Dragon Box Chinese Phone Tool |
09-11-2012, 07:34 | #1816 (permalink) |
No Life Poster Join Date: Nov 2007 Location: karachi pakistan
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Action=ReadInfo FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM7 Baudrate=115200 CPU_Type=SC6600L7 CPU_ID=66007009 NOR_ID=0020882800208828 NOR_Size=0MB NOR_Name=NOR_UNKNOWN NOR_DieCnt=0 NAND_ID= NAND_Size= NAND_Name= CPU_Type=SC6600L7 CPU_ID=66007009 NOR_ID=0020882800208828 NOR_Size=16MB NOR_Name=User-defined NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... RXD=6 TXD=7 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700900026A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Manufacturer: ST & NUMONYX, Device: Unknow CPU: SC6600L7 Flash: NOR_UNKNOWN setting the Flash Parameters... Settings have been completed! CPU: SC6600L7 Flash: User-defined Reading FileSystem info... File System Ver: 0A IMEI 1=352273017386340 IMEI 2=352751019523267 ------Auto Format Address------- Start=0x003D0000 Size =0x00C30000 Read FS info...done |
09-11-2012, 07:34 | #1817 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=SpreadTrum Action=Reset FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM7 Baudrate=115200 CPU_Type=SC6600L2 CPU_ID=66007001 NOR_ID=0020881000208810 NOR_Size=8MB NOR_Name=NOR_ST_M58WR064KT NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... RXD=8 TXD=3 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700100006A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_ST_M58WR064KT setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Analyzing FileSystem... Done. Reset the user data area... Note: if user partition size is more than 4MB, The phone would may take 1 minute to rebuild FileSystem after Reset Action. All Done. |
09-11-2012, 07:35 | #1818 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=SpreadTrum Action=WriteFlash FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x00800000 Interface=COM FlashFile=C:\NOKIA 3806 CPU SC6600L2 Flash NOR_ST_M58WR064KT Comport=COM7 Baudrate=921600 CPU_Type=SC6600L2 CPU_ID=66007001 NOR_ID=0020881000208810 NOR_Size=8MB NOR_Name=NOR_ST_M58WR064KT NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... RXD=8 TXD=3 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700100006A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_ST_M58WR064KT setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable All Done. |
09-11-2012, 07:37 | #1819 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=SpreadTrum Action=Format FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x00800000 Interface=COM FlashFile=C:\NOKIA 3806 CPU SC6600L2 Flash NOR_ST_M58WR064KT Comport=COM7 Baudrate=921600 CPU_Type=SC6600L2 CPU_ID=66007001 NOR_ID=0020881000208810 NOR_Size=8MB NOR_Name=NOR_ST_M58WR064KT NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... RXD=8 TXD=3 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700100006A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_ST_M58WR064KT setting the Flash Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 0A Start=0x007B0000, Size=0x00050000 Unlocking all blocks before program/erase... Unlock Done. Auto formatting... Done. |
09-11-2012, 07:39 | #1820 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=SpreadTrum Action=WriteFlash FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x00800000 Interface=COM FlashFile=C:\NOKIA COPY S16 CPU SC6600L2 Flash NOR_ST_M58WR064KT Comport=COM7 Baudrate=921600 CPU_Type=SC6600L2 CPU_ID=66007001 NOR_ID=0020881000208810 NOR_Size=8MB NOR_Name=NOR_ST_M58WR064KT NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... RXD=8 TXD=3 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700100026A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_ST_M58WR064KT setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable All Done. |
09-11-2012, 07:39 | #1821 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=SpreadTrum Action=Format FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x00800000 Interface=COM FlashFile=C:\NOKIA COPY S16 CPU SC6600L2 Flash NOR_ST_M58WR064KT Comport=COM7 Baudrate=921600 CPU_Type=SC6600L2 CPU_ID=66007001 NOR_ID=0020881000208810 NOR_Size=8MB NOR_Name=NOR_ST_M58WR064KT NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... RXD=8 TXD=3 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700100026A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_ST_M58WR064KT setting the Flash Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 0A Start=0x00790000, Size=0x00070000 Unlocking all blocks before program/erase... Unlock Done. Auto formatting... Done. |
