03-05-2024, 21:13 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: HUR / R.S Age: 40
Member: 21750 Status: Offline Sonork: 100.62509 Thanks Meter: 73 | ta-1006 flashing failed Operation : Read Flash Dump [ v1.20 ] 1. Power off device, remove battery 2. Insert cable, press and hold BootKey ( # ) 3. Insert battery in device! Wait for device ... Device Connected! BootVersion : SPRD SECURE BOOT Block version BootVersion : BEST RETRO3G Port speed : 921600 FDL Flash : Control transfered! Boot Done! SW_VERS : 20.0.0.17.00 PC_EXTR : AW 059Z3B7 IMEI[1] : 355809090079950 IMEI[2] : 355809093079957 BT_ADDR : AF76F6D5C46C Dumping Flash Content ... Read Ok! Saved as : NKSPDv2_3558090900xxxxx.bin Saved to : C:\InfinityBox\BEST2\phdata\ Done! Elapsed: 00:12:51 Reconnect Power/Cable! File : TA-1006_20.0.0.17.00_AW_059Z3B7.sprd SWVersion : 20.0.0.17.00_AW_059Z3B7 Operation : Write FirmWare [ v1.20 ] Setting : True : Full Factory Reset Setting : False : NVRAM Update/Swap 1. Power off device, remove battery 2. Insert cable, press and hold BootKey ( # ) 3. Insert battery in device! Wait for device ... Device Connected! BootVersion : SPRD SECURE BOOT Block version BootVersion : BEST RETRO3G Port speed : 921600 FDL Flash : Control transfered! Boot Done! ERROR : NVRAM update FAIL! FILENAME : C:\Users\moust\Desktop\TA-1006_20.0.0.17.00_AW_059Z3B7.sprd\TA-1006_20.0.0.17.00_AW_059Z3B7.sprd ERRORINFO : 00000080:80000000FF7F7E65 Error : Flashing failed! Make sure device HW is in normal condition, check battery and cable! Reconnect Power/Cable! |
