Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 01-17-2020, 12:26   #1006 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Nokia 106 ta 1114 reset password & read flash file done by best2
Card found : 30C22462 , v0122
Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20
Operation : Identify [ v1.20 ]
1. Make sure device is powered off. Power off, if need. Wait 10 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : Nokia USB Serial Port (COM7)
MODE : NOKIA USB SERIAL
PORT : 7
BROM : Init BROM
BROM init passed!
CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001
BROM : SECCFG : 0x00000005
BROM : NOKIA USB SERIAL
BROM : 0x05 BL : 0x00
BROM : MEID : 4B9B9630061D9CFC3DC3A27DB42C63D6
BROM : Run BootLoader ...
BOOT : Run BL ver. 01
BOOT : 0x05 BL : 0x01
BOOT : WD : 0005
BOOT : RTC : Setup ...
BOOT : RTC : 000E
BOOT : PRJ : NEMO61D.10.00.11.p2
BOOT : SWR : 10.00.11
BOOT : BDDS : 30
BOOT : PSRM : Init
BOOT : PSRM : 0003
Boot done!
SWVer : NEMO61D.10.00.11.p2
FLASH : 00C2 : 0025 : 0036 : 0000
PRDC : 059Z0X8
IMEI[1] : 354189xxxxxxxxx
IMEI[2] : 354189xxxxxxxxx
NCK : 20 digits
PROV : 24407000
Saved as : 354189xxxxxxxxx.mtsec
Saved to : C:\InfinityBox\BEST2\Backup\
Done!
Elapsed: 00:01:11
Reconnect Power/Cable!
Operation : Reset Settings [ v1.20 ]
PORT : 7
BROM : Init BROM
BROM init passed!
BOOT : WD : 0005
BOOT : RTC : 000E
AGENT : Look for suitable BootChain in DA ...
AGENT : DEFAULT AUTO
AGENT : Found MT6261
AGENT : NEMO61D.10.00.11.p2
BOOT : Sending 1st DA ...
BOOT : DA sent
BOOT : Transfer control to DA ...
DA : Sync Passed!
DA : Authentification pass!
DA : Agent : v03.02 on BBID : 0x8E
NOR: 00C8 : 0060 : 0016 : 0000
NOR: [GigaDevice] GD25LQ32
NOR:
TSIZE : 0x00400000 [ 4.00 MB ]
PSIZE : 0x00400000 [ 4.00 MB ]
STYPE : 0x00000000
FLOTP : DA_NOR_OTP_EXIST
STATUS : OK
BSTYLE : SF_FLASH_BOOT
Boot done!
FFS Info exists in MAUI : 0x00370000 : 0x00088000
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:00:25
Operation : Read FirmWare [ v1.20 ]
PORT : 7
BROM : Init BROM
BROM init passed!
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : BDDS : 30
BOOT : PSRM : Init
BOOT : PSRM : 0003
Boot done!
CODE : 0x00370000
Reading Flash ...
TDSN : TA-1114
PRDC : 059Z0X8
PPM : IJ
LANG :
[1] : Urdu (Islamic Republic of Pakistan)
[2] : English (United Kingdom)
BUILD : TA-1114_ROM_eMP_10.00.11
BUILD : TA-1114_LANG_PACK_ROM_IJ_eMP_10.00.11_001
BUILD : TA-1114_CUSTPACK_ROM_IJ_eMP_10.00.11_001
BUILD : TA-1114_JUMP_TABLE_IJ_eMP_10.00.11_001
BUILD : TA-1114_VIVA_eMP_10.00.11
Make VPL definition
Save Path : C:\InfinityBox\BEST2\TA-1114\
Save Name : TA-1114_059Z0X8_10.00.11.vpl
Build Finished!
Done!
Elapsed: 00:06:02
The Following User Says Thank You to A.G.Shahid For This Useful Post:
Old 01-19-2020, 13:28   #1007 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 680
Nokia 105 format done
PTFN : Nokia USB Serial Port (COM254)
PORT : 254
BROM : Init BROM
BROM init passed!
