Dragon Box Chinese Phone Tool |
10-11-2012, 03:45 | #1 (permalink) |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Return to Data!! and how to Control this error? 1. Unsupported mobile CPU Like : http://forum.gsmhosting.com/vbb/f646...0/#post8681865 2. Driver not properly install so mobile could not find driver properly. 3. Computer CPU not compatible with the program 4. Unsupported Operating System Using with the Program 5. Mobile not connected with the software. Sometimes, you need continue Holding POWER BUTTON until Operation is finished. 5. Use lower Port if Possible (Below then 10) 6. Other unspecified Errors a . Like Mobile is MTK and you select SPD so mobile Boot File not find and mobile could not boot. b. Buggy windows (Operating System) is used We suggest you, find the correct CPU and try to connect with it. if the Cpu type is SPD, and you try to connect with MTK, of course there will be DATA Error!! Secondly, Check the CPU type that Dragon supports or not. If not supports, there might be DATA ERROR!! Thirdly, Install Driver Properly, if driver not install properly, software could not find boot file, so there might be Data Error!! Fourthly, Be sure that the Windows has no bug. And do not use unsupported Operating System that software could not recognize to the Operating system and there might be Data Error!! Finally, Handle software properly. Check Sticky thread regularly. Search the post if you are not success to connect with the phone. And, if you not find the solution in the previous post, then post your problem as new thread with all the problem mentioned clearly with screen shots of Dragon connecting windows and wait for reply. 7. Receiving Data Error: http://forum.gsmhosting.com/vbb/9582500-post3.html GOOD LUCK BR Dipendra Pathak Last edited by Dipendra Pathak; 12-20-2013 at 12:18. |
The Following 11 Users Say Thank You to Dipendra Pathak For This Useful Post: |
12-02-2012, 09:41 | #5 (permalink) |
No Life Poster Join Date: Jul 2009 Location: JHELUM,PAKISTAN
Member: 1082557 Status: Offline Sonork: 100.1611230 Thanks Meter: 199 | Two main problems of return Data Error Drivers not installed properly(Specially in MStar) 2nd= Scan Pin-out checking error... Untick that option and then check If not then one thing more that wrong chip scanning...... |
01-29-2013, 16:40 | #6 (permalink) |
Freak Poster Join Date: Nov 2009 Location: I.N.D.I.A
Member: 1169043 Status: Offline Sonork: 100.1586033 Thanks Meter: 58 | >>> USB Pinfind No need Hold Mobile Power key... >>> Searching Mstar Driver... For Mstar 853XB CPU;You need Hold Down the Power KEY. Find Mstar DriverI:\ --> GCREADER CPU_ID:0x00508003 CPU Name:MSW8533D Connecting Mstar CPU of the Mobile.... >>> Downloading First Boot... >>> Downloading Second Boot... BOOT version: 0x050618 Mobile RAM: 0x00400000 Flash Name:GIGA_GD25LQ64A Flash ID:0x00C86017 Flash Size:0x00800000 -> 8M >>> Initializing Boots... >>> Erasing Flash Now.... Hint: Use Page Erase Mode,Progress bar not standard... >>> Writing Flash File... All Done... |
The Following User Says Thank You to {X-MAN} For This Useful Post: |
02-11-2013, 00:43 | #7 (permalink) |
Junior Member Join Date: Jun 2005 Location: Belarus Zhlobin. Age: 40
Member: 156742 Status: Offline Thanks Meter: 0 | This error in new ver. And add project id in info like ver2.13 In all the pictures the verification procedure of the same phone. sorry for my english ... |
03-14-2013, 04:24 | #9 (permalink) | |
Freak Poster Join Date: Nov 2008 Location: Istanbul,Turkiye
Member: 908773 Status: Offline Thanks Meter: 13 | Quote:
If we will change NOR to NAND. i think all will be OK Last edited by ASAH; 03-14-2013 at 04:31. | |
05-10-2013, 12:23 | #15 (permalink) |
Insane Poster Join Date: Oct 2011 Location: okara pakistan Age: 47
Member: 1673729 Status: Offline Sonork: [email protected] Thanks Meter: 8 | where is Coolsand RDA Cpu Update Gpg Dragon Box Was Dead You Can Get An other Box |
