20 digits PROV : 24407000 Saved as : XXXXXXXXXXXXXXX.mtsec Saved to : C:\InfinityBox\BEST2\Backup\ Done! Elapsed: 00:00:41 Reconnect Power/Cable! Operation : Reset Settings [ v1.18 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM48) MODE : NOKIA USB SERIAL PORT : 48 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 3203288056253B93CC3E977F0FCFAD59 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.10.02.11.p1 BOOT : SWR : 10.02.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : N103.10.02.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00EF : 0070 : 0016 : 0000 NOR: [Winbond] SF_W25Q32JV NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00370000 : 0x00088000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
The Following User Says Thank You to Yusuf Lawal For This Useful Post: |
08-26-2019, 18:05 | #905 (permalink) |
Member: 1677653 Status: Offline Thanks Meter: 2,770 | Nokia 1 frontier frp reset done Card found : A6936825 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.18 Operation : Identify [ v1.18 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM5) MODE : PRELOADER PORT PORT : 5 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia DownloadAgent ver.07220419 BEST2 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 90014A483847346132A536B43B00C0A3 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A483847346132A536B43B0035A3 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : C0AD481E3357454BD324D644E6F5C04 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! --- SysInfoSub [PART A]: Patch Level : O11019 Display ID : 00WW_0_36A Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-04-05 Build Time : 1521548090 Product Model : FRT Product Brand : alps Product Name : FRT_00WW_FIH Product Device : FRT Product Manfct : alps Product Info : FRT Board Platform : mt6737m --- SecuritySub : IMEI[0] : XXXXXXXXXXXXXXX IMEI[1] : XXXXXXXXXXXXXXX NVRAM check : Passed! Backup sensetive data [ 11 ] Backup path : Backup\MT6735__0C0AD481E3357454BD324D644E6F5C04\ [24] Read : SUTINFO [25] Read : CDA [27] Read : ELABEL [2] Read : PROINFO [3] Read : NVRAM [26] Read : DEVICEINFO Backup done! Done! Elapsed: 00:00:20 Reconnect Power/Cable! Card found : A6936825 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.18 Operation : Reset Settings [ v1.18 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM5) MODE : PRELOADER PORT PORT : 5 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia DownloadAgent ver.07220419 BEST2 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 90014A483847346132A536B43B00C0A3 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A483847346132A536B43B0035A3 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : C0AD481E3357454BD324D644E6F5C04 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
08-27-2019, 05:13 | #906 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Nokia 215 reset password done by best Card found : 30C22462 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.18 Operation : Reset Settings [ v1.18 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM5) MODE : NOKIA USB SERIAL PORT : 5 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 7E7519A9505A458CBAB3FA8C781CF53F BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : JET.12.03.11.p1 BOOT : SWR : 12.03.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : JET.12.03.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8B NOR: 00C2 : 0025 : 0038 : 0000 NOR: [MXIC] MX25U12835FZNI_10G NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00E80000 : 0x00174000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:29 Reconnect Power/Cable! |
09-02-2019, 10:21 | #907 (permalink) |
Freak Poster Join Date: Jan 2012 Location: Sylhet Korim Ullah Market Age: 28
Member: 1714226 Status: Offline Sonork: 100.1683394 Thanks Meter: 243 | TA-1049 frp done by BEST2 Card found : 1AE16B70 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.18 Operation : Reset Settings [ v1.18 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port (COM63) MODE : BOOTROM PORT : 63 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6755 AGENT : Nokia DownloadAgent ver.07220419 BEST2 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 150100514536334D4203686AE41C7509 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE63MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B20D0B5DD4DB667E4E687E3BD234D2E6 DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM41) MODE : PRELOADER PORT PORT : 41 Boot done! Format Ok : USERDATA Format Ok : RESET PROTECTION Format Ok : PRIVACY Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