BROM : SECCFG : 0x00000007
BROM : MEID : 33D3C6928D098C9C4DAA12BC845CD648
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : N103.10.02.11.p1
BOOT : SWR : 10.02.11
AGENT : N103.10.02.11.p1
BOOT : DA sent
DA : Sync Passed!
NOR: 00C2 : 0020 : 0016 : 0000
NOR: [MXIC] MX25L3291FWJI_09
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:00:17
The Following User Says Thank You to Luckey1 For This Useful Post:
Old 01-21-2020, 11:50   #1008 (permalink)
Arslanmayo's Avatar
Member: 2478233
Thanks Meter: 596
nokia ta-1174 format done
Infinity-Box BEST Nokia [HMD] Module [NK2] v1.19
Operation : Reset Settings ( Format FS ) [ v1.19 ]
1. Power off device, remove battery
2. Insert cable, press and hold BootKey ( # )
3. Insert battery in device!
Wait for device ...
Device Connected!
ERROR : Protocol HandShake failed!
Error : Fail to init protocol!
Remove battery, cable. Check cable and connection. Repeat operation!
Extra : FTM mode
2. Not hold any key on device!
Wait for device ...
Device Connected!
Enter SVC ...
Waiting Device ...
Check SVC ...
SVC : DiagChannel opened!
Boot Done!
Erase BLK #0
Format Ok!
Done!
Elapsed: 00:00:26
The Following 3 Users Say Thank You to Arslanmayo For This Useful Post:
Old 01-21-2020, 12:34   #1009 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 680
Nokia 150 format done
PTFN : MediaTek PreLoader USB VCOM Port (COM306)
PORT : 306
BROM : Init BROM
BROM init passed!
BROM : MEID : A05B11C13ACD1FDEEC65B7314833FFED
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : DUBAI61D.11.00.11.p1
BOOT : SWR : 11.00.11
AGENT : DUBAI61D.11.00.11.p1
BOOT : DA sent
DA : Sync Passed!
NOR: 00EF : 0070 : 0016 : 0000
NOR: [Winbond] SF_W25Q32JV
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
FFS Info exists in MAUI : 0x003A0000 : 0x00058000
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:03:46
Old 01-22-2020, 13:47   #1010 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Nokia 105 ta 1034 reset password done by best2
PORT : 7
BROM : Init BROM
BROM init passed!
BROM : MEID : 84FE7F530E020CF53DA6F720FC718925
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : N103.11.00.11.p1
BOOT : BDDS : 30
BOOT : PSRM : Init
BOOT : PSRM : 0003
Boot done!
SWVer : N103.11.00.11.p1
BBSN : 84FE7F530E020CF53DA6F720FC718925
PRDC : 059Z105
IMEI[1] :
IMEI[2] :
NCK : 20 digits
PROV : 24407000
Saved as : xxxxxxxxxxxxxxx.mtsec
Done!
Elapsed: 00:00:58
PORT : 7
BROM : Init BROM
BROM init passed!
BOOT : WD : 0005
BOOT : RTC : 000E
AGENT : N103.11.00.11.p1
BOOT : DA sent
DA : Sync Passed!
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:00:26
Old 01-22-2020, 14:08   #1011 (permalink)
gile@gile's Avatar
Member: 1473716
Thanks Meter: 1,273
Nokia 3310 3G TA-1022 Flash done
Wait for device ...
Device Connected!
BootVersion : SPRD SECURE BOOT Block version
BootVersion : BEST RETRO3G
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
SW_VERS : 13.0.0.17.01
PC_EXTR : AX 059Z3N6
IMEI[1] : 357305082247265
IMEI[2] : 352751019523267
BT_ADDR : A92BE328F104
Security saved : NKSPDv2_357305082247265.scnv
Done!
Elapsed: 00:00:25
File : TA-1022_20.0.0.17.00_AY_059Z525.sprd
SWVersion : 1022_20.0.0.17.00_AY_059Z525
Operation : Write FirmWare [ v1.20 ]
Setting : False : Full Factory Reset
Setting : True : NVRAM Update/Swap
Wait for device ...
