Dragon Box Chinese Phone Tool |
![]() | #1906 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2007 Location: karachi pakistan
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Action=ReadInfo FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM2 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00C8006000170000 NOR_Size=8MB NOR_Name=Unknown Flash NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=16 TXD=11 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CC01 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C8006000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: D5211_Z9_29_JAVA_S01 |
![]() | #1907 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=Format FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM2 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00C8006000170000 NOR_Size=8MB NOR_Name=Unknown Flash NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=16 TXD=11 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CC01 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C8006000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: D5211_Z9_29_JAVA_S01 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00768000, size=0x00098000 All Done |
![]() | #1908 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=IMEI FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM2 Baudrate=921600 Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=16 TXD=11 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CC01 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... IMEI=358688000000158 IMEI=358688000000158 Rebulid IMEI1=353056195192508 Rebulid IMEI2=353056280454369 |
![]() | #1909 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=Format FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM2 Baudrate=921600 CPU_Type=MT6225 CPU_ID=0D03000F NOR_ID=002088C400000000 NOR_Size=16MB NOR_Name=[ST] M30L0T7000T0, M36L0T7050T0 NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=23 TXD=2 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 002088C400000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... Failed to check H/W. Get Project ID from phone... Project ID: KXDX03B2_T3ZSP_NVND_AB_GRT_V01 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00E00000, size=0x00200000 All Done |
![]() | #1910 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=ReadFlash FlashType=NOR boot=Ver3.848 Expert Mode=Disable Range[start]=0x0 Range[size]=0x01000000 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\KXDX03B2_T3ZSP_NVND_AB_GRT_ V01 Comport=COM2 Baudrate=921600 CPU_Type=MT6225 CPU_ID=0D03000F NOR_ID=002088C400000000 NOR_Size=16MB NOR_Name=[ST] M30L0T7000T0, M36L0T7050T0 NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=23 TXD=2 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 002088C400000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Get Project ID from phone... ProjectID Not Found. Changing baudrate to 921600... Done. Reading full Flash... Saved file to: C:\Documents and Settings\SAEED\Desktop\KXDX03B2_T3ZSP_NVND_AB_GRT_ V01 All Done. |
![]() | #1911 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=Format FlashType=NOR boot=Ver3.848 Expert Mode=Disable Range[start]=0x0 Range[size]=0x01000000 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\Gright E72 mini (6225) S900B_JFY_T02_M0419_D_ML_A\Gright E72 mini (6225) S900B_JFY_T02_M0419_D_ML_A Comport=COM2 Baudrate=921600 CPU_Type=MT6225 CPU_ID=0D03000F NOR_ID=002088C400000000 NOR_Size=16MB NOR_Name=[ST] M30L0T7000T0, M36L0T7050T0 NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=23 TXD=2 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 002088C400000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Get Project ID from phone... ProjectID Not Found. Changing baudrate to 921600... Done. Formatting Flash... All Done |
![]() | #1912 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=Format FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM2 Baudrate=921600 CPU_Type=MT6225 CPU_ID=09030001 NOR_ID=0089890100000000 NOR_Size=32MB NOR_Name=[INTEL] PF48F40xxM0x0xx NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=4 TXD=8 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0089890100000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: N.NC8901053.MA10001.V1.3 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x01C00000, size=0x00400000 All Done |
![]() | #1913 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM2 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00C8006000170000 NOR_Size=8MB NOR_Name=Unknown Flash NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=2 TXD=23 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CE00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C8006000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: C100A3PLUS.JHZ.J04.110321.02 |
