07-05-2013, 07:26 | #407 (permalink) |
Freak Poster Join Date: Aug 2011
Member: 1635037 Status: Offline Sonork: 1590479 Thanks Meter: 41 | Phone found! Series 40 Device detected! read info... - Ok Using F-bus count... Sending code 467442959374398 Level : 7 to SimLock Server... Simlock Server Answer: Unlock code Accepted! Done! Phone disconected! Connect phone on selected interface... |
The Following User Says Thank You to USMAN KUNJAH For This Useful Post: |
10-02-2013, 18:47 | #410 (permalink) |
No Life Poster Join Date: Aug 2006 Location: SPAIN-----UK
Member: 333439 Status: Offline Sonork: 100.1589101 Thanks Meter: 623 | card found: S/N 9369:**** registered to: Toplink Connect phone on selected interface... Checking for device... Qualcomm MMC Storage , rev : 2.31 Drive space : 14 GiB Drive Index : 2 Processing MBR... Processing EBR... Check product info... Current OSBL mode : QUALCOMM Found : SeaRay Model : RM-801 , RM-819 Model : Lumia 800 Phone Id set to : 059N8B5_026AFA3AB Processing Lumia Wp7x Patch Unlock Found Location #1 State : Not Patched Patch ... Patch Ok Unlock Code (PIN) : 00000000 Unlock Code (PUK) : 0000000000 1. Power Up phone 1.0 Press Restart button 1.1 Or Reconnect Battery / 15sec. hold PowerOn, after PowerOn 2. Enter code (PIN or PUK) 3. After PIN/PUK accepted, you can restore state via "Restore SimLock state" (c) Wp7x Patch Unlock : Bph&co (Genie Projects) All done! |
The Following User Says Thank You to Allunlockingsource For This Useful Post: |
10-30-2013, 09:23 | #415 (permalink) |
Insane Poster Join Date: Jul 2009 Location: south sudan
Member: 1075366 Status: Offline Thanks Meter: 8 | problem with my nokia sl3 2730c-1 Phone found! Series 40 Device detected! read info... - Ok Upload Job procedure started... Phone Imei: 357411043890803 Checking locks... Conf key : 8000000000000000 Provider key : 5050200000000000 Country : Australia Operator : YES OPTUS Counters : Key 0 [3] , Fbus 0 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close ============================= LOCKS : Closed ============================= PA_SL3 (15 digit) phone detected... - > Power Off phone, dissconnect it and connect Phone disconected! Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... ASIC ID: 000000010000022600010006030C192101023000 CPU ID : RAP3Gv3 , Features : No any extended features PUBLIC ID: 01800119EC7B0556C32C0069970C42CE6BC28FFE ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 Error, this CPU not supported yet Fetching failed! Connect phone on selected interface... UFSx error, reconnect and try again... Upload Job fail...! Connect phone on selected interface... |
11-09-2013, 11:48 | #417 (permalink) |
Freak Poster Join Date: Aug 2005 Location: Accra.Ghana Age: 51
Member: 167261 Status: Offline Thanks Meter: 19 | [QUOTE=yubilabuok;9841631]problem with my nokia sl3 2730c- Fetching failed if you are using usb cable then dont use usb, use fbus cable to unlock your fone just to reag lbf and unlock direct its possible infinitybest unlock it all i fbus connection |