Device Connected!
Port speed : 921600
Boot Done!
[NVM] : Initialize SRC
[NVM] : Initialize DST
[NVM] : Prepare
[NVM] : SWP : 0x000B : 0x000A
[NVM] : Update
[NVM] : Update Ok!
Flash : KERNELIMG
Flash : BOOTLOADER
Flash : USERIMG
Flash : MMIRES
Flash : DSPCODE
Flash : DSPCODE2
Erase : ERASE AUTOSMS
Erase : ERASE PRELOAD
Flash : PRELOAD
Erase : FLASH
Flashing finished!
Done!
Elapsed: 00:01:20
The Following User Says Thank You to gile@gile For This Useful Post:
Old 01-25-2020, 07:46   #1012 (permalink)
niaz muhammad's Avatar
Member: 1519396
Sonork: 100.1612702
Thanks Meter: 1,951
nokia 110 write flash don
Card found: S/N : 8C73AEBC , v0136
Registered to: Niaz muhammad
Connect phone on selected interface...
Core : v2.29 , BB5XG FlashEngine : v10.5
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm827__03.51.mcusw
PPM : rm827__03.51.ppm_mh2
CNT : rm827__03.51.image_mh2_059S4H9
Flashing phone now...
[Gen] Rules accepted for : XGOLD Generation
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
-> If Windows say "Unrecognized device" / Operation not start
-> Or if Phone start charge - just reinsert battery
-> If flashing freeze - reinsert cable/battery and try again
--- Press phone's power button or insert usb cable! ---
Connection opened successfully
IF Boot Init : 0xF0
IF Resp Len  : 0x0A
IF xCPUID    : XGOLD 213 [XMM2130 QUANTUM]
IF Resp Data  :  1FB300020303010100FF
Sending EBL Loader ...
EBL Loader Ok, 01
EBL Loader ready, AA
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.49_M1S1
Speed accepted, use 6.500.000
FLASHID : 89008289
FLIC conf set, RST set
Boot done!
Check keys...
Check done. Image can be flashed
Backup enabled, will read all certificates
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 356358050339144
IMEI 2 : 356358050339151
PCcode : 059N2R6
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : C:\InfinityBox\BEST\Backup\Cert\356358050339144_2nd_XG213_CRT.rpl
Settings : EDM [0x8] , Block Mode , Fast CRC , Verify
   ===Flashing [MCU]===
File : rm827__03.51.mcusw
Image : rm827__03.51.mcusw_ebl_psi.fls
Sec-pack found, sending ...
Sec-pack sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:00
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40040000 , Len : 0x00020000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40060000 , Len : 0x00100000
Erasing, wait ...
Erase done, time : 00:00:05
Write , Start : 0x40060000 , Len : 0x00100000
Flashing , wait ...
Region flash done, time : 00:00:01
Processing Region 4/5
Erase , Start : 0x40280000 , Len : 0x01940000
Erasing, wait ...
Erase done, time : 00:01:18
Write , Start : 0x40280000 , Len : 0x018C0000
Flashing , wait ...
Region flash done, time : 00:00:29
Processing Region 5/5
Erase , Start : 0x43E20000 , Len : 0x00040000
Erasing, wait ...
No write data, skip
CRC check passed , 0xA3D6
   ===Flashing [PPM]===
File : rm827__03.51.ppm_mh2
Image : package_mh2.ppm_ebl_psi.fls
Sec-pack sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x41BC0000 , Len : 0x00600000
Erasing, wait ...
Erase done, time : 00:00:16
Write , Start : 0x41BC0000 , Len : 0x003664A4
Flashing , wait ...
Region flash done, time : 00:00:04
CRC check passed , 0x8ED2
   ===Flashing [CNT]===
File : rm827__03.51.image_mh2_059S4H9
Image : package_mh2_059S4H9.image.fls
Sec-pack sent
Found 2 region(s)
Processing Region 1/2
Erase , Start : 0x421C0000 , Len : 0x01C60000
Erasing, wait ...
