Dragon Box Chinese Phone Tool |
12-03-2012, 15:39 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: JHELUM,PAKISTAN
Member: 1082557 Status: Offline Sonork: 100.1611230 Thanks Meter: 199 | All in one solution If you guys have any problems post it here i will try to solve that in 12 hours.. So in these days users are facing a lot of problem about USB connecting, MStar Connecting, Return Data error, Connecting Mobile and not loading boot.. So here are the links of New drivers... BOX DRIVERS WIN 7>>>> Box Driver.rar - 4shared.com - online file sharing and storage - download - Mirza Atif MStar Drivers>>>> Mstar Driver.rar - 4shared.com - online file sharing and storage - download - Mirza Atif MTK USB Drivers>>>>> MTK USB Driver.rar - 4shared.com - online file sharing and storage - download - Mirza Atif SPD USB + Andriod>>>>> USB-Spreadtrum Android.rar - 4shared.com - online file sharing and storage - download - Mirza Atif __________________________________________________ ______ Return Data Error When this error come you have to check several things First check that you are connecting right chip or not... Question = How to check it??? Answer = Use dragon freeware tool OR open phone and read name from main chip. Second if using USB then install proper drivers __________________________________________________ _______ Connecting Mobile Error If you get this error do several things.. First check that you are connecting right chip or not... How to check mentioned above Second uncheck the option of scan pin-out then connect.... __________________________________________________ _______ Any error else you get then post it here.. WITH BEST REGARDS. |
The Following 6 Users Say Thank You to nice_champ For This Useful Post: |
12-04-2012, 07:15 | #2 (permalink) |
Member: 1082557 Status: Offline Sonork: 100.1611230 Thanks Meter: 199 | WRITE IMEI ERROR If you got this error that mobile is connected with box but not writing IMEI then do several things... >>First untick scan pinout option then check >>Second remove black pin(Ground PIN) from battert connectors and connect it on mobile boar at gnd anywhere on board but on gnd >>Third remove the ringer from board then check. Your problem will be solve.. |
The Following 2 Users Say Thank You to nice_champ For This Useful Post: |
12-04-2012, 07:18 | #3 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | @nice_champ they all already post but the problem is that we not use search button before posting in forum |
The Following User Says Thank You to Faheem Anjum For This Useful Post: |
12-04-2012, 08:53 | #5 (permalink) |
Freak Poster Join Date: Jul 2011
Member: 1626204 Status: Offline Thanks Meter: 48 | celkon c770i charging jack fully damaged............i wnt to flash the phone....and i connect the rx tx to pcb dm & dp..........but not connected the phone ...... plse help me how to slove my problem.................i have more than 5 sets same problem facing....................it have mstar chip............plse help me bro |
12-04-2012, 09:20 | #6 (permalink) |
Member: 1082557 Status: Offline Sonork: 100.1611230 Thanks Meter: 199 | Have you connected the gnd pin or not? If not then connect it. If connected then UN tick he option of pin-out and then check.. Then reply me |
12-04-2012, 14:21 | #7 (permalink) |
Member: 1082557 Status: Offline Sonork: 100.1611230 Thanks Meter: 199 | TIPS ABOUT UPDATES In new updates some of those mobiles which are connecting and working fine on old versions are not connecting perfectly on new updates. So no need to worry about them just use 2.13 version of dragon your problem will be solve. PROBLEM WITH USB CONNECTING In my opinion there are a lot of problems with USB connecting and that is all about the Drivers so with my personal experience use the WINDOWS 7.. Then you will not face any problem like this |
The Following 3 Users Say Thank You to nice_champ For This Useful Post: |
12-10-2012, 15:00 | #8 (permalink) | |
Freak Poster Join Date: Nov 2011 Location: Indonesia Age: 40
Member: 1687184 Status: Offline Sonork: 100.1621473 Thanks Meter: 24 | Quote:
The Following User Says Thank You to solitaire09 For This Useful Post: |
12-10-2012, 15:07 | #9 (permalink) | |
Member: 1082557 Status: Offline Sonork: 100.1611230 Thanks Meter: 199 | Quote:
Dragon box work perfect on both windows but that was those users who can not install drivers at their own .. So window 7 automatically download drivers from updates | |
12-13-2012, 20:17 | #10 (permalink) |
Member: 1082557 Status: Offline Sonork: 100.1611230 Thanks Meter: 199 | Flash Files HOW SEARCH FLASH FILES Dear dragon users all the files which you need are already uploaded. Just you need to use search. So here are some links to search your desire flash file http://forum.gsmhosting.com/vbb/f457...h-file-567608/ Dragon Flash Files - GSM-Forum Http://www.gpgindustries.com First try to search here then post thread if you can't find.... WITH BEST REGARDS |
12-17-2012, 10:02 | #11 (permalink) |
Member: 1082557 Status: Offline Sonork: 100.1611230 Thanks Meter: 199 | PC RESTART ON SPD FORMATTING Dear users there is a problem occuring during formatting the SPD chip specially on USB... So no need to worry just remove the old USB Drivers of SPD and install new drivers... Link is given below.. When i was facing this problem then i removed old drivers and installed this one... Then dragon start working fine on same mobile... http://www.4shared.com/rar/m4oqqWdw/USB-Spreadtrum.html WITH BEST REGARDS |
12-26-2012, 13:34 | #12 (permalink) |
Member: 1082557 Status: Offline Sonork: 100.1611230 Thanks Meter: 199 | New solutions 6610/20 CPU'S CONNECTING ERROR In these days many users facing problem about 6610/20 CPU'S mobile.. So users you have to do just one thing that change the baud rate to 115200.. These two CPU'S work like charm on this baud rate... WRITE IMEI ERROR Users i have already described some of solution about write imei error but after applying those solution some of mobiles do not succeeded in write imei. So the real fact is this that in older version there is a fault which was Called by ""NO IMEI FOUND"""... These two error are the same things so you what to do just use 2.13 version of dragon and write nv file via NV Editor.. |
01-31-2013, 13:34 | #14 (permalink) |
Member: 1082557 Status: Offline Sonork: 100.1611230 Thanks Meter: 199 | Q-MOBILES DRIVER PROBLEM Hi, I was facing a problem with mostly Q-MOBILES that they don't pick the drivers while i have installed WIN-7 on my PC.. I tried to find drivers on internet but could not make it. Then i installed a software from new Q-MOBILE'S CD which comes with mobile and after that mostly of Q-MOBILES auto pick their drivers... So if you are facing same problem then install that software you will get mostly of mobiles drivers... WITH BEST REGARDS.. |
05-13-2013, 05:24 | #15 (permalink) |
Junior Member Join Date: May 2013
Member: 1934336 Status: Offline Thanks Meter: 0 | what is it? >>> Getting Mobile Connection Info... VCC Pin: GND Pin:2, 4, Signal Pin:3, 5, 6, 7, 8, 18, 19, 20, 21, 22, 23, 24, >>> Scanning Mobile PinOut... >>> Please Hold the Power key... Get Mobile PinOut: TXD:8 RXD:6 >>> Please Hold the Power key... >>> Connecting Mobile... ***********AT THIS POINT MOBILE STARTS? >>> Return DATA Error!!! |
