Dragon Box Chinese Phone Tool |
04-28-2011, 08:01 | #1 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 752540 Status: Offline Thanks Meter: 18 | blackcherry bl9000 touch callibration...Solved Last edited by Faheem Anjum; 04-29-2011 at 15:00. |
04-28-2011, 08:23 | #3 (permalink) |
Member: 752540 Status: Offline Thanks Meter: 18 | Initializing... DA_LIB_VER_3.2.1.3 It is sensing the pinout fast... D-=10 D+=9 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM201 Connected...sending boot... FDL test...OK ArmBootMode: 6600700500005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L/WT6226A Flash: NOR_ST_M30L0T7000T0 setting the Flash Parameters... Settings have been completed! Reading FileSystem info... File System Ver: 0A IMEI 1=352751040990238 IMEI 2=352751040990246 --------NOR_FLASH_CONFIG-------- Flash Bank count=1 EFS sector count=7 File sector count=0 Sector size=0x00020000 Flash start addr=0x00000000 Flash size=0x01000000 Fix NV addr=0x00EE0000 Product information addr=0x00FE0000 MMI resource addr=0x00A20000 ------Auto Format Address------- Start=0x00F00000 Size =0x000E0000 Read FS info...done |
04-28-2011, 08:25 | #4 (permalink) |
Member: 752540 Status: Offline Thanks Meter: 18 | here is log sir Initializing... DA_LIB_VER_3.2.1.3 It is sensing the pinout fast... D-=10 D+=9 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM201 Connected...sending boot... FDL test...OK ArmBootMode: 6600700500005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L/WT6226A Flash: NOR_ST_M30L0T7000T0 setting the Flash Parameters... Settings have been completed! Reading FileSystem info... File System Ver: 0A IMEI 1=352751040990238 IMEI 2=352751040990246 --------NOR_FLASH_CONFIG-------- Flash Bank count=1 EFS sector count=7 File sector count=0 Sector size=0x00020000 Flash start addr=0x00000000 Flash size=0x01000000 Fix NV addr=0x00EE0000 Product information addr=0x00FE0000 MMI resource addr=0x00A20000 ------Auto Format Address------- Start=0x00F00000 Size =0x000E0000 Read FS info...done |
04-28-2011, 08:27 | #5 (permalink) |
Cheater -Don't Deal with him- Join Date: Jun 2009 Location: PAKISTAN/UAE
Member: 1050335 Status: Offline Sonork: 100.1602801 Thanks Meter: 4,174 | I think you need only press RED button on your handset if not solved then you need full flash your phone and you get flash file from here http://forum.gsmhosting.com/vbb/6828877-post356.html |
04-28-2011, 09:41 | #7 (permalink) |
Member: 1050335 Status: Offline Sonork: 100.1602801 Thanks Meter: 4,174 | You need reset your handset with box and after reset press and hold power button on your handset for 1/2 minutes |
I need flash to Alcatel One Touch Viev db: Be 3, 2 mb,16A | sosin | Alcatel & TCL Old Models | 0 | 02-13-2002 03:47 |
anyone gotone touch unlock for T191??? | unlockgod | Motorola ODM | 0 | 01-10-2002 17:21 |
Nokia 3210 v5.36 how leads must touch the phone? | Psyko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-24-2000 18:18 |
Wanted: Net monitor for alcatel one touch club+ | X-tommy | Alcatel & TCL Old Models | 1 | 07-23-1999 03:44 |
Alcatel One Touch cable needed!!! | tati | Alcatel & TCL Old Models | 0 | 05-17-1999 22:05 |