Erase done, time : 00:04:00
Write , Start : 0x421C0000 , Len : 0x01020000
Flashing , wait ...
Region flash done, time : 00:00:21
Processing Region 2/2
Erase , Start : 0x43E60000 , Len : 0x000E0000
Erasing, wait ...
Erase done, time : 00:00:07
No write data, skip
CRC check passed , 0x9E52
Flashing done!
Total flash time : 00:06:48
Reboot phone now...
The Following User Says Thank You to niaz muhammad For This Useful Post:
Old 01-25-2020, 11:27   #1013 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 680
Rm-1035
Setting : UserData erase : True
Setting : LangPack Only : False
PTFN : Nokia USB Serial Port (COM342)
PORT : 342
BROM : Init BROM
BROM init passed!
CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000
BROM : MEID : ED01DA09EA7C238415033F70069E66FE
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : CRYSTAL.10.02.11.p1
AGENT : Found MT6260
AGENT : CRYSTAL.10.02.11.p1
BOOT : DA sent
DA : Sync Passed!
DA : Agent : v03.02 on BBID : 0x8B
NOR: 00EF : 0040 : 0016 : 0000
NOR: [WINBOND] W25Q32BV
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
VPL SoftwareVersion : 11.00.11 [RM-1035]
DEV SoftwareVersion : 10.02.11
SWInfo compare result : DEVICE SW ( Minor version ) is LOWER, than in VPL!
Load FlashSet :
MROM : RM-1035_ROM_eMP_11.00.11
LANG : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002
CUST : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002
JUMP : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002
VIVA : RM-1035_VIVA_eMP_11.00.11
Prepare FlashSet :
DCR : RM-1035_ROM_eMP_11.00.11
DCR : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002
DCR : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002
DCR : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002
DCR : RM-1035_VIVA_eMP_11.00.11
Prepare Target
SDS : OK : 0x003F4000 : 0x0000C000
FFS Format Ok!
CBR : 0x0000001A:0x00000001:0x00000000:0x00000000:0x0000 0010:0x00000002:0x00000000
Erase Target Flash
Erase done!
Write Target Flash
Write : RM-1035_ROM_eMP_11.00.11
Write : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002
Write : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002
Write : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002
Write : RM-1035_VIVA_eMP_11.00.11
Write done, waiting target response ...
Write flash done!
Verify Target FlashContent
Verify : RM-1035_ROM_eMP_11.00.11
Verify : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002
Verify : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002
Verify : _JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002
Verify : RM-1035_VIVA_eMP_11.00.11
Done!
Elapsed: 00:01:21
Old 01-25-2020, 12:49   #1014 (permalink)
tapas770's Avatar
Member: 2171294
Sonork: 100.1659207(No More Use)
Thanks Meter: 706
Talking Nokia 2.2 TA-1188 Full Flash/Hang Logo,FRP Remove Done
Phone Problem Was Hang Logo,
Solved By Best Dongle
Load : C:\Users\AhnafTelecom\Desktop\HMDSW_Wasp-1280-0-00WW-B01.zip
Device : wasp
Android: 9
SKU ID : 600WW
ROM Ver: PPR1.180610.011
Load Ok!
Operation : Flash Firmware [FTM] [ v1.19 ]
Setting : UserData preserve : False
Setting : FRP Reset : True
Setting : Change SKUID : False
Setting : Keep SVC : True
-> Old : Power Off Phone, wait 5-10 seconds, Insert USB cable
-> New : Power Off Phone, press and hold VOL_DOWN and POWER keys, until FASTBOOT screen appear
Wait for phone...
Connect Ok!
Device Found!
Initialize ...
Initialize Ok!
Dev Model : Wasp
HW version : 1.0
HW variant : MTK EMMC
HW RF_BAND : G_850_900_1800_1900^W_1_5_8^L_1_3_5_7_8
SW version : WSP_sprout-163A-0-00WW-B01
SW CurrSlot : A
SW serialnm : HZAL1620C7J7A901740
SW secured : YES
Bootloader type : WT2
Security Version : 0002
Prepare base package, please, wait ...
Prepare data package, please, wait ...
