Dragon Box Chinese Phone Tool |
01-17-2014, 09:18 | #1 (permalink) |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | GPGDragon And SPD Android Read\Write Bin File<Test Mobile Sumsung X5292 4.11> Dragon Read Flash for SPD 6820 Not Dead Dragon Format SPD 6820 Most Safe(Not Get The USER say Dead Format In the 3.41E,But We can not say is 100%) Read Back Flash By USB Debug<Not ADB Tool,Dragon Team Made OWN Debug Tool> *This in the Reading Flash You can Open the task manager;Others Adb.exe in the process.But Dragon No; Read Back the Flash 100% Working,First we can see the read back after save the logo.bmp File,this is a pics,after read pac flash file,so many flash read form others is not pics,or damage And UBOOT.bin,NV.bin and others....File Size you can see is Different and Factory Flash But Dragon is Perfect; Now Just we Welcome New 2014 and More then More News for my dragon Lover ~`~`~`~`~`~`~`~`~`~`~`~`~`~`~`~`~`~`~`~`~`~`~`~`~` ~`~`~`~`~` Read back Flash File <Test Mobile Sumsung X5292 CPU 6820> Box Firmware Ver 1.65 Software Ver V3.41 Mobile Connecter By Dragon Jigs Mobile better Pin Connect to Box VCC and GND *auto pinfind,very Fast in the Last Dragon Firmware;you click start same time get the mobile pinout <Dragon Still is NO.1 in the World for China Mobile Auto Pinfind> Read Flash Start: Run Dragon V3.41E or More Last Tool Select TAP to Spreadtrue Mobile Option Switch To 6820 Select Read Flash Normal Software Read Flash Save to C:\tempFile.bin *if you need save to others path,Please Setting it first Then Click Start;some Phone need hold the boot key and wait the Software Read back Done!!! *Test 512MB Flash need about 35 Min Only(is Fast othen Others Team) Last edited by Dipendra Pathak; 01-17-2014 at 09:55. |
The Following 2 Users Say Thank You to Dipendra Pathak For This Useful Post: |
01-17-2014, 11:00 | #6 (permalink) | |
No Life Poster Join Date: Oct 2010 Location: china Age: 35
Member: 1428349 Status: Offline Sonork: 100.1597111 Thanks Meter: 13,139 | Quote:
Read This Please | |
01-24-2014, 16:50 | #10 (permalink) |
Insane Poster Join Date: Dec 2005
Member: 207593 Status: Offline Thanks Meter: 1 | when flas mobile by bin file it give this log:: >>> Getting Mobile Connection Info... VCC Pin: GND Pin:7, Signal Pin:1, 3, 4, 5, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:4 D-:3 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM91 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... >>> Opening File Error,Please Check the File Path... File No Found:C:\Users\azmiaf\Downloads\Compressed\درايفرا ت اندريود 2013\حل مشكله الايتيونز\برامج HTC\كلمة السر hTc toolkit\gt-s5830\تصليح التاتش\ملفات التاتش\gt-i9003\mt625a i9300 note\i9300 mtk625a\pac files new\Dragon_V3.41E_3\system\spreadtrum\6820_Write_B lock_Flash_1.bin |
01-24-2014, 21:59 | #11 (permalink) |
Freak Poster Join Date: Aug 2006
Member: 332522 Status: Offline Thanks Meter: 28 | My problem: >>> Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM68 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:0000ADBC Flash Size:20000000->512M Flash Name:NAND_HYNIXH8BCS0UN0MCR CPU Name:6820/8810 >>> Reading Flash... Error:Receive Data 0x7E Error... Error:Receive Data 0x7E Error... After this the phone no power on |
01-25-2014, 05:24 | #13 (permalink) | |
Freak Poster Join Date: Sep 2005 Location: quantity or quality? :)
Member: 179142 Status: Offline Thanks Meter: 42 | Quote:
>>> Getting Mobile Connection Info... VCC Pin: GND Pin:7, Signal Pin:1, 2, 3, 4, 5, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:4 D-:3 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM24 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:00002CBC Flash Size:20000000->512M Flash Name:NAND_SamSungMT29C4G48MAZAPAKD CPU Name:6820/8810 >>> Reading Flash... Error:Receive Data 0x7E Error... Error:Receive Data 0x7E Error... after this my phone was dead | |
01-26-2014, 04:44 | #14 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Q Mobile A2 Light 8810/6820 Successfully Flashed by GPG Dragon Dongle http://forum.gsmhosting.com/vbb/9741974-post64.html BR Dipendra Pathak |