The Following 6 Users Say Thank You to rubelgsm For This Useful Post: |
09-05-2019, 09:52 | #908 (permalink) |
Banned Join Date: Oct 2017 Location: pakistan kpk mansehra Age: 26
Member: 2765424 Status: Offline Thanks Meter: 1,039 | Nokia 1 ta-1056 dead boot recover done NOKIA 1 TA-1056 DEAD BOOT RECOVER DONE Card found : 284D31AC , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.18 Load : C:\Users\NASEER\Downloads\Compressed\Open-Market-Nokia-1+-FRT-039G-0-00WW-B02\Open-Market-Nokia-1 -FRT-039G-0-00WW-B02.nb0 Load Ok! Operation : Write FW [ v1.18 ] Setting : UserData preserve : False Setting : Flash Pre-Erase : True Setting : Bootloader update : True 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port (COM67) MODE : BOOTROM PORT : 67 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia DownloadAgent ver.07220419 BEST2 Fail to disable Dog! BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 90014A483847346132A5C357A91745D7 DAInf: 4 : 2 : 155 eMMC : OK eMMC : 484A01906134473857C3A532D74517A9 DRAM : DRAM: 0x40000000 [ 1.00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A483847346132A5C357A91735D7 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : E2386E67DED513E25A8868EABEFDB249 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM235) MODE : PRELOADER PORT PORT : 235 Boot done! DL_INFO : PMT present SEC_DL : False (CUST) SEC_ID : 0x67887C7972766E6888787678777B796E [FL] : HW verification passed! Erase : 0x0000000000000000 : 0x0000000000080000 Erase : 0x0000000001C80000 : 0x0000000008900000 Erase : 0x000000000ADC0000 : 0x0000000000100000 Erase : 0x000000000B000000 : 0x00000000D4800000 PMT Update : OK Flashing now ... PROCESS : PRELOADER Unpack : FRT-0-039G-00WW-1-2-preloader_FRT.bin Flash : FRT-0-039G-00WW-1-2-preloader_FRT.bin Update bootloader code ... Update bootloader Ok! PROCESS : LK Unpack : FRT-0-039G-00WW-1-2-lk.img Flash : FRT-0-039G-00WW-1-2-lk.img PROCESS : BOOT Unpack : FRT-0-039G-00WW-1-2-boot.img Flash : FRT-0-039G-00WW-1-2-boot.img PROCESS : RECOVERY Unpack : FRT-0-039G-00WW-1-2-recovery.img Flash : FRT-0-039G-00WW-1-2-recovery.img PROCESS : LOGO Unpack : FRT-0-039G-00WW-1-2-logo.bin Flash : FRT-0-039G-00WW-1-2-logo.bin PROCESS : SECRO Unpack : FRT-0-039G-00WW-1-2-secro.img Flash : FRT-0-039G-00WW-1-2-secro.img PROCESS : TEE1 Unpack : FRT-0-039G-00WW-1-2-tee.img Flash : FRT-0-039G-00WW-1-2-tee.img PROCESS : TEE2 Unpack : FRT-0-039G-00WW-1-2-tee.img Flash : FRT-0-039G-00WW-1-2-tee.img PROCESS : ODMDTBO Unpack : FRT-0-039G-00WW-1-2-odmdtbo.img Flash : FRT-0-039G-00WW-1-2-odmdtbo.img PROCESS : SYSTEMINFO Unpack : fver Flash : fver PROCESS : SUTINFO Unpack : FRT-00WW-001-sutinfo.img Flash : FRT-00WW-001-sutinfo.img PROCESS : CDA Unpack : FRT-00WW-011-cda.img Flash : FRT-00WW-011-cda.img PROCESS : VENDOR Unpack : FRT-0-039G-00WW-1-2-vendor.img Flash : FRT-0-039G-00WW-1-2-vendor.img PROCESS : SYSTEM Unpack : FRT-0-039G-00WW-1-2-system.img Flash : FRT-0-039G-00WW-1-2-system.img PROCESS : CACHE Unpack : FRT-0-039G-00WW-1-2-cache.img Flash : FRT-0-039G-00WW-1-2-cache.img PROCESS : USERDATA Unpack : FRT-0-039G-00WW-1-2-userdata.img Flash : FRT-0-039G-00WW-1-2-userdata.img PMT Update : OK SEC_DL : False (CUST) SEC_ID : 0x67887C7972766E6888787678777B796E Flashing finished! Done! Elapsed: 00:02:22 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to taimur-ahmad For This Useful Post: |
09-06-2019, 05:16 | #909 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Nokia ta 1034 full flash done by best Card found : 30C22462 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.18 Open VPLfile : TA-1034_059Z107_30.04.11.vpl Description : TA-1034 IJ DeviceType : TA-1034 ProductCode : 059Z107 SoftwareVer : 30.04.11 PPM LangPack : [1] : Urdu (Islamic Republic of Pakistan) [2] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.18 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM5) MODE : NOKIA USB SERIAL PORT : 5 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : E06E7D0C7BDAB14F7CFADFABD08D2CEE BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.30.04.11.p1 BOOT : SWR : 30.04.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : N103.30.04.