09-25-2010, 10:34 | #1 (permalink) |
Freak Poster Join Date: May 2006 Location: SUDAN Age: 39
Member: 271980 Status: Offline Sonork: 100.1573370 Thanks Meter: 227 | <<< How to enter unlock code >>> Berfore you asking about the how to entering code . u can find the step's here in this thread Nokia How to enter my Unlock Code on Nokia ? Model : All Nokia |
The Following 6 Users Say Thank You to kabo tel For This Useful Post: |
09-25-2010, 10:35 | #2 (permalink) |
Member: 271980 Status: Offline Sonork: 100.1573370 Thanks Meter: 227 | Motorola Motorola How to enter my Unlock Code on Motorola ? Model : All MotorolaMOTOROLA Z8, Z10 RIZR: **057*CODE with SIM |
09-25-2010, 10:38 | #4 (permalink) |
Member: 271980 Status: Offline Sonork: 100.1573370 Thanks Meter: 227 | Lg Model's LG How to enter my Unlock Code on LG ? Model : LG KB770 |
The Following 5 Users Say Thank You to kabo tel For This Useful Post: |
09-25-2010, 10:48 | #5 (permalink) |
Member: 271980 Status: Offline Sonork: 100.1573370 Thanks Meter: 227 | htc HTC How to enter codes in G1 - GOOGLE (HTC fone) IMP: U MUST HAVE ONE SIM CARD WHICH HAS DATA SERVICES ENABLED ON IT. Step 1 Insert any other sim card in phone other than Tmobile simcard, this simcard which you insert should have 3G activated on it, the phone will ask you to enter unlock code, Here you must enter unlock code given by us to you . Step 2 Press MENU Button on the phone you will see small button on the lower part of screen pop up APN settings Now click : APN settings You will see a list of Tmobile service click again Menu button A new button will pop up click New Apn Now enter your network settings here and then sign in to gmail ------------------------------------------------------------------- How to enter codes in htc based fones. Answer : put a cross sim card in , other than the fone is locked , it ask u to input unlock code , the code u recieved from us 8 digits one , enter it , if asked twice do the same .show u network means ur fone is unlocked |
The Following 3 Users Say Thank You to kabo tel For This Useful Post: |
09-25-2010, 10:52 | #6 (permalink) |
Member: 271980 Status: Offline Sonork: 100.1573370 Thanks Meter: 227 | Samsung How to enter my Unlock Code on Samsung ? Samsung i200 Unlock Codes: 83795xxx 50295xxx 50295xxx 4697xxx 1. Insert an unaccepted sim inside and turn on 2. Screen asks for 'unlock code', 'new code', 'confirm new code', put in the first code 83795xxx three times; 3. Screen asks me another 'unlock code', put in the second code 50295xxx Model: Samsung i616 Jack or Blackjack2 from Fido Canada 1. Power ON your phone with a FIDO SIM Card that the phone is locked to 2. Type #7465625*638* 3. Network Lock Screen appear, enter UNLOCK CODE 4. Device is now unlocked Model: Samsung A767 (Propel), A437, T459 (Gravity): 1 - Power on without SIM 2 - Type in #7465625*638*Unlock code# (8 digit unlock code*) 3 - Device should say: “Network Lock Deactivated” 4 - Phone may automatically reboot Model: Samsung SGH-T459 (Gravity): 1. Power on without SIM 2. From the standby screen, use the dial pad to enter the number sequence 3. Type in #7465625*638*Unlock code# (8 digit unlock code*) 4. Device should say: “Network Lock Deactivated” Model: Samsung i900 / Omnia 1 - Switch ON your phone with a NON Accepted SIM Card, 2 - Enter the pin code of this refused Simcard 3 - Device is now asking for another pin code 4 - Then enter the Unlock Code ! Model: Samsung Zxxx, Dxxx, Pxxx & F490 (ex : Z140, D520, P200, etc...) 1 - Switch ON your phone with a not Accepted SIM Card, 2 - Compose : #7465625*638*CODE# Model: Samsung Z510 et Z320i et Z650i : 1 - Switch ON your phone with a not Accepted SIM Card, 3 - Compose **CODE# Model : All others Samsung 1 - Switch ON your phone with a not Accepted SIM Card, 2 - Phone will ask for "Password", 3 - You can now enter the Unlock Code we send to you. OR (if phone show "Insert Correct SIM Card") 1 - Switch ON your phone with a not Accepted