07-02-2011, 11:08 | #1 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Whats this? After flashing Connect phone on selected interface... UFS S/N 113742 boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Checking StartUp data ... ----------------------- SDD Key status : SD Data is Ok SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL3 phone detected Done! Core version : 1.23 , Rev : 4.8 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm561__09.98.mcusw PPM : rm561__09.98.ppm_mh CNT : rm561__09.98_008.image_mh_ctv_in_v3_88814 Check FlashFiles, Please, wait... -> SWversion check skipped : Manual mode selected Backup enabled, Will read Certificates now... SL3 Simlock read ... ok WMDRM read ... ok CRT308 Backup Created Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 1B70010EFC7800561D0079089219F8931E4157A6 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 240000EC , CMT , NOR CMT Flash ID : 240000EC < SAMSUNG => K81259ETF FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 3EA22A1DDA660002E56108DB5072A10F8709443FA8 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 353394048272207 CMT : Read CCC certificate... Cert size : 30600 byte(s) CMT : Read HWC certificate... Cert size : 20480 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\infinity box\InfinityBox_install_BEST_v1.23\Backup\Cert\353 394048272207.rpl Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 1B70010EFC7800561D0079089219F8931E4157A6 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 240000EC , CMT , NOR CMT Flash ID : 240000EC < SAMSUNG => K81259ETF FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 3EA22A1DDA660002E56108DB5072A10F8709443FA8 Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm561__09.98.mcusw Found 6 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x000BFFFF CMT , NOR , Area : 0x000C0000 - 0x0013FFFF CMT , NOR , Area : 0x00140000 - 0x0137FFFF CMT , NOR , Area : 0x01380000 - 0x0151FFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:20 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm561__09.98.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] Total writen 1247 blocks TIME : Write time : 00:02:50 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm561__09.98.ppm_mh Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01520000 - 0x01DBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:24 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm561__09.98.ppm_mh Total writen 399 blocks TIME : Write time : 00:00:52 PrReq : NOR , 00 ConvertImage: Processing rm561__09.98_008.image_mh_ctv_in_v3_88814 ConvertImage: Page Size is 128K, no need convert Transmission mode : Dual (Ddr, TX2) Erase : Processing rm561__09.98_008.image_mh_ctv_in_v3_88814 Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01DC0000 - 0x0215FFFF CMT , NOR , Area : 0x02160000 - 0x03FBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:02:24 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm561__09.98_008.image_mh_ctv_in_v3_88814 Total writen 512 blocks TIME : Write time : 00:01:12 PrReq : NOR , 00 Init Service mode... Wait... Reading Phone Info.... Connected phone - Error Software Info: Error IMEI: Error Ape Version: Error Product code: Error Checking... SimLock status : SimLock Damaged!!!!! Security status : Security Damaged!!!!! Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
07-02-2011, 11:58 | #4 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | registered to: saeedullah_khan Connect phone on selected interface... Core version : 1.23 , Rev : 4.8 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm561__09.98.mcusw PPM : rm561__09.98.ppm_mh CNT : rm561__09.98_008.image_mh_ctv_in_v3_88814 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 1B70010EFC7800561D0079089219F8931E4157A6 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm561__09.98.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:03 Write : Processing rm561__09.98.mcusw Total 1256 [1256/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:01:36 MCU Write done ===Flashing [PPM]=== Erase : Processing rm561__09.98.ppm_mh Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:53 Write : Processing rm561__09.98.ppm_mh Total 399 [399/0/0] blocks to write, writing... TIME : Write time : 00:00:31 PPM Write done ===Flashing [CNT]=== Erase : Processing rm561__09.98_008.image_mh_ctv_in_v3_88814 Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:03:35 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm561__09.98_008.image_mh_ctv_in_v3_88814 Total 512 [512/0/0] blocks to write, writing... TIME : Write time : 00:00:37 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:09:18 Reboot phone now... -> Flashing Failed! Maybee HW error, or Downgrade try???! Anyway - try reinsert battery and PowerUp phone manualy Connect phone on selected interface... Done! Elapsed: 00:11:26 Connect phone on selected interface... |