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00EF : 0070 : 0016 : 0000 NOR: [Winbond] SF_W25Q32JV NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 30.04.11 [TA-1034] DEV SoftwareVersion : 30.04.11 SWInfo compare result : SAME Load FlashSet : MROM : TA-1034_ROM_eMP_30.04.11 LANG : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001 CUST : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001 JUMP : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001 VIVA : TA-1034_VIVA_eMP_30.04.11 Prepare FlashSet : DCR : TA-1034_ROM_eMP_30.04.11 DCR : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001 DCR : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001 DCR : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001 DCR : TA-1034_VIVA_eMP_30.04.11 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : TA-1034_ROM_eMP_30.04.11 Write : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001 Write : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001 Write : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001 Write : TA-1034_VIVA_eMP_30.04.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1034_ROM_eMP_30.04.11 Verify : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001 Verify : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001 Verify : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001 Verify : TA-1034_VIVA_eMP_30.04.11 Done! Elapsed: 00:01:01 Reconnect Power/Cable! |
09-07-2019, 01:13 | #910 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: GREENHILLS
Member: 467922 Status: Offline Sonork: 100.1612115 Thanks Meter: 215 | Nokia 5.1 TA-1088 FRP reset done. Hi to all, Nokia 5.1 reset done using NK2 Bestdongle. Quote:
The Following 2 Users Say Thank You to DEADBOOT For This Useful Post: |
09-07-2019, 09:11 | #911 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Subotica Age: 54
Member: 60687 Status: Offline Thanks Meter: 32 | ta-1104 frp log: Operation : Reset Settings [ v1.18 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port (COM105) MODE : BOOTROM PORT : 105 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY+DEV_ARB BROM : BOOTROM BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] BROM : SOCID : 7F55F658FCEFE971864918C62578716F602F3C71F234CD30D8 0F1E649F709FEA AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6765 AGENT : Nokia DownloadAgent ver.07220419 BEST2 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256,00 KB ] DRAM: 0xC0000000 [ 3,00 GB ] EMMC: 90014A68423861503E01174058B665AF EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hB8aP> EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x01000000 [ 16,00 MB ] USER : 0x747C00000 [ 29,12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : D3CD34BAC6AFC8CD9F8C1B0AA19F454B DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : RESET PROTECTION Done! Elapsed: 00:00:58 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to arnoldmasa For This Useful Post: |
09-08-2019, 05:07 | #912 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Nokia 3310 3g reset password done by best2 Card found : 30C22462 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.12 Operation : Reset Settings ( Format FS ) [ v1.12 ] 1. Power off device, remove battery 2. Insert cable, press and hold BootKey ( # ) 3. Insert battery in device! Wait for device ... Device Connected! BootVersion : SPRD SECURE BOOT Block version BootVersion : BEST RETRO3G Port speed : 921600 FDL Flash : Control transfered! Boot Done! Erase BLK #0 Erase BLK #1 Erase BLK #2 Erase BLK #3 Format Ok! Done! Elapsed: 00:00:32 Reconnect Power/Cable! |
09-23-2019, 17:31 | #913 (permalink) |
Member: 1677653 Status: Offline Thanks Meter: 2,770 | Nokia 1 plus format all done Card found : A6936825 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.18 Operation : Identify [ v1.18 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM22) MODE : PRELOADER PORT PORT : 22 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY BROM : PRELOADER PORT BROM : SOCID : 14E0F2E5EB3D9CD5074AD307662EE71ED4290B35EF95CFF9A3 D0EC4D4BB2FB54 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6739 AGENT : Nokia DownloadAgent ver.07220419 BEST2 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: 150100464E36324D4203DCF39B56563F EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FN62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0x1D2000000 [ 7.28 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : CDF37D5BC498A04BF6D9D99F1C38E103 DA : USB : HIGH-SPEED Boot done! --- SysInfoSub [PART A]: Patch Level : PPR1.180610.011 Display ID : 00WW_0_750 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-04-01 Build Time : 1553968287 Product Model : ANT Product Brand : alps Product Name : ANT_00WW_FIH Product Device : ANT Product Manfct : alps Product Info : ANT Product Board : ANT Board Platform : mt6739 --- SecuritySub : NVRAM check : Passed! Backup sensetive data [ 11 ] Backup path : Backup\MT6739__CDF37D5BC498A04BF6D9D99F1C38E103\ Backup done! Done! Elapsed: 00:00:24 Reconnect Power/Cable! Operation : Reset Settings [ v1.18 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM22) MODE : PRELOADER PORT PORT : 22 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY BROM : PRELOADER PORT BROM : SOCID : 14E0F2E5EB3D9CD5074AD307662EE71ED4290B35EF95CFF9A3 D0EC4D4BB2FB54 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6739 AGENT : Nokia DownloadAgent ver.07220419 BEST2 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: 150100464E36324D4203DCF39B56563F EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FN62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0x1D2000000 [ 7.28 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : CDF37D5BC498A04BF6D9D99F1C38E103 DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
09-26-2019, 16:57 | #914 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Burundi Bujumbura
Member: 750759 Status: Online Sonork: 75101010 Thanks Meter: 169 | Nokia5.1 TA-1075 FRP Reset done Operation : Reset Settings [ v1.18 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port (COM3) MODE : BOOTROM PORT : 3 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6755 AGENT : Nokia DownloadAgent ver.07220419 BEST2 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100475836424D4203AB3CA8413521 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : GX6BMB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 5C18F8589BB91801E21F97DAECF23813 DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM69) MODE : PRELOADER PORT PORT : 69 Boot done! Format Ok : USERDATA Format Ok : RESET PROTECTION Format Ok : PRIVACY Done! Elapsed: 00:00:33 Reconnect Power/Cable! |
The Following User Says Thank You to Arafat Mashaka For This Useful Post: |
09-27-2019, 00:13 | #915 (permalink) |
Junior Member Join Date: Oct 2014
Member: 2282287 Status: Offline Thanks Meter: 4 | I had this Phone stuck on recovery For months... flash after flash ... tool after tool But the Final solution is With BEST NK2 ..... Thanks From The Heart ............................... Card found : 8XXXXXXX , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.07 Loading firmware ... Created by Infinity-Box (c) BEST (c) 2018 Device Brand : Nokia Device IntName : TA-1021_00WW Device TA-IDxx : TA-1021 Device Manufact.: HMD Global Device Model : PLE Device CPU : MSM8937 Nokia Model : Nokia 6 CU_SWVer : HMD Global Device Project : 600WW Dev Build Info : TA-1021_00WW-user 7.1.2 N2G47H 00WW_3_700 release-keys Dev CPU : MSM8937 Dev SKU : 600WW SKU Vendor : NOKIA SKU Locale : Worldwide SKU Carier : FIH Generic FOXCN_SW_A : PLE-3700-0-00WW-B0 Load Ok! Operation : Flash [ v1.07 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. Use BOOT JIG or EDL cable! 3. Insert USB cable, press "POWER_ON" button few times, if need Wait for phone... Device Found! Initialize ... Error : Fail to init protocol! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Flash [ v1.07 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. Use BOOT JIG or EDL cable! 3. Insert USB cable, press "POWER_ON" button few times, if need Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 430 [MSM8937] BB_IDC_SWB : 00000000 ID_BLOCK_S : B9489E48 ID_BLOCK_I : 0004F0E1 ID_BLOCK_L : 646297BBA5231FA8013E97B10726FB19 ID_BLOCK_L : 58681F818768B4C329A07AAD38CC2502 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RX1BMB Boot Ok! Flash Chain : 65 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : devcfg.mbn Flashing : devcfg.mbn Flashing : adspso.bin Flashing : sec.dat Flashing : splash.img Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : boot.img Flashing : recovery.img Flashing : ftm_boot.img Flashing : def_npreset.mbn Flashing : hwconf.cfg Flashing : sysinfo.cfg Flashing : splashm.img Flashing : hidden.img Flashing : cda.img Flashing : persist.img Flashing : misc.img Flashing : mdtp.img Flashing : cmnlib.mbn Flashing : cmnlib.mbn Flashing : cmnlib64.mbn Flashing : cmnlib64.mbn Flashing : keymaster.mbn Flashing : keymaster.mbn Flashing : system.img Flashing : cache.img Flashing : userdata.img Flashing : gpt_backup0.bin Wipe data ... BootConfig set to 0x00 Flashing done! When you will see ANDROID on screen make next steps : 1. Press and Hold both 'Vol_UP' and 'Power_On' keys 2. Hold them until device will reboot and show again ANDROID logo 3. Release 'Power_On' button, wait when color circle appear on screen! Done! Elapsed: 00:08:02 Reconnect Power/Cable! |
The Following User Says Thank You to tcr_tareq For This Useful Post: |