SIM Card, 2 - Compose : #0111*CODE# Model : Samsung i450 & i560 and I8910 1 - Switch ON your phone without SIM Card, 2 - Compose #PW+CODE+1# The letter P appear after press 3 times quickly the button star ( * ) The letter W appear after press 4 times quickly the button star ( * ) The letter + appear after press 2 times quickly the button star ( * ) Model : Samsung i780 1. Insert an unaccepted SIM card 2. Enter the pin code to simcard 3. At the top of screen an "exclamation mark" icon will appear 6. Click on "exclamation mark" icon 7. There will appear link "settings" - click on it 8. Virtual keyboard appears on screen with Enter PIN prompt. 9. Enter your 8-digit unlock code. Model : Samsung SGH-P207: 1. Reset to original factory setting by typing *2767*3855#, youre phone will reboot 2. Then insert a sim card that is from another network that your phone is not locked to. 3. An Wrong sim message will come up on the screen 4. When message appears type in* #9998*3323# 5. At this time a white screen will appear which says "exit" 6. Tap the rigth soft key, (occasionally it will not go to the next screen, if so press the down key) 7. From the menu that appears scroll down to the malloc Fail option, this will reboot, and normal service screen will appear. 8. Then type *0141# and press the green call key, Personalized will appear on the screen, and the name of the current sim card provider will appear on the screen. 9. Turn phone off, and then turn on 10. Go to menu by tapping left soft key, then settings in bottom right hand corner, then choose option number 7 security, then choose option number 6 Sim Lock, select option 1 disable 11. Then enter 00000000 (eight zeros), the message will come up sim lock disabled with a check mark, your phone is now unlocked to use with other carriers. |
09-25-2010, 10:53 | #7 (permalink) |
Member: 271980 Status: Offline Sonork: 100.1573370 Thanks Meter: 227 | Sagem How to enter my Unlock Code on Sagem ? Model : Sagem My-S7 |
09-25-2010, 10:54 | #8 (permalink) |
Member: 271980 Status: Offline Sonork: 100.1573370 Thanks Meter: 227 | Sharp How to enter my Unlock Code on Sharp ? Model : All Sharp |
09-25-2010, 10:55 | #9 (permalink) |
Member: 271980 Status: Offline Sonork: 100.1573370 Thanks Meter: 227 | Huawei How to enter my Unlock Code on Huawei ? 1) open Hyperterminal : C:\Program Files\Windows NT (should be there) 2) you must set com port on modem (Huawei Mobile Connect - 3G Modem) 3) type following command : AT^CARDLOCK="<you unlock code>" 4) Validate by pressing Enter. |
09-25-2010, 10:56 | #10 (permalink) |
Member: 271980 Status: Offline Sonork: 100.1573370 Thanks Meter: 227 | Toshiba How to enter my Unlock Code on Toshiba ? Model: Portege G710 1 - Power on phone with sim accepted 2 - Put pin code 3 - When phone is ready, go to: START - ACCESORIES - UNLOCK SIM 4 - Enter UNLOCK CODE, and ACCEPT |
09-25-2010, 10:56 | #11 (permalink) |
Member: 271980 Status: Offline Sonork: 100.1573370 Thanks Meter: 227 | Pantech How to enter my Unlock Code on Pantech ? 1.POWER ON PHONE WITH ACCEPETED SIM CARD |
09-25-2010, 10:56 | #12 (permalink) |
Member: 271980 Status: Offline Sonork: 100.1573370 Thanks Meter: 227 | Utstarcom How to enter my Unlock Code on Utstarcom ? Model: GTX750R |
09-25-2010, 10:57 | #13 (permalink) |
Member: 271980 Status: Offline Sonork: 100.1573370 Thanks Meter: 227 | Cingular BlackJack How to enter my Unlock Code on Cingular BlackJack ? Insert disallowed simcard (a simcard that the phone does not usaully accept) and enter unlock codes when prompted |
09-25-2010, 10:58 | #14 (permalink) |
Member: 271980 Status: Offline Sonork: 100.1573370 Thanks Meter: 227 | Sanyo How to enter my Unlock Code on Sanyo ? Model : All Sanyo |
09-25-2010, 10:58 | #15 (permalink) |
Member: 271980 Status: Offline Sonork: 100.1573370 Thanks Meter: 227 | Sendo How to enter my Unlock Code on Sendo ? Model : All Sendo |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