07-02-2011, 13:44 | #6 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | registered to: saeedullah_khan Connect phone on selected interface... UFS S/N 113742 boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core version : 1.23 , Rev : 4.8 Selected FlashSettings : Manual Files Set for Flashing : CNT : 92801557_rm561__09.98.image_t_ph_gray Check FlashFiles, Please, wait... -> SWversion check skipped : Custom mode selected Backup enabled, Will read Certificates now... SL3 Simlock read ... ok WMDRM read ... ok CRT308 Backup Created Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 1B70010EFC7800561D0079089219F8931E4157A6 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 240000EC , CMT , NOR CMT Flash ID : 240000EC < SAMSUNG => K81259ETF FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 3EA22A1DDA660002E56108DB5072A10F8709443FA8 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 353394048272207 CMT : Read CCC certificate... Cert size : 30600 byte(s) CMT : Read HWC certificate... Cert size : 20480 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\BEST_v1.23\Backup\Cert\353394048272207.rpl Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 1B70010EFC7800561D0079089219F8931E4157A6 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 240000EC , CMT , NOR CMT Flash ID : 240000EC < SAMSUNG => K81259ETF FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 3EA22A1DDA660002E56108DB5072A10F8709443FA8 Transmission mode : Dual (Ddr, TX2) Boot Done! ConvertImage: Processing 92801557_rm561__09.98.image_t_ph_gray ConvertImage: Page Size is 128K, no need convert Transmission mode : Dual (Ddr, TX2) Erase : Processing 92801557_rm561__09.98.image_t_ph_gray Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01DC0000 - 0x0215FFFF CMT , NOR , Area : 0x02160000 - 0x03FBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:01 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing 92801557_rm561__09.98.image_t_ph_gray Total writen 696 blocks TIME : Write time : 00:01:30 PrReq : NOR , 00 Init Service mode... Wait... Init Service mode Failed! Skip AfterFlash Connect phone on selected interface... |
07-02-2011, 16:18 | #10 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Yes, can be HW. But as i can see - we have rpl backup - NPC + SLD is very important. So - can try erase and reflash it after. If still no luck - it is HW problem. I just prefer exclude SW part first, before digg hw. |
07-04-2011, 08:48 | #12 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | problam solve after wash+rehoot registered to: saeedullah_khan Connect phone on selected interface... UFS S/N 113742 boot - Ok Connect phone on selected interface... Core version : 1.23 , Rev : 4.8 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm561__09.97.mcusw PPM : rm561__09.97.ppm_mena_b CNT : rm561__09.97.image_mena_b_red Check FlashFiles, Please, wait... -> SWversion check skipped : Dead mode selected Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 1B70010EFC7800561D0079089219F8931E4157A6 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 240000EC , CMT , NOR CMT Flash ID : 240000EC < SAMSUNG => K81259ETF FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent PAPUBkeys blank (erased or HW failure) Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm561__09.97.mcusw Found 6 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x000BFFFF CMT , NOR , Area : 0x000C0000 - 0x0013FFFF CMT , NOR , Area : 0x00140000 - 0x0137FFFF CMT , NOR , Area : 0x01380000 - 0x0151FFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:05 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm561__09.97.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] Total writen 1247 blocks TIME : Write time : 00:02:32 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm561__09.97.ppm_mena_b Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01520000 - 0x01DBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:02 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm561__09.97.ppm_mena_b Total writen 353 blocks TIME : Write time : 00:00:43 PrReq : NOR , 00 ConvertImage: Processing rm561__09.97.image_mena_b_red ConvertImage: Page Size is 128K, no need convert Transmission mode : Dual (Ddr, TX2) Erase : Processing rm561__09.97.image_mena_b_red Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01DC0000 - 0x0215FFFF CMT , NOR , Area : 0x02160000 - 0x03FBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:08 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm561__09.97.image_mena_b_red Total writen 528 blocks TIME : Write time : 00:01:05 PrReq : NOR , 00 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 2700 classic Software Info: V 09.97 18-06-10 RM-561 (c) Nokia IMEI: 12345610654321? Product code: Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) SimLock Data found! SimLock key found! WMDRM key found! Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 1B70010EFC7800561D0079089219F8931E4157A6 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 240000EC , CMT , NOR CMT Flash ID : 240000EC < SAMSUNG => K81259ETF FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 3EA22A1DDA660002E56108DB5072A10F8709443FA8 Transmission mode : Dual (Ddr, TX2) Boot Done! Preparing for write certificates... Switching to CMT... CMT : NPC erase Ok Writing NPC... Ok CMT : CCC erase Ok Writing CCC... Ok CMT : HWC erase Ok Writing HWC... Ok Init Service mode... Wait... Check phone mode... Phone already in Test mode, skip change... Writing SimLock Key... Ok! Writing SimLock Data... Ok! SDD Key status : SDData Damaged!!!!! SimLock status : SimLock is Ok Security status : Security is Ok Done! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Repair SD procedure started... Phone Imei: 353394048272207 Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 1B70010EFC7800561D0079089219F8931E4157A6 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... CMT Loader sent, Boot Ok rap= 1B70010EFC7800561D0079089219F8931E4157A6 hash= 9DDBFCFE6E73CED7D8C6268C8EB85723 key= 659BFA2DD11E45DA8D6DA48C5CC586393D22388E Init Service mode... Wait... Key file updated... Check phone mode... Phone already in Test mode, skip change... Writing Super Dongle Key... Ok Done! Checking StartUp data ... ----------------------- SDD Key status : SD Data is Ok SimLock status : SimLock is Ok Security status : Security Damaged!!!!! ----------------------- PA_SimLock Version : PA_SL3 phone detected Done! Local SX4 procedure started... Phone Imei: 353394048272207 Key file exists, no need to read... Step 1... Step 2... Step 3... SX4 Auth - Ok Done! Uploading RF/Battery tune to phone... Using : RM-561.pm Operating mode is OK, no need change... Field 1 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Record 13 write - Ok Record 14 write - Ok Record 15 write - Ok Record 16 write - Ok Record 17 write - Ok Record 19 write - Ok Record 20 write - Ok Field 2 Record 0 write - Ok Field 309 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 4 write - Ok Record 5 write - Ok Record 7 write - Ok Record 8 write - Ok Record 17 write - Ok Record 22 write - Ok Check ST_SECURITY now... Security status : ST_SECURITY => OK Done! Elapsed: 00:00:02 Checking StartUp data ... ----------------------- SDD Key status : SD Data is Ok SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL3 phone detected Done! Checking Camera Configuration... Operating mode is OK, no need change... CAM1 HW : NIMMIIIIRRFF00000000 CAM1 SW ver : XXXXXX [ SW damaged ] Configuration NIMMIIIIRRFF00000000.dcc not found... Secondary Camera #2 configuration info not exist Done! |
07-04-2011, 11:01 | #14 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | know ok registered to: saeedullah_khan Connect phone on selected interface... UFS S/N 113742 boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Checking Camera Configuration... Operating mode is OK, no need change... CAM1 HW : NIMMIIIIRRFF0A021001 CAM1 SW ver : 002007 Updating Camera #1 Configuration... Upload done, checking... CAM1 SW ver : 002007 Configuration Ok! Secondary Camera #2 configuration info not exist Done! Reading Phone Info.... Connected phone - Nokia 2700 classic Software ver : V 09.97 18-06-10 RM-561 (c) Nokia IMEI : 353394048272207 Ape Ver : APE Var : APE ADSP: DSP Ver : ICPR72_09w26 APE Test: PPM : V 09.97 18-06-10 RM-561 (c) Nokia MEN CNT : Content: mena_b_red V 09.97 18-06-10 RM-561 (c) Nokia Product SN : 0 Product code : Base Prd.code: Module code : Long Prod.SN : 0 Hardware info======= HWID : Retu : 16 Tahvo : 22 Batery: 4687 mV Camera: CMT BT: 2222-302 APE BT: APE HW: LCDVer: SEIKO RF ic : 06540601 Lock info =========== IMEI : 353394048272207 IMEI spNet : IMEI svNet : Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
SIM restriction pending -- what does it mean? | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 07-17-2011 10:05 |