Prepare update package, please, wait ...
Device : Wasp ( Wasp )
BLType : WT2
SecVer : 02
Device authentification ...
Processing server operation ...
Connecting to server...
Connected
Authenticating...
Authenticated
Checking Client version...
Client version is valid
Process...
Finished
Disconnected
Finished
Challenge : Process
Challenge : Passed!
OP : Initial
Process : preloader_a : preloader_wasp.bin
Process : custom_a : custom.img
SPImage : Process custom_a_0
Process : custom_b : custom.img
SPImage : Process custom_b_0
Process : logo : logo.bin
Process : lk_a : lk.img
Process : dtbo_a : dtbo.img
Process : md1img_a : md1img.img
Process : scp_a : scp.img
Process : spmfw_a : spmfw.img
Process : sspm_a : sspm.img
Process : tee_a : tee.img
Process : system_b : system_other.img
SPImage : Process system_b_0
SPImage : Process system_b_1
SPImage : Process system_b_2
OP : Update
Process : boot_a : boot_a.img
Process : elabel_a : elabel_a.img
SPImage : Process elabel_a_0
Process : system_a : system_a.img
SPImage : Process system_a_0
SPImage : Process system_a_1
SPImage : Process system_a_2
SPImage : Process system_a_3
SPImage : Process system_a_4
SPImage : Process system_a_5
SPImage : Process system_a_6
SPImage : Process system_a_7
SPImage : Process system_a_8
SPImage : Process system_a_9
SPImage : Process system_a_10
SPImage : Process system_a_11
SPImage : Process system_a_12
SPImage : Process system_a_13
SPImage : Process system_a_14
SPImage : Process system_a_15
SPImage : Process system_a_16
SPImage : Process system_a_17
Process : userdata : userdata.img
SPImage : Process userdata_0
Process : vbmeta_a : vbmeta_a.img
Process : vendor_a : vendor_a.img
SPImage : Process vendor_a_0
SPImage : Process vendor_a_1
SPImage : Process vendor_a_2
OP : Post
OP : UserData preserve : disabled
OP : Reset FRP
BLType : WT2
SecVer : 02
Connected
Authenticating...
Authenticated
Process...
Finished
Disconnected
Finished
Challenge : Process
Challenge : Passed!
Reset FRP Ok!
Done!
Elapsed: 00:13:43
Thanks Infinity Team such A Strong Update..
The Following 2 Users Say Thank You to tapas770 For This Useful Post:
Old 01-26-2020, 06:01   #1015 (permalink)
Nadeem Waris's Avatar
Member: 1080718
Sonork: 100.1596539 QQ-2710826805
Thanks Meter: 2,247
Operation : Reset Settings [ v1.19 ]
PTFN : Nokia USB Serial Port (COM4)
PORT : 4
BROM : Init BROM
BROM init passed!
BROM : MEID : BBAD70AC092DB834DC07337B21E458B0
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : RETRO.11.02.11.p1
BOOT : SWR : 11.02.11
AGENT : RETRO.11.02.11.p1
BOOT : DA sent
DA : Sync Passed!
NOR: 00EF : 0060 : 0018 : 0000
NOR: [WINBOND] W25Q128FW
NOR:
TSIZE : 0x01000000 [ 16.00 MB ]
PSIZE : 0x01000000 [ 16.00 MB ]
STYPE : 0x00000000
STATUS : OK
Boot done!
FFS Info exists in MAUI : 0x00CD0000 : 0x00324000
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:01:08
The Following User Says Thank You to Nadeem Waris For This Useful Post:
Old 01-26-2020, 06:02   #1016 (permalink)
Member: 1080718
Thanks Meter: 2,247
PORT : 4
BROM : Init BROM
BROM init passed!
BROM : MEID : C889804EBEC668C9E229E3E6DA3ED6F1
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : N103.30.04.11.p1
BOOT : SWR : 30.04.11
AGENT : N103.30.04.11.p1
BOOT : DA sent
DA : Sync Passed!