![]() | #1914 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM2 Baudrate=921600 CPU_Type=MT6225 CPU_ID=B503000C NOR_ID=0098000300000000 NOR_Size=16MB NOR_Name=[TOSHIBA] TC58FVM7TDD NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=6 TXD=5 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0098000300000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: M.RK32F6906.M28202.V1.2.0.0M0420 |
![]() | #1915 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=ReadFlash FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\M.RK32F6906.M28202.V1.2.0.0 M0420 Comport=COM2 Baudrate=460800 CPU_Type=MT6225 CPU_ID=B503000C NOR_ID=0098000300000000 NOR_Size=16MB NOR_Name=[TOSHIBA] TC58FVM7TDD NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=6 TXD=5 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0098000300000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: M.RK32F6906.M28202.V1.2.0.0M0420 Changing baudrate to 460800... Done. Reading full Flash... Saved file to: C:\Documents and Settings\SAEED\Desktop\M.RK32F6906.M28202.V1.2.0.0 M0420 All Done. |
![]() | #1916 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=Format FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\M.RK32F6906.M28202.V1.2.0.0 M0420 Comport=COM2 Baudrate=115200 CPU_Type=MT6225 CPU_ID=B503000C NOR_ID=0098000300000000 NOR_Size=16MB NOR_Name=[TOSHIBA] TC58FVM7TDD NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=6 TXD=5 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0098000300000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: M.RK32F6906.M28202.V1.2.0.0M0420 Changing baudrate to 115200... Done. Formatting Flash... AutoFormat address: start=0x00E00000, size=0x00200000 All Done |
![]() | #1917 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=SpreadTrum Action=WriteFlash FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x00800000 Interface=USB FlashFile=C:\Documents and Settings\SAEED\Desktop\NOKIA A108 CPU SC6600L7 Flash NOR_ST_M58WR064KT Comport=COM2 Baudrate=921600 CPU_Type=SC6600L7 CPU_ID=66007009 NOR_ID=0020881000208810 NOR_Size=8MB NOR_Name=NOR_ST_M58WR064KT NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... D-=8 D+=9 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM18 Connected...sending boot... FDL test...OK ArmBootMode: 6600700900005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L7 Flash: NOR_ST_M58WR064KT setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable All Done. |
![]() | #1918 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM2 Baudrate=921600 CPU_Type=MT6253 CPU_ID=0000000F NOR_ID=0089890300000000 NOR_Size=16MB NOR_Name=[INTEL] PF38F30xxM0x1xx NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=7 TXD=9 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6253, HardwareVer:8A00, SoftwareVer:8A04 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0089890300000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: T219.NYN.12832.NOTV.V22 |
![]() | #1919 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=SpreadTrum Action=Unlock FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x01000000 Interface=USB FlashFile=C:\Documents and Settings\SAEED\Desktop\XP CINTA (WHITE) CPU SC6600L7A Flash NOR_K5L2731CAM Comport=COM2 Baudrate=921600 CPU_Type=SC6600L7A CPU_ID=66007019 NOR_ID=00EC257E25082501 NOR_Size=16MB NOR_Name=NOR_K5L2931_2731CAM NOR_DieCnt=2 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM18 Connected...sending boot... FDL test...OK ArmBootMode: 6600701900005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L7A Flash: NOR_K5L2931_2731CAM setting the Flash Parameters... Settings have been completed! Connect and search Security Code... Privacy protect: 0 Theft proof: 222222 Privacy protect: 5 Privacy protect: 9 Privacy protect: 2 PhoneLock: 12590896 PhoneLock: 12590899 Privacy protect: 1234 Done. |
![]() | #1920 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=SpreadTrum Action=Reset FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x01000000 Interface=USB FlashFile=C:\Documents and Settings\SAEED\Desktop\XP CINTA (WHITE) CPU SC6600L7A Flash NOR_K5L2731CAM Comport=COM2 Baudrate=921600 CPU_Type=SC6600L7A CPU_ID=66007019 NOR_ID=00EC257E25082501 NOR_Size=16MB NOR_Name=NOR_K5L2931_2731CAM NOR_DieCnt=2 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM18 Connected...sending boot... FDL test...OK ArmBootMode: 6600701900005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L7A Flash: NOR_K5L2931_2731CAM setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Analyzing FileSystem... Done. Reset the user data area... Note: if user partition size is more than 4MB, The phone would may take 1 minute to rebuild FileSystem after Reset Action. All Done. |
