Dragon Box Chinese Phone Tool |
09-23-2013, 10:03 | #61 (permalink) |
No Life Poster Join Date: Dec 2009 Location: VOLCANO TEAM Age: 39
Member: 1175029 Status: Offline Sonork: 100.1597135 Thanks Meter: 401 | MICROMAX - A27 CPU - 8810 FORMAT DONE BY GPG DRAGON Box MICROMAX - A27 CPU - 8810 FORMAT DONE BY GPG DRAGON Box READ INFO. FORMAT DONE. Br. OM TELCOM |
The Following User Says Thank You to om telcom For This Useful Post: |
09-26-2013, 14:38 | #62 (permalink) |
Freak Poster Join Date: Jul 2006 Age: 54
Member: 320105 Status: Offline Thanks Meter: 18 | karbonn a6 successfully formated karbonn a6 successfuly formated with gpgdragon v3.33 google account removed >>> Detecting COM PortCOM217 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:00002CBC Flash Size:20000000->512M Flash Name:NAND_SamSungMT29C4G48MAZAPAKD CPU Name:6820/8810 >>> Auto Formatting ... Format_RuntimeNV...Fail. Format_Cache...Fail. Format_Misc...Fail. Format_UserData...Success. All Done... |
09-29-2013, 10:29 | #65 (permalink) |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Lava iris s349+ pattern unlock gpg dragon box TODAY I AM RESET PATTERN LOCK PATTERN LOCK IMAGE FORMATE GPG DRAGON BOX PATTERN UNLOCK IMAGE GPG DRAGON BOX |
The Following 3 Users Say Thank You to .::THE ROCK::. For This Useful Post: |
09-30-2013, 08:49 | #67 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | intex cloud x1 pattern unlock GPG DROGON intex cloud x1 pattern unlock GPG DROGON HRER LOG Code: >>> USB Pinfind No need Hold Mobile Power key... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM43 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:0000ECBC Flash Size:20000000->512M Flash Name:NAND_SamSungK9K4G16Q0M CPU Name:6820/8810 >>> Auto Formatting ... Format_RuntimeNV...Fail. Format_Cache...Fail. Format_Misc...Fail. Format_UserData...Success. All Done... |
10-01-2013, 13:51 | #68 (permalink) |
No Life Poster Join Date: Feb 2010 Location: india kerala,MALAPURAM EDAKKAR
Member: 1224654 Status: Offline Sonork: jaheer Thanks Meter: 61 | can u send this same file for me.pls,,,,, samsung clone spd android set firmware pls >>> USB Pinfind No need Hold Mobile Power key... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM48 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:0000ECBC Flash Size:20000000->512M Flash Name:NAND_SamSungK9K4G16Q0M CPU Name:6820/8810 All Done... |
10-01-2013, 14:18 | #69 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | MICROMAX A27 pattern unlock Successfully done by GPGDragon MICROMAX A27 pattern unlock Successfully done by GPGDragon Code: >>> USB Pinfind No need Hold Mobile Power key... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM43 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:0000ECBC Flash Size:20000000->512M Flash Name:NAND_SamSungK9K4G16Q0M CPU Name:6820/8810 >>> Auto Formatting ... Format_RuntimeNV...Fail. Format_Cache...Fail. Format_Misc...Fail. Format_UserData...Success. All Done... |
10-02-2013, 13:07 | #70 (permalink) | |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Micromax a27 paatern unlock Quote:
10-23-2013, 13:02 | #73 (permalink) |
No Life Poster Join Date: Mar 2012 Location: INDIA
Member: 1740430 Status: Offline Sonork: 100.1627542 Thanks Meter: 198 | lava iris 349 google account remove by dragon box USE USB CABLE AND PRESS VOL DOWN KEY +POWER KEY INSERT USB >>> USB Pinfind No need Hold Mobile Power key... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM101 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:00002CBC Flash Size:20000000->512M Flash Name:NAND_SamSungMT29C4G48MAZAPAKD CPU Name:6820/8810 >>> Auto Formatting ... Format_RuntimeNV...Fail. Format_Cache...Fail. Format_Misc...Fail. Format_UserData...Success. All Done... BR:,VICKY TOMAR |
10-23-2013, 15:08 | #74 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | MICROMAX A27 pattern unlock Successfully done by GPGDragon MICROMAX A27 pattern unlock Successfully done by GPGDragon Code: >>> USB Pinfind No need Hold Mobile Power key... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM43 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:0000ADBC Flash Size:20000000->512M Flash Name:NAND_HYNIXH8BCS0UN0MCR CPU Name:6820/8810 >>> Auto Formatting ... Format_RuntimeNV...Fail. Format_Cache...Fail. Format_Misc...Fail. Format_UserData...Success. All Done... |
10-24-2013, 08:36 | #75 (permalink) |
Junior Member Join Date: Mar 2012 Age: 33
Member: 1730078 Status: Offline Sonork: 165137:saifu Thanks Meter: 9 | Symphony w12 Pattern Lock Removed By GPGDragon Symphony w12 Pattern Lock Removed By GPGDragon Symphony w12 Pattern Lock Removed By GPGDragon Last edited by Dipendra Pathak; 03-04-2014 at 13:02. |