09-11-2012, 07:42 | #1822 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=SpreadTrum Action=WriteFlash FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x00800000 Interface=COM FlashFile=C:\NASAKI G8 CPU SC6600L2 Flash NOR_ST_M58WR064KT Comport=COM7 Baudrate=921600 CPU_Type=SC6600L2 CPU_ID=66007001 NOR_ID=0020881000208810 NOR_Size=8MB NOR_Name=NOR_ST_M58WR064KT NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... RXD=8 TXD=3 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700100026A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_ST_M58WR064KT setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable All Done. |
09-11-2012, 07:43 | #1823 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM7 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00EF006000170000 NOR_Size=8MB NOR_Name=SF_FM25Q32 NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=8 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA04 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EF006000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: Z101.FET-C5.BOOM-V1-0722 |
09-11-2012, 07:43 | #1824 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=ReadFlash FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=C:\BOOM B707 (6252) Project ID Z101.FET-C5.BOOM-V1-0722 Comport=COM7 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00EF006000170000 NOR_Size=8MB NOR_Name=SF_FM25Q32 NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=8 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA04 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EF006000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: Z101.FET-C5.BOOM-V1-0722 Changing baudrate to 921600... Done. Reading full Flash... Saved file to: C:\BOOM B707 (6252) Project ID Z101.FET-C5.BOOM-V1-0722 All Done. |
09-11-2012, 07:45 | #1825 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=SpreadTrum Action=ReadInfo FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM7 Baudrate=115200 CPU_Type=SC6610/20 CPU_ID=66100000 NOR_ID=00C8004000160000 NOR_Size=4MB NOR_Name=SF_GD25Q32 NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... D-=8 D+=9 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM13 Connected...sending boot... FDL test...OK ArmBootMode: 6610000000005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading FileSystem info... File System Ver: 0A IMEI 1=868609003923975 IMEI 2=910575601400468 ------Auto Format Address------- Start=0x003D8000 Size =0x00028000 Read FS info...done |
09-11-2012, 07:46 | #1826 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=SpreadTrum Action=Format FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM7 Baudrate=115200 CPU_Type=SC6610/20 CPU_ID=66100000 NOR_ID=00C8004000160000 NOR_Size=4MB NOR_Name=SF_GD25Q32 NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... D-=8 D+=9 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM13 Connected...sending boot... FDL test...OK ArmBootMode: 6610000000005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 0A Start=0x003D8000, Size=0x00028000 Unlocking all blocks before program/erase... Unlock Done. Auto formatting... Done. |
09-11-2012, 07:47 | #1827 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM7 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00EF004000150000 NOR_Size=2MB NOR_Name=Unknown Flash NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA05 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EF004000150000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: 52D_19F_PAD_V03 |
09-11-2012, 07:49 | #1828 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=ReadFlash FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\52D_19F_PAD_V03 Comport=COM7 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00EF004000150000 NOR_Size=2MB NOR_Name=Unknown Flash NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA05 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EF004000150000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: 52D_19F_PAD_V03 Changing baudrate to 921600... Done. Reading full Flash... Saved file to: C:\Documents and Settings\SAEED\Desktop\52D_19F_PAD_V03 All Done. |
09-11-2012, 07:51 | #1829 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM7 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00C2002500350000 NOR_Size=2MB NOR_Name=SF_MX25U3235E NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CB02 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C2002500350000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: 52D_19C_PAD_V02 |
09-11-2012, 07:55 | #1830 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM7 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00C8006000170000 NOR_Size=8MB NOR_Name=Unknown Flash NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=1 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA05 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C8006000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: D5211_DNT_G88_BF_S01 |
