blackcherry bl9000 touch callibration...Solved my bl9000 stucks on callibration,its touch is not working properly.so help me to remove callibration with dragon box...thx |
Which CPU inside your phone? |
Initializing... DA_LIB_VER_3.2.1.3 It is sensing the pinout fast... D-=10 D+=9 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM201 Connected...sending boot... FDL test...OK ArmBootMode: 6600700500005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L/WT6226A Flash: NOR_ST_M30L0T7000T0 setting the Flash Parameters... Settings have been completed! Reading FileSystem info... File System Ver: 0A IMEI 1=352751040990238 IMEI 2=352751040990246 --------NOR_FLASH_CONFIG-------- Flash Bank count=1 EFS sector count=7 File sector count=0 Sector size=0x00020000 Flash start addr=0x00000000 Flash size=0x01000000 Fix NV addr=0x00EE0000 Product information addr=0x00FE0000 MMI resource addr=0x00A20000 ------Auto Format Address------- Start=0x00F00000 Size =0x000E0000 Read FS info...done |
here is log sir Initializing... DA_LIB_VER_3.2.1.3 It is sensing the pinout fast... D-=10 D+=9 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM201 Connected...sending boot... FDL test...OK ArmBootMode: 6600700500005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L/WT6226A Flash: NOR_ST_M30L0T7000T0 setting the Flash Parameters... Settings have been completed! Reading FileSystem info... File System Ver: 0A IMEI 1=352751040990238 IMEI 2=352751040990246 --------NOR_FLASH_CONFIG-------- Flash Bank count=1 EFS sector count=7 File sector count=0 Sector size=0x00020000 Flash start addr=0x00000000 Flash size=0x01000000 Fix NV addr=0x00EE0000 Product information addr=0x00FE0000 MMI resource addr=0x00A20000 ------Auto Format Address------- Start=0x00F00000 Size =0x000E0000 Read FS info...done |
I think you need only press RED button on your handset if not solved then you need full flash your phone and you get flash file from here http://forum.gsmhosting.com/vbb/6828877-post356.html |
thx4 reply sir but my phone is blinking on logo after flashing with this file,i have no backup ...plz help |
You need reset your handset with box and after reset press and hold power button on your handset for 1/2 minutes |
i have tried all but same then i have changed touch screen and its ok now...anyway thx 4 fast support.. |