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:00:31
Old 01-26-2020, 06:02   #1017 (permalink)
Member: 1080718
Thanks Meter: 2,247
PTFN : Nokia USB Serial Port (COM59)
PORT : 59
BROM : Init BROM
BROM init passed!
BROM : MEID : 4F7661552F21D15625B0B759218D07CE
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : KESA61A.10.00.11.p2
AGENT : KESA61A.10.00.11.p2
BOOT : DA sent
DA : Sync Passed!
NOR: 00EF : 0060 : 0017 : 0000
NOR: [WINBOND] W25Q64DW
NOR:
TSIZE : 0x00800000 [ 8.00 MB ]
PSIZE : 0x00800000 [ 8.00 MB ]
STYPE : 0x00000000
STATUS : OK
Boot done!
FFS Info exists in MAUI : 0x00580000 : 0x00278000
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:00:29
Old 01-26-2020, 06:05   #1018 (permalink)
Member: 1080718
Thanks Meter: 2,247
Nokia 130 2017 fully dead flash done With best
Operation : Write FirmWare [ v1.19 ]
PORT : 4
BROM : Init BROM
BROM init passed!
BROM : MEID : 9C9515A64E9A7890E6F8C7671465BB60
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : DA sent
DA : Sync Passed!
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
VPL SoftwareVersion : 11.02.11 [TA-1017]
DEV SoftwareVersion : 10.00.11
Load FlashSet :
MROM : TA-1017_ROM_eMP_11.02.11
LANG : TA-1017_LANG_PACK_ROM_IJ_eMP_11.02.11_001
CUST : TA-1017_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.02.11_001
JUMP : TA-1017_JUMP_TABLE_IJ_MEA_PK_eMP_11.02.11_001
VIVA : TA-1017_VIVA_eMP_11.02.11
Prepare FlashSet :
DCR : TA-1017_ROM_eMP_11.02.11
DCR : TA-1017_LANG_PACK_ROM_IJ_eMP_11.02.11_001
DCR : TA-1017_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.02.11_001
DCR : TA-1017_JUMP_TABLE_IJ_MEA_PK_eMP_11.02.11_001
DCR : TA-1017_VIVA_eMP_11.02.11
Prepare Target
SDS : OK : 0x007F8000 : 0x00008000
FFS Format Ok!
Erase Target Flash
Erase done!
Write Target Flash
Write : TA-1017_ROM_eMP_11.02.11
Write : TA-1017_LANG_PACK_ROM_IJ_eMP_11.02.11_001
Write : TA-1017_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.02.11_001
Write : TA-1017_JUMP_TABLE_IJ_MEA_PK_eMP_11.02.11_001
Write : TA-1017_VIVA_eMP_11.02.11
Write flash done!
Verify : TA-1017_ROM_eMP_11.02.11
Verify : TA-1017_LANG_PACK_ROM_IJ_eMP_11.02.11_001
Verify : TA-1017_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.02.11_001
Verify : TA-1017_JUMP_TABLE_IJ_MEA_PK_eMP_11.02.11_001
Verify : TA-1017_VIVA_eMP_11.02.11
Done!
Elapsed: 00:01:32
Old 01-26-2020, 06:05   #1019 (permalink)
Member: 1080718
Thanks Meter: 2,247
PORT : 4
BROM : Init BROM
BROM init passed!
BROM : MEID : FC829D90113FCDBDAA99D64A0A101FFF
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : DA sent
DA : Sync Passed!
NOR: 00C2 : 0025 : 0038 : 0000
NOR: [MXIC] MX25U12835FZNI_10G
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:00:46
Old 01-26-2020, 06:06   #1020 (permalink)
Member: 1080718
Thanks Meter: 2,247
PTFN : Nokia USB Serial Port (COM13)
PORT : 13
BROM : Init BROM
BROM init passed!
CHIP : MT6261 , SBID : 0xCA02 , HWVR : 0x8000 , SWVR : 0x0001
BROM : MEID : 209E2544E7EC7FB4BB65CD1914C9E025
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : DA sent
DA : Sync Passed!
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:00:25
Page generated in 0.39656 seconds with 9 queries
